How do I patch panel
Howdy ya’ll,
Next year the missus and I are building a new house. Obviously I’m going to run Cat 6a cables to every room. my network will be my modem, router, 16 port switch, patch panel.
My main question is about the patch panel. After watching this video https://youtu.be/TgvmM6R8rQc. The guy is talking about 568A and B. If i understand this correctly, the only difference is the order in which the wires are connected? I can see the different pattern. I will have to wire both sides to activate each port?
568B is the common way of wiring but as long as you do both ends of the cable the same either will work. A vs B puts different pairs on different pins. Both were originally designed for compatbility with different legacy systems that aren’t much of a concern anymore.
So can I wire both sides 568B?
Yes, that is the idea.
Cool, I’m going to run at least 12 wires.
Congrats on the house.
Type A is the standard here in OZ, i think from memory Tybe B is USA, as @freqlabs said as long as you stick to the same throughout it makes no difference.
