How do I make a disk image in Clonezilla (keeps imaging parts)
I selected “expert” mode as beginner FORCES me to choose between compression, or compression.
Clearly I’m not expert but I chose disk image not partition image. But I’m on my second run and I see it blacking out the screen for each partition again and it looks like I’ll get the same result. Why does this have to nbe so difficult? Can the developers not test their own software and realize that when disk image is selected, the image file is ssplit into four files for each partition?
So annoying.
So your "expert’ mode screen onl has compression?
Not choices between partimage/DD/ntfsclone?
Default images are saved to 4096 sections, but expertmode alleges the ability to change it.
Which version of clonezilla are you running, in case anyone else uses it??
Expert option is listed likeghe following, but maybe their website is outdated
https://clonezilla.org/clonezilla-live/doc/01_Save_disk_image/advanced/09-advanced-param.php
Beginner mode only allows compressino, zip or something else. Only two options. It’s my limited understanding, that if I compress the image, it would make sense that I’d have to decompress it in order to run it in a VM, well I don’t have space for that. How would a “beginner” even know that? There could be so much more detail in the setup screens.
I’m on an older version, 3.0.1.
So, Expert mode with no compression (I’d have to have two hard disks running with ample space (which I’d have to clear my SSD backup, etc) but I’m left with filename*.uncomp for each partition. I thought it’d just be one big image, but it seems that’s not working. The default it to use 0 for the splitting, so it doesn’t look like each partition should have its own file, I chose disk image, not partition image, but I still get all four partitions in the final output.
Edit: Also I tried direct disk copy, and also the second time, I tried ntfs clone, same results.
I don’t mean to be ignorant, but have you tried a live version of a “desktop” Linux distro? Maybe a graphical disks utility might be easier to work with?
Even on a pi, the computer will run a GUI os faster than disk speed, so if clonezilla’s tools aren’t working for you, try another way?
If the destination has more space available that the source, then gnome-disks can point and click make disk images?
You don’t want partition cloning, but I always liked gparted ‘’a copy and pasted function of partitions, as long as it had ntfs clone tools or whatever in the background.
I am sorry I have not used Clonezilla before, and to be honest, have googled how to use pv and dd to pipe whole disks into gzip, then on to files or images a couple times, but not tried Clonezilla.
I think it is a you thing, I use Clonezilla in a personal and professional environment. The compression is for sparse files so that you don’t copy all of the empty space = smaller images. When you write them to the disk, they will balloon back to the original size on disk.
What is your actual use case for not using compression. If you cannot use compression, then why not just use DD and be done with it?
Clonezilla makes all of that pretty easy. The beginner mode is so easy that even a Marine can do it (I love my Marines). I think OP may have jumped off the deep end and does not understand the tools, or his use case is very particular and would need to use a manual solution, like you mentioned.
What VM host software are you using? Most can load compressed images.
just use DD and save yourself the trouble.
https://man.archlinux.org/man/dd.1
dd if=/dev/<device> of=<device_path or image_name.img> bs=4096 status=progress
