Help with my asrock x760 and 9700x build
Hey guys . I have been touble shooting for now 2 days.
-ASRock X870 STEEL LEGEND WIFI AM5 AMD X870 SATA 6Gb/s ATX Motherboard
-amd 7 9700x
-CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6400
-MSI Gaming GeForce RTX 5070 Ti
-samsung 990pro pci4.0 nvme m.2 ssd
I have tried it pretty much all . I tried to boot up a mother board with everything off but one stick of ram,cpu and nothing works.
My first mistake was trying to boot up with my old pcs ssd and now with the new drive it still having the samw problem.
I have tried updating the bios
And downgrading it
Tried to reset the settings with the two pins and unplug plus removing the battery.
So prrtty much what happens is i switching the power supply on. Wait 5 mins . Then turn on the pc. Red indication light turns on and the yellow one turns off and on about 3 times and the pc turns itself off
Red led generally means that there is a cpu initialization error.
i would suggest to reseat the cpu and check the socket for bend pins or damage.
