Help
I'm having problems with my computer I'm getting fluctuating frame rates and static in my headset when i play games. In battlefield 3 i was getting between 30-50 frames while my friend was getting 80-100 frames we had the same display settings and our PC's are almost exactly the same the only difference is we have different companies make our video cards (I have a sapphire vapor-x radeon hd 7950 and he has a gigabyte radeon hd 7950).
Here are my specs:
AMD fx-8350
Gigabyte GA-990FXA-UD3
Corsair H80i
2x8Gb corsair vengence ram
Sapphire Vapor-x Radeon HD 7950
Corsair AX750 watt Power Supply 80+ gold
and I use a Razer Kraken Pro as a headset can someone help me solve this problem
what driver version does he have in comparison to yours, have you downloaded the latest or did you just use the ones on the CD (BAD)
install sapphire trixx and monitor your temps and see if your are being throttled due to temps
Update all the drivers.  A 7950 should work pretty well for BF3
I have the latest drivers and i downloaded the Trixx program and i was getting 50 degrees Celsius temperatures and i was still getting messed up frame and in Skyrim I was skipping across the screen do you have any ideas of what could cause that?
Make sure everything is connected nicely.  I'm suspecting a possibly faulty GPU.
uninstal the kraken and try the game, see what happens.
Everything is connected properly and could it be because I had a faulty psu I just got a replacement psu I didn't use my computer once I found out my power supply was bad
