Sorry for my english, Now, how will bf3 run on my pc? good? bad?
pc specs: intel i5 2300 2.80 ghz dual core
Msi geforce gtx 460 1gb
4 gb of ram
please respond as soon as possible! Thanks!
Snap, i didnt think it will look so clumsy, sorry for that!
You can edit your post to correct it. That will do fine, probably can't run it at full settings with maxed AA, but you should have no problems.
a mix of highs and very high with no AA
Run it on medium textures, low shadow detail, high character models with a maximum of 2x AA, if not zero AA.
