How f*$%^d are my hard drives?
I have two hard drives that have started to exhibit some SMART errors and other problems. (Don’t look too closely at the dates–thankfully the files were backed up and none of this was critical, but it would be nice to know if the drives themselves are still useful in any way.)
Here’s the trail for the first drive, as told through email notifications from smartd and zed:
Drive CGR
Monday, October 20, 2025 04:43
Device: /dev/sdg [SAT], ATA error count increased from 0 to 2
Device info:
ST16000NM001G-2KK103, S/N:-----CGR, WWN:5-000c50-0-------8, FW:SN03, 16.0 TB
Saturday, December 06, 2025 02:28
Device: /dev/sdm [SAT], 8 Offline uncorrectable sectors
Device info:
Device: /dev/sdm [SAT], 8 Currently unreadable (pending) sectors
Device info:
Device: /dev/sdm [SAT], Self-Test Log error count increased from 0 to 1
Device info:
Sunday, December 07, 2025 01:59
Device: /dev/sdm [SAT], ATA error count increased from 2 to 5
Device info:
Sunday, December 07, 2025 10:39
ZFS has finished a scrub:
eid: 217
class: scrub_finish
host: silver
time: 2025-12-07 09:39:18+0000
pool: test2
state: ONLINE
status: One or more devices has experienced an error resulting in data
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: Message ID: ZFS-8000-8A — OpenZFS documentation
scan: scrub repaired 0B in 21:25:26 with 1 errors on Sun Dec 7 09:39:18 2025
config:
NAME STATE READ WRITE CKSUM
test2 ONLINE 0 0 0
ata-ST16000NM001G-2KK103_-----CGR ONLINE 9 0 10
errors: 1 data errors, use ‘-v’ for a list
Monday, December 08, 2025 12:07
eid: 221
class: scrub_finish
host: silver
time: 2025-12-08 11:07:54+0000
pool: test2
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
action: Determine if the device needs to be replaced, and clear the errors
using ‘zpool clear’ or replace the device with ‘zpool replace’.
see: Message ID: ZFS-8000-9P — OpenZFS documentation
scan: scrub repaired 0B in 21:13:10 with 0 errors on Mon Dec 8 11:07:54 2025
config:
test2 ONLINE 0 0 0
errors: No known data errors
Between the first and second scrub there, I deleted the file that had the corruption and everything has been good since then. I have not attempted to write anything, but the weekly scrubs have detected no further errors and no increase in bad sectors.
Here’s the second drive, also through email notifications:
Drive LJG
Tuesday, July 07, 2026 07:25
Device: /dev/sdf [SAT], not capable of SMART self-check
Device info:
ST16000NM001G-2KK103, S/N:-----LJG, WWN:5-000c50-0-------e, FW:SN03, 16.0 TB
Device: /dev/sdf [SAT], failed to read SMART Attribute Data
Device info:
Device: /dev/sdf [SAT], Read SMART Self-Test Log Failed
Device info:
Device: /dev/sdf [SAT], Read SMART Error Log Failed
Device info:
I don’t have the logs from this, but zfs had marked the drive as failed. I had immediately powered off the machine until I could deal with the problem. On reboot, I got a lot of angry logs:
A very sad kernel
Jul 12 16:01:00 kernel: ata13.00: exception Emask 0x0 SAct 0x800000 SErr 0xc0000 action 0x0
Jul 12 16:01:00 kernel: ata13.00: irq_stat 0x40000008
Jul 12 16:01:00 kernel: ata13: SError: { CommWake 10B8B }
Jul 12 16:01:00 kernel: ata13.00: failed command: READ FPDMA QUEUED
Jul 12 16:01:00 kernel: ata13.00: cmd 60/08:b8:00:00:00/00:00:00:00:00/40 tag 23 ncq dma 4096 in
res 43/00:08:00:00:00/00:00:00:00:00/00 Emask 0x401 (device error)
Jul 12 16:01:00 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:00 kernel: ata13.00: exception Emask 0x0 SAct 0x2 SErr 0x0 action 0x0
Jul 12 16:01:00 kernel: ata13.00: cmd 60/08:08:00:00:00/00:00:00:00:00/40 tag 1 ncq dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:00 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:00 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:00 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 2 dma 4096 in
res 53/04:08:00:00:00/00:00:00:00:00/e0 Emask 0x1 (device error)
Jul 12 16:01:00 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 3 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 4 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 5 dma 4096 in
Jul 12 16:01:00 kernel: I/O error, dev sdi, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Jul 12 16:01:00 kernel: Buffer I/O error on dev sdi, logical block 0, async page read
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 24 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 6 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 7 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 8 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 9 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 10 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 25 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 11 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 12 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 13 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 14 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 15 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 26 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 16 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 17 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 18 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 19 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 20 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 27 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 21 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 22 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 23 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 28 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 0 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 29 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 1 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 30 dma 4096 in
Jul 12 16:01:00 kernel: Dev sdi: unable to read RDB block 0
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 6 dma 4096 in
res 53/04:08:18:00:00/00:00:00:00:00/e0 Emask 0x1 (device error)
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 20 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 21 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 22 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 23 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:08:18:00:00/00:00:00:00:00/e0 tag 31 dma 4096 in
Jul 12 16:01:00 kernel: I/O error, dev sdi, sector 24 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Jul 12 16:01:00 kernel: Buffer I/O error on dev sdi, logical block 3, async page read
Jul 12 16:01:00 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 0 dma 4096 in
res 53/04:08:80:ff:bf/00:00:46:07:00/e0 Emask 0x1 (device error)
Jul 12 16:01:00 kernel: I/O error, dev sdi, sector 31251758976 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 1 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 10 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 21 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 12 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 2 dma 4096 in
Jul 12 16:01:00 kernel: I/O error, dev sdi, sector 31251758976 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Jul 12 16:01:00 kernel: Buffer I/O error on dev sdi, logical block 3906469872, async page read
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 28 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 17 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 6 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 20 dma 4096 in
Jul 12 16:01:00 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 0 dma 131072 in
res 53/04:00:00:00:00/00:00:00:00:00/e0 Emask 0x1 (device error)
Jul 12 16:01:01 kernel: ccp 0000:48:00.1: firmware: failed to load amd/amd_sev_fam19h_model01h.sbin (-2)
Jul 12 16:01:01 kernel: firmware_class: See I Challenge Thee for information about missing firmware
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90001, and key code 148: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90002, and key code 152: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90003, and key code 144: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90004, and key code 421: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90005, and key code 423: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90006, and key code 140: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90007, and key code 155: Invalid argument
Jul 12 16:01:01 (udev-worker)[2807]: event0: Failed to call EVIOCSKEYCODE with scan code 0x90008, and key code 150: Invalid argument
Jul 12 16:01:02 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:02 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:02 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:02 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:02 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 2 dma 131072 in
Jul 12 16:01:02 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:02 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:03 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:03 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:03 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:03 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:03 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 10 dma 131072 in
Jul 12 16:01:03 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:03 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:04 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:04 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:04 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:04 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:04 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 22 dma 4096 in
Jul 12 16:01:04 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:04 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:06 kernel: I/O error, dev sdi, sector 31251758976 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
Jul 12 16:01:06 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:06 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:06 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:06 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:06 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 26 dma 131072 in
Jul 12 16:01:06 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:06 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:07 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:07 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:07 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:07 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:07 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 2 dma 4096 in
Jul 12 16:01:07 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:07 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:09 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:09 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:09 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:09 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:09 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 6 dma 131072 in
Jul 12 16:01:09 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:09 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:10 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:10 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:10 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:10 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:10 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 22 dma 4096 in
Jul 12 16:01:10 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:10 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:11 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:11 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:11 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:11 kernel: ata13.00: failed command: READ DMA
Jul 12 16:01:11 kernel: ata13.00: cmd c8/00:00:00:00:00/00:00:00:00:00/e0 tag 13 dma 131072 in
Jul 12 16:01:11 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:11 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:13 kernel: I/O error, dev sdi, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 2
Jul 12 16:01:13 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:13 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:13 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:13 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:13 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 16 dma 4096 in
Jul 12 16:01:13 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:13 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:14 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:14 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:14 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:14 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:14 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 29 dma 4096 in
Jul 12 16:01:14 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:14 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:16 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:16 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:16 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:16 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:16 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 22 dma 4096 in
Jul 12 16:01:16 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:16 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:17 kernel: ata13.00: exception Emask 0x0 SAct 0x0 SErr 0xd0000 action 0x0
Jul 12 16:01:17 kernel: ata13.00: irq_stat 0x40000001
Jul 12 16:01:17 kernel: ata13: SError: { PHYRdyChg CommWake 10B8B }
Jul 12 16:01:17 kernel: ata13.00: failed command: READ DMA EXT
Jul 12 16:01:17 kernel: ata13.00: cmd 25/00:08:80:ff:bf/00:00:46:07:00/e0 tag 12 dma 4096 in
Jul 12 16:01:17 kernel: ata13.00: status: { DRDY SENSE ERR }
Jul 12 16:01:17 kernel: ata13.00: error: { ABRT }
Jul 12 16:01:18 kernel: I/O error, dev sdi, sector 31251758976 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Jul 12 16:01:18 kernel: Buffer I/O error on dev sdi, logical block 3906469872, async page read
Jul 12 16:01:57 systemd[1]: Failed to mount test-test0.mount - /test/test0.
I have a feeling the answers to the question in the subject are:
  • drive CGR should never be trusted again
  • drive LJG is completely toast
I would love to hear that I’m wrong though. I’m also intrigued about what might have caused LJG to go offline so dramatically without any warning. I’ve been running regular zfs scrubs and SMART self-tests as long as I’ve had the drive and there wasn’t a peep about it until the message on July 7.
(Of course, these drives are both out of warranty by just under a year :confused: )
Thanks!
That implies you were trusting it before.
Its used with zfs, and kept under surveillance like it wanted to steal your girlfriend, so probably you werent.
I dont understand the file corruption part, is this not a redundant setup where zfs cannot just auto heal? thats strange.
Imho its probably fine and can stay, if bad blocks are not increasing that was just an event and not the beginning of the end.
I have old drives with some bad blocks that just happened years ago and never had issues since. But they are all used in arrays so there is redundancy in case they act up again.
Obviously the answer changes if I was not using zfs or btrfs or snapraid, on windows for example you have to trust the drive much more.
bad luck. Something failed catastrophically on the control board and it refuses to even establish a sata connection
Looks like the drive was generating errors and on reboot was completely toast?
Trash it, replace, move on?
Unclear what ZFS pool config is, presumably you have pool resiliency? Are these drives on an add in HBA?
Also remember:
ZFS is not a substitute for backups. Its higher availability but still subject to things like controller failure, multiple disk failure, OS induced file corruption (consistent on disk, but ruined via app), etc.
Check your SMART data and see if those are SMR drives. If they are, and you’re hitting them with random writes or using them in a parity array, that ‘f*$%^d’ feeling is often just the drive’s cache overflowing and the performance hitting a wall.
Very true, I wasn’t trusting it all that much before.
There was no data loss here at all, thankfully, just the loss of the drives.
Good question: both of them are directly connected to the motherboard via an OCuLink 4x SATA breakout (the other drives on this link are fine.)
They’re CMR, so fortunately that’s not the problem.
The drive continues to fail SMART self-tests which is annoying, but otherwise seems to be continuing fine for now. I guess I will use it with the same caution I have so far: redundancy and backups.
Since all of that can be attributed to random crap here’s what I would do.
First, pull them out of service.
Then wipe the drives by writing zeros
dd if=/dev/zero of=/dev/sdxxxxx bs=whatever
No attempt to save anything. If I got errors doing that, I assume the drive is toast and replace. Otherwise, this is about as clean and fast a write test as you can get.
Then I run badblocks twice - first in non-destructive read mode (nice and fast) be sure to log any bad blocks
Then I run it a second time with read/write (4 pass random) pattern. Again, log any bad blocks.
At this point, if the errors/performance was acceptable, I’d mark the bad blocks (one of many reasons to keep the logs) and put it back in service (in a less critical application maybe). And still watch it.
I’ve done some version of this since the DOS days, and it’s amazing how you can revive a seemingly dead drive.
Good luck
