High speed local storage for workstation
I am busy with improvements for my workstation and want (need?) high speeds storage for the following:
  • VM’s ( multiple at the same time, depending on the project but about 3 at the same time )
  • github actions local runs
  • docker containers ( about 5 at the same time )
  • web development
  • ansible automations
    And allot more.
I have thought of just buying 1 x 375gb optane ssd but even that would be limited with everything running at full bore and it’s not enough space.
sooooo, what about 2 or even 4 x 375gb intel optane SSD’s and combine them. The problem then is with what.
ZFS, LVM etc etc. All good possible options. But i want iops. sweet sweet iops. but how? Creating a ZFS pool is easy.
I don’t want to spend thousands of euro’s for a storage set-up.
who has some advice or even examples? Thanks :slight_smile:
EDIT:
I don’t really care about safety :grin: . I have a nas that i make backups to.
I often work with databases bigger then 40gb.
If your board supports bifurcation, a PCIe to M.2 breakout board and some decent m.2 optane drives.
If you want more, U.2 drives.
That is what i want to do yes. But the second issue is how to combine them.
What’s your hypervisor / caremetal install?
If you really do not care about safety or security then put each one in as an individual drive and split your workloads.
I run RHEL 9 with vmware workstation. i got more VM’s then 4 so adding a drive to each vm is not really a option.
probably not, but you can divy up the workloads. ZFS in RAIDZ1 across 4 drives gets you where you wanna be without too much overhead and some bit of redundancy. Striping would lay blistering numbers, but 1 controller clocks out and the array is lost
