High ping latency with 4x 2.5Gb PCIe card
has anyone seen anything like this before? I recently bought from amazon: GLOTRENDS ST7419 2.5Gb Network Card with 4 RJ45 Port, Intel I226-V Controller, PCIe 3.1 x4. I’ve put it in a minisforum ms-a2 (latest bios).
When I ping other devices through this port there is horrendous ping - 50ms - 800ms.
PING 172.16.1.2 (172.16.1.2) 56(84) bytes of data.
64 bytes from 172.16.1.2: icmp_seq=1 ttl=64 time=332 ms
64 bytes from 172.16.1.2: icmp_seq=2 ttl=64 time=68.8 ms
64 bytes from 172.16.1.2: icmp_seq=3 ttl=64 time=509 ms
64 bytes from 172.16.1.2: icmp_seq=4 ttl=64 time=327 ms
I’ve turned off all power management, offloading etc. but it’s hard to imagine what could be causing hundreds of milliseconds of delays - other than some kind of catastrophic incompatibiltiy or design flaw
Have you tried a different ethernet cable?
yes.
I don’t see any stats around packet retransmissions with either cable. I’ve also used the same network cable to do ping tests to the same target device via a switch and the pings are ~1ms as expected. I’ve also tried different ports on the 4-port card.
I’ve just now added the same card to an older dell precision tower (intel) and i’m also seeing problematic pings:
~$ ping 172.16.1.2
64 bytes from 172.16.1.2: icmp_seq=1 ttl=64 time=26.1 ms
64 bytes from 172.16.1.2: icmp_seq=2 ttl=64 time=51.8 ms
64 bytes from 172.16.1.2: icmp_seq=3 ttl=64 time=60.9 ms
64 bytes from 172.16.1.2: icmp_seq=4 ttl=64 time=21.8 ms
64 bytes from 172.16.1.2: icmp_seq=5 ttl=64 time=63.6 ms
64 bytes from 172.16.1.2: icmp_seq=6 ttl=64 time=34.7 ms
64 bytes from 172.16.1.2: icmp_seq=7 ttl=64 time=17.8 ms
64 bytes from 172.16.1.2: icmp_seq=8 ttl=64 time=91.0 ms
I’m fairly certain now that the card is faulty, and it’s not just a config or incompatibility issue with the minisforum ms-a2.
OS? What does PCI Express stats report?
OS Linux. What do you mean by PCI Express stats exactly?
$ ethtool -S enp6s0 | grep -iE “error|drop|crc|fec”
rx_crc_errors: 0
rx_missed_errors: 0
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_window_errors: 0
rx_long_length_errors: 0
rx_short_length_errors: 0
rx_align_errors: 0
dropped_smbus: 0
qbv_config_change_errors: 0
rx_errors: 0
tx_errors: 0
tx_dropped: 0
rx_length_errors: 0
rx_over_errors: 0
rx_frame_errors: 0
rx_fifo_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
rx_queue_0_drops: 0
rx_queue_1_drops: 0
rx_queue_2_drops: 0
rx_queue_3_drops: 0
lspci -vvv
Seems like GLOTRENDS products are all garbage and have some weird hardware issues or are designed poorly
I’d return it as soon as possible
Found this in under one of the reviews that seems like very much the thing you’re experiencing
Name seemed familiar and when I checked my order history I bought a NVMe carrier board from them this month and when it was failing PCIe training I found out they slapped a very cheap SATA controller on it and is not a proper NVMe card.
That’s good information.
