Help with adding SAS drives to TrueNas Scale
Hey All,
I have a pool in truenas scale that is just a single 10tb sata drive that I use for media. It’s just about full, so I’m looking to add in another drive. I’m thinking about investing in a SAS controller to be able to use cheaper SAS drives, but I have a couple questions and my google-fu is failing me so far.
  1. Would I be able to add a 10tb SAS drive to the existing pool with the 10tb sata drive?
  2. In the future (if HDD prices drop again) if I want to add more drives to the pool for redundancy, would the mix of Sata and SAS become a problem?
  3. Should both the Sata and SAS drive be connected to the SAS controller, or am I fine leaving the sata drive connected to the motherboard?
Side Note, I came here looking to create an account to participate in the forums, only to find out I already joined back in 2015! Great to see this place is more active than ever :grinning_face_with_smiling_eyes:
  1. yes (assuming you’re ok with striping them (0 redundancy))
  2. no
  3. doesn’t matter
Good to know. Thanks!
You can add it as a mirror as well. (although this obviously wont increase usable space).
in recent zfs they added the ability to add drives to an existing raidz too. But afaik you cannot convert from single or mirror/stripe to raidz so this is more of a future thing.
