Good day everyone. I purchased a EKWB water-cooling kit a few years ago (Linked below). It contained a EK-Supremacy EVO. So my predicament is that I bought a i9 12900k and I would like to reuse this if it is possible but I don’t know if it would be compatible. I saw a reddit thread (linked below) stating that all I need is the LGA 1700 bracket for the motherboard I purchased and it should work but there was not any for sure confirmation that it does.
I would like to know if it would just be better to purchase a water-block made for the i9 12900k?
Also if I were to purchase one would I be able to reuse the fittings from the supremacy EVO for the tubing? or I would need to buy new everything.
The whole cooling unit is in really good condition so I don’t want to repurchase an entire unit again. If it is also possible can anyone link some suggestions from EK for a water-block?
I’ve read and saw a few videos saying that you are not supposed to mix metal because it cause corrosion or leaks something like that so I just want to make sure that everything recommended won’t cause any problems in the long run. Thanks for all the help in advance!
