Then the Debian package maintainer has stupidly removed the critical versioning information needed for debugging. I just had a look at the package in sid also, it’s extremely old.
Nobody should be packaging LG yet, it’s still in Beta and changes extremely frequently, least of all a distro that has such a slow/long release cycle. Please use the B2 stable sources from the LG website and the host binary provided for it. Do not use git unless you’re intending to do development and provide PRs.
Also note that IGP performance is quite poor when exceeding FHD (1080p) or 60FPS due to system memory bandwidth constraints. it’s recommended you use a discrete GPU for your host, even if it’s older/slow.
879447583 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
879450067 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
879460301 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
879463580 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
879588246 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
879595718 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
879603700 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
879604996 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
879729676 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
879730798 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
879739933 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
879741325 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
879867607 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
879868738 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
879879084 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
879880468 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880032935 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880033997 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880043711 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880045104 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880146217 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880147198 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880156204 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880157619 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880411913 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880413104 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880424073 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880425570 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880517676 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880518488 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880525639 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880526754 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880674519 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880675583 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880683678 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880684925 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
880844940 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
880846118 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
880855591 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
880857062 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
881044923 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
881045985 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
881054132 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
881055436 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
881223060 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
881224037 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
881231682 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
881232842 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
881375621 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
881376879 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
881388069 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
881389917 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
881507970 [I] platform.c:329 | app_init | System timer resolution: 48.82 ns
881508981 [I] app.c:445 | app_main | Looking Glass Host (B2-0-g76710ef201)
881516639 [E] ivshmem.c:72 | ivshmemOpen | Unable to enumerate the device, is it attached?: 0x00000103 (No more data is available.)
881518041 [E] app.c:450 | app_main | Failed to open the IVSHMEM device
