I have an external backup drive encrypted by BitLocker for security reason. But my new Mac refuses to open it when connected. The Mac is running the latest macOS 27 Gold State.
It only lists eject the drive, ignore and erase option when it detects the drive during connection.
How can open and unlock bitlocker drive on macOS 27?
If you know Dislocker you can use it to open BitLocker drives on macOS 27. It basically creates a virtual NTFS partition from your encrypted volume, and then you mount that on your Mac.
Before you open BitLocker drives on macOS 27. You’ll need to install it via Homebrew, use the Terminal, and have your 48-digit recovery key or password handy.
You could take a look at bitlocker-automount. It’s an open-source project for Apple Silicon Macs that aims to mount BitLocker-encrypted drives, with read-only access by default. It may be worth trying if you just need to get files off an external backup drive without modifying the original.
Check the README for dependencies and setup steps, and verify that it works with your macOS version before relying on it. You’ll need your BitLocker password or recovery key. If your goal is to open bitlocker drive on mac, don’t select Erase in Disk Utility, since that could wipe the drive.
As far as I know, macOS has never supported BitLocker natively, so this isn’t a macOS 27 bug. The Mac only gives you Eject, Ignore, or Erase because it just doesn’t recognize the encrypted volume.
Thanks for the remind. Unfortunately, I can’t format the drive currently as there are a lot of files on it. I would definitely format it with exFAT next time. For now, I need to find a valid option to open bitlocker drive on macOS 27 Gold State!
Hey, using Parallels Desktop to run a Windows virtual machine is one way to access a BitLocker-encrypted drive on macOS 27. If Windows can access the physical drive directly, you can unlock it using your BitLocker password or recovery key.
How to open bitlocker drive on macOS 27:
Install Windows 11 in Parallels Desktop on your Mac.
Connect the BitLocker drive to your Mac and select the option to connect it directly to the Windows virtual machine.
Open File Explorer in Windows and locate the drive.
Enter your BitLocker password or recovery key to unlock the drive and access your files.
If you’re cool with terminal commands, willing to risk a beta-ish setup, and have your recovery key handy—it might work to open bitlocker drive on macOS 27.
To open bitlocker drive on macOS 27, you can try Dislocker, which can unlock BitLocker-encrypted volumes without running a Windows virtual machine. Check its official GitHub page for installation requirements first.
How to use it:
Identify the BitLocker partition on your Mac.
Install Dislocker and create a directory for the unlocked volume.
Run this command, replacing /dev/diskXsY with your actual partition identifier:
Enter your BitLocker password when prompted, then follow the project’s instructions to mount and access the decrypted files.
This gives you another way to open bitlocker drive on macOS 27 without a paid unlocking app. Compatibility with macOS 27 is not guaranteed, so check the project’s current requirements before proceeding. Don’t erase or format the original drive.
Lukotta helps me open bitlocker drive on mac. It uses a small Linux virtual machine to handle disk access, making it easier for me to use these types of encrypted volumes on macOS.
Here’s a quick overview of how to use it:
First, download the software, connect your drive, and then follow the prompts to unlock the encrypted volume using your key as needed.
Once the encrypted volume is successfully mounted, open Finder, locate the volume, and you’ll be able to access the files inside.
Depending on the file system and mounting permissions, you can read from, write to, and eject the drive just as you would with any other mounted volume.
i wrote this a while ago feel free to use, it fork it, whatever.
its basically an updated dislocker, with a UI so its super easy to use, not only that ive added write support in 2 modes, 1 direct and another via a virtual Drive.
bitlocker-unlock-macos - just do a search on github. or not.
