How about this for a first "from scratch" build?
I haven't actually built a PC before, I purchased a stock Lenovo and just slapped a new GPU and PSU in it and off I went into the wonderful world of PC gaming! I've decided it is time to build a PC from scratch though. I've got a list here, and just want to know how it looks!
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
GPU: XFX Radeon HD 6770 1GB 128-bit GDDR5
RAM: CORSAIR Vengeance 8GB Dual Channel DDR3 1600MHz
PSU: CORSAIR Builder Series CX600 V2 600W
MOBO: GIGABYTE GA-970A-D3 AM3+ AMD 970 ATX AMD
CASE: NZXT M59 - 001BK Black Steel ATX Mid Tower
Now, the GPU and PSU are leftover from my previous system, and I will eventually upgrade to a better card, but I would like to know how it looks as-is? The CPU in my last build (an old Athlon) was bottlenecking my old PC, so I never really got to see how well the 6770 can perform, sadly :(
Everything looks good, only thing I would suggest:  If you can find 1866MHz Ram for similar price then go for that.  Your motherboard supports it.
Here is some 1866MHz for $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
cant lose with corsair or g.skill
