I’m considering an upgrade to my current AM4 system, and have a real hard time deciding between the Ryzen 7900X3D and 7800X3D. The price difference in my country is miniscule, so what’s keeping me up at night is the 2 CCD situation on the 7900X3D.
I’m purely running Linux and use my PC both for work (involves compilation, containerization, VMs) as well as gaming mainly through Steam/Proton.
So my question is: Does anyone know if the process scheduler in Linux works better than the Windows one for these heteregenous CPUs?
E.g. will it pick the v-cache enabled threads for gaming out-of-the-box or not?
As far as I can tell from early reviews on Phoronix it didn’t work well back then, but I haven’t been able to find updated information.
One suggestion I did stumble upon was reducing core frequency on the non-v-cache cores in UEFI. I can live with a slightly lower boost clock on the second CCD, but I can’t find any information about the process scheduler using boost frequency for its decision making either.
Finally I’m normally using the amd-pstate driver with the schedutil governor.
I hope someone here has some insights into the matter, to ease my buying decision
