I try to reset my cisco wireless router, but I can’t reset it. Please help me to reset or figure out the issuse.
usually they have a reset button you might need a paperclip to press it.
If its a software reset type you need to access the default password.
if all else fails just replace the router they dont cost very much.
Model might help here is a random one tho
You just plug in a networking cable into port 1
Like @Gnuuser said, there should be a hole somewhere to stick a bent open paper clip into.
Thats a switch XD
need to provide the model number of the router. Cisco make a lot of models and they reset differently. AKA a Meraki is different from a catalyst
