How many frames per second is enough?
Hello Logan, Wendell and the tek forums i have a question about  frames per second.
The general concensus seems to be that the higher the FPS in games the better. I  can understand that to some point but i dont really notice a difference between say 40fps and for example 60fps. In general i would say everything above 30fps seems about right as long as its a stable framerate and it doesnt drop below 30fps.
To give you an example, my desktop PC runs Battlefield 3 at an average of 40fps to well beyond 60fps and it runs really smooth with no slowdowns whatsoever.  On my laptop BF3 runs at between 25 and 60 fps and its the framedrops that you really can see, not so much the framerate itself.
Whats your opinion on FPS, how much is enough and can you really SEE the difference between a FPS above say 40fps? Are there any conclusive tests that show the human eye can see the difference between 60 and 120fps or are we all fooling ourselfs?
In my opinion its much more a matter of stable framerates then of high framerates.
To be honest i have noticed the same thing. As long as I have a stable 40+ fps I cant tell the difference. This could be because im new to pc gaming
I think 24+ is playable, and I want to always have 60 frames but I don't care if it goes above that.
From what I understand, going from 60 to 120 is a very minute difference.  You can't really see it, but as an experienced gamer, you may feel the difference.  Linus did a video on this.
http://www.youtube.com/watch?v=a2IF9ZPwgDM
So long as I can get a minimum of 60 fps in my games, I'm happy.  I usually notice when my frames drop to 30-45 fps, especially in games like BF3.
I consider everything below 40 not enjoyable to play, 50+ is what I aim for.
60fps or go home for me especially if i am playing a first person shooter like battlefield...frame drops can get you killed!
Yes but isnt it the frame DROPS that kill you and not so much the 'lower' framerate ?
You are going to have a lot more chances to drop below 30fps when you are running at 40fps than you are running a solid 60fps vsync'ed
You can instantly tell when you are running 30 fps over 60 fps in fps games you feel like you are running through soup when you are used to 60+fps.
to me it's not about framerate, it could be 20fps and it would still be perfectly playable, it's about stability, it's not that 40fps is that much worse than 60fps, it's that a 20fps drop is incredibly noticable and introduces a comparitivly large amount of lag
i don't care if dayz runs at 60, 40, or 20, so long as it can pick one and stick with it
One can quickly get used very high framerates when playing the right kind of games. Like back when in the CRT days I could easily spot if the framerate in Quake dropped down to around 60-70fps, because it was usually at 100. Nowadays when on a regular monitor 60 is the maximum actual frame rate, in first person shooters I feel okay as long as it does not drop too far below 50. Were I to get me a 120Hz monitor(not happening as long as they're TN panels) I would surely develop a problem with any first person game running at around 60, and would have to use low settings.
40+ is usually enough for me.  But 60 is always optimal, and it also depends on the game.  In a single-player FPS, 40 is good enough, but in multiplayer games where reaction time is key, its best to make sure you get at least 60.
Having to put up with Hd2000 has made me get used to <40fps, and I'm fine (in most genre's) with as low as 20, as long as it's stable.
My PC has spoiled me ever since I made the switch. 60fps is my preferred sweetspot for now, any slight change from that is very noticeable to me. As long as fps is constant I feel it is fine. It's pretty noticeable when a game drops 5 - 10 frames all of a sudden though.
I think it's down to personal preference and what will make your eye happy overall.
24 frames / sec is what most video formats play in. like the other members have voiced, its really all about how stable your frame rate is. it's its jumping around all over the place it causes a very unpleasant game experience. i usually turn vsync on and call it a day.
Personally i can tell the difference between 40 and 60. Never had a monitor capable of higher frames so i cant say anything above this point. I would imagine 120 fps is quite noticeable for most people thinking of peoples reaction the HFR version of The hobbit (even thought this might not be completely comparable to gaming on a computer monitor)
It would be really great if someone knew some scientific articles on this topic as it keeps popping up on various forums with out any kind of scientific experiment as background.
going from 30 to 60 is a noticable improvement in smoothness
A recent example that springs to mind is playing resident evil 6 on ps3 (which plays at 30fps) and then playing it on the pc (60+), the difference is clear.
Going from 60 to 120 I cant comment on as I haven't had a screen that can go beyond 75hz for the resolution I game at.
I usually aim for 40-50 fps, but if its 30 and very stable, that's fine, most movies are even shot in 24-30 fps
The frame "dropping" is also called stuttering, this used to happen a lot with AMD cards in crossfire, they would have a good average frame rate, but would stutter regularly. I don't think there are any problems with that anymore though.
Even the perceived difference between 30 fps (if its completely stable) and 120 is not that much, but the problem with games is that you can never have totally stable frames per second. a good thing to do is to tune your settings so your minimum fps never drops below 30 or so.
The frames per second all depends on what game, what graphics card, and how smooth the gameplay is. For example bioshock infinite is good at around 35 fps. On the other hand COD is good at 60 fps
Same
I am satisfied at 40+, 30 FPS feels too unresponsive. Obviously I prefer a solid 60 though :)
