How does this build look for a $850 budget?
This is list of all the components I have come up with for around $850, I wanted to get a second opinion before buying them.
Processor(CPU):  AMD Phenom II X4 965 Black - $94.99
CPU Cooler: Cooler Master Hyper 212 EVO - $29.99
MotherBoard: ASUS M5A97 R2.0 ATX AM3+ - $94.99
Memory(RAM): G.Skill 8GB (2x4GB) DDR3-1600MHz - $66.99
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive - $65.98
Graphics Card(GPU): XFX Radeon HD 7850 2GB GDDR5 860MHz - $209.98
Case: NZXT Phantom 410 Mid Tower - $84.50
Power Supply(PSU): XFX 750W 80 Plus Bronze ATX12V/EPS12V Semi-Modular - $84.99
Optical Drive: Asus DRW-24B1ST/BLK/B/AS - $19.99
Operating System: Windows 7 Home Premium 64bit - $89.98
Total - $832.39
Please leave any suggestions! Thanks!:)
What country are you from?
United States
http://pcpartpicker.com/p/19gnD
you can get a 7870 or sometimes a 7870xt/le for that much, unless you plan on adding more gpus that's far overkill on the psu, i'd reccomend getting a cheaper case (but that's the most subjective thing, so i'm not going to try and make you)
http://pcpartpicker.com/user/Manimal/saved/1P4Z
This is pretty good. No bottlenecks as far as I can see. The XT version of the 7870 is great. I also found an amazing deal on a 7970. It was 305$ if you want to give up 40 dollars over your budget you could get a VERY good graphics card.
How do these changes look?
http://pcpartpicker.com/user/ICONICx12/saved/1uYc
