How do you correctly install an RGB LED strip on the ASRock X299 Taichi motherboard to avoid damaging the components?
What are the specific steps and precautions needed for safely installing an RGB LED strip on an ASRock X299 Taichi motherboard, ensuring that the strip is properly connected without causing any damage to the motherboard components? https://mans.io/files/viewer/1219985/61
Make sure you’re using a 12V LED strip and not a 5V “addressable/digital” one. Fasten the strip to the case or wherever. Plug it into the motherboard headers. There’ll be an arrow on the connector, match this up to the arrow or mark on the motherboard. Done. You can put a dot of glue gun on the connector if it keeps falling out, as they are wont to do.
