Holding FFmpeg using apt-mark can cause stuff to uninstall
Seems there’s a problem with 2 apps on my installation now thinking they need to be uninstalled for the greater good after a recent Ubuntu apt update
The following packages will be REMOVED:
  mpv obs-studio
They did not do this before, only solution I was able to come up with on the fly to keep the programs after updating was to hold the packages.
Before this, no issues whatsoever with holding ffmpeg because I did a manual build of it. Now all of a sudden, each apt update these apps REALLY want to be uninstalled. Unfortunately this looks like it is likely because I have a custom build of FFmpeg that breaks dependencies.
It managed to go away when I removed the PPA I built from, and properly reheld the proper shared libraries FFmpeg depended on.
Keep in mind, dependencies is a really convoluted rabbit hole that can cause problems when you manually build from a PPA source.
