Nx2l's Home Lab blog
So… im still messing with this crap…
Found the solution… try to patch now.
https://github.com/zfsonlinux/zfs/issues/8318
I default to rhel world as well, but if ZoL is in the mix, I go with Ubuntu for the native support.
I understand though. You gotta keep up appearances.
There must be something missing.
Not having any luck with those steps yet…
ll /lib/modules/4.20.10-200.fc29.x86_64/
total 16940
-rw-r–r--. 1 root root 258 Feb 15 13:57 bls.conf
lrwxrwxrwx. 1 root root 40 Feb 15 13:57 build -> /usr/src/kernels/4.20.10-200.fc29.x86_64
-rw-r–r--. 1 root root 201371 Feb 15 13:56 config
drwxr-xr-x. 2 root root 42 Feb 22 22:28 extra
drwxr-xr-x. 14 root root 157 Feb 22 21:13 kernel
-rw-r–r--. 1 root root 1074886 Feb 22 22:28 modules.alias
-rw-r–r--. 1 root root 1048515 Feb 22 22:28 modules.alias.bin
-rw-r–r--. 1 root root 1692 Feb 15 13:57 modules.block
-rw-r–r--. 1 root root 8296 Feb 15 13:57 modules.builtin
-rw-r–r--. 1 root root 10721 Feb 22 22:28 modules.builtin.bin
-rw-r–r--. 1 root root 394505 Feb 22 22:28 modules.dep
-rw-r–r--. 1 root root 544122 Feb 22 22:28 modules.dep.bin
-rw-r–r--. 1 root root 363 Feb 22 22:28 modules.devname
-rw-r–r--. 1 root root 153 Feb 15 13:57 modules.drm
-rw-r–r--. 1 root root 69 Feb 15 13:57 modules.modesetting
-rw-r–r--. 1 root root 2667 Feb 15 13:57 modules.networking
-rw-r–r--. 1 root root 136744 Feb 15 13:57 modules.order
-rw-r–r--. 1 root root 562 Feb 22 22:28 modules.softdep
-rw-r–r--. 1 root root 452719 Feb 22 22:28 modules.symbols
-rw-r–r--. 1 root root 553036 Feb 22 22:28 modules.symbols.bin
lrwxrwxrwx. 1 root root 5 Feb 15 13:57 source -> build
-rw-------. 1 root root 4111527 Feb 15 13:56 System.map
drwxr-xr-x. 2 root root 6 Feb 15 13:54 updates
drwxr-xr-x. 2 root root 40 Feb 22 21:13 vdso
-rwxr-xr-x. 1 root root 8753352 Feb 15 13:57 vmlinuz
Its not showing up… I guess i have to wait until the next zfs release… or go back a kernel…
im just going to stop tonight… for real this time.
Edit 1
Actually got it…
I imported my pool and now a disk is not showing up…
EDIT 2 :
The steps are:
  • Make sure that you are running the kernel that you want to build the module for:
    uname -srm Linux 4.20.7-100.fc28.x86_64 x86_64
  • Reinstall zfs and spl packages to have a clean environment:
    dnf reinstall zfs-dkms spl-dkms zfs
  • Download ubuntu’s zfs-linux tarball:
    wget https://mirrors.edge.kernel.org/ubuntu/pool/main/z/zfs-linux/zfs-linux_0.7.12-1ubuntu5.debian.tar.xz
  • Extract the archive
    tar xjf zfs-linux_0.7.12-1ubuntu5.debian.tar.xz
  • Enter the patches dir:
    cd debian/patches
  • Apply the patch to the zfs source:
    sudo patch -p1 /var/lib/dkms/zfs/0.7.12/source/include/zpios-ctl.h <3204-Add-4.20-timespec-compat-fix.patch
  • Remove the modules that dnf built upon installation of the package:
    sudo dkms remove spl/0.7.12 --all
    sudo dkms remove zfs/0.7.12 --all
  • Build the modules anew from the patched source code:
    sudo dkms --force install spl/0.7.12
    sudo dkms --force install zfs/0.7.12
  • Load the module: modprobe zfs
    Now you should be able to restart the zfs-services and mount your pool(s), or just reboot your machine to make the changes to take effect.
I’m in the same boat. Was working on a jbod. Plugged it back in and half the drives are degraded or unavailable. Think this guy might be on the way out.
I think we’re all clear now…
Just have to restore a few config files
I got the fibre targets enabled again to my compute server.
Are you still up?
I woke up a couple hours ago
I’m still up :frowning: I also had a ZFS fiasco involving a resilver and subsequent scrub. SAS cables are so sensitive.
Sorry to hear.
what brand?
The ones inside Supermicro JBODs. I’m not exactly sure what happened. Part of my fan mod was pinching or pulling or interfering with the connection in a way where the communication with the HBA was garbled.
It still saw about 2/3rds of my disks in varying states and tried to start resilvering over the bad connection. Fixed it and then it repaired itself and gave me s cryptic warning that “applications might be affected”.
Is everything ok now?
As far as I could tell everything was fine. There was a backup in the last 24 hours so not a shit-your-pants situation, I just needed to get the box back up.
And then?
Alright team, I got another situation. I have some docker containers up and running, we’ll use keycloak at port 8082. When go to http://<ip>:8020, everything is fine and dandy.
Whomst-ever, I tried to add an nginx reverse proxy and it’s acting like it can’t find the host? My config basically looks like:
location / {
    proxy_set_header Host $host;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_pass http://<ip>:8020;
I don’t remember the exact errors (I can get those tonight if it will help) but is there anything special about proxies in docker?
Wish I could help… but I’ve never messed with proxies in docker
Im pretty interested in replacing my home lab setup an Epyc 7371 system… but other than a few articles…
I havent found anywhere that has it in stock.
Hey guys, I thought you might like my Home(lab)-made Container Orchestration Platform that I made because (in part) of this blog. Lemme know what you think!
Considering selling my current storage setup (6 core i5 . 8th gen with 64GB memory) for this:
Of course reusing my SAS HBA, FC HBAs, PSU, and case.
Thoughts??
  • yes
  • no
  • yes, but…
  • no, but…
  • other …
0 voters
What will this allow you to do that you can’t do now?
maybe…but not really. My next step probably should be more harddrives…
damn you… asking the questions that make me reflect on my idea.
… might could if I also sold my compute system and integrated everything into one machine. But I dont think I want to do that.
