I am using some Ikea Jonaxle shelves to clean up my space in the office. There is a different model with better spaced shelves. I like to be difficult apparently. This is the one designed for wire baskets. I used 3 additional top shelves but they need modified. You need to trim the corners just a bit. I did it with a grinder but a dremel or something to cut light metal would work.
