I’m having trouble with the darktable benchmark from the Phoronix Test Suite (on Arch). When I run it it says the test failed to produce a result. When I run it with the debug-run
command the log looks like the test is running fine. Any help would be appreciated!
0.366220 [dev] took 0.177 secs (0.183 CPU) to load the image.
0.431598 [export] creating pixelpipe took 0.065 secs (0.078 CPU)
0.446569 [dev_pixelpipe] took 0.015 secs (0.031 CPU) initing base buffer [export]
0.457912 [dev_pixelpipe] took 0.011 secs (0.091 CPU) processed ‘raw black/white point’ on CPU, blended on CPU [export]
0.466830 [dev_pixelpipe] took 0.009 secs (0.044 CPU) processed ‘white balance’ on CPU, blended on CPU [export]
0.599797 [dev_pixelpipe] took 0.133 secs (1.056 CPU) processed ‘highlight reconstruction’ on CPU, blended on CPU [export]
0.860072 [dev_pixelpipe] took 0.260 secs (1.980 CPU) processed ‘demosaic’ on CPU, blended on CPU [export]
1.451531 [dev_pixelpipe] took 0.591 secs (3.492 CPU) processed ‘tone mapping’ on CPU, blended on CPU [export]
2.353842 [dev_pixelpipe] took 0.902 secs (6.361 CPU) processed ‘lens correction’ on CPU, blended on CPU [export]
2.400607 [dev_pixelpipe] took 0.047 secs (0.354 CPU) processed ‘base curve’ on CPU, blended on CPU [export]
2.431544 [dev_pixelpipe] took 0.031 secs (0.255 CPU) processed ‘input color profile’ on CPU, blended on CPU [export]
2.590726 [dev_pixelpipe] took 0.159 secs (1.252 CPU) processed ‘color reconstruction’ on CPU, blended on CPU [export]
18.134389 [dev_pixelpipe] took 15.544 secs (123.048 CPU) processed ‘denoise (non-local means)’ on CPU, blended on CPU [export]
18.564112 [dev_pixelpipe] took 0.430 secs (3.148 CPU) processed ‘global tonemap’ on CPU, blended on CPU [export]
19.096374 [dev_pixelpipe] took 0.532 secs (4.050 CPU) processed ‘shadows and highlights’ on CPU, blended on CPU [export]
21.994451 [dev_pixelpipe] took 2.898 secs (21.712 CPU) processed ‘equalizer’ on CPU, blended on CPU [export]
22.289351 [dev_pixelpipe] took 0.295 secs (2.342 CPU) processed ‘local contrast’ on CPU, blended on CPU [export]
22.490078 [dev_pixelpipe] took 0.201 secs (1.564 CPU) processed ‘color zones’ on CPU, blended on CPU [export]
22.537165 [dev_pixelpipe] took 0.047 secs (0.359 CPU) processed ‘levels’ on CPU, blended on CPU [export]
22.646738 [dev_pixelpipe] took 0.110 secs (0.810 CPU) processed ‘sharpen’ on CPU, blended on CPU [export]
22.677809 [dev_pixelpipe] took 0.031 secs (0.259 CPU) processed ‘color contrast’ on CPU, blended on CPU [export]
22.755685 [dev_pixelpipe] took 0.078 secs (0.608 CPU) processed ‘output color profile’ on CPU, blended on CPU [export]
22.779137 [dev_pixelpipe] took 0.023 secs (0.179 CPU) processed ‘gamma’ on CPU, blended on CPU [export]
22.779161 [dev_process_export] pixel pipeline processing took 22.348 secs (172.994 CPU)
[export_job] exported to ‘output.jpg’
