So I'm building a PC here are specs
Intel Core i7 5820k 6-core @3.3GhZ
Corsair H100i
Asrock x99 Extreme4 Motherboard
32 GB GSKILL DDR4 RAM F4-2133C15Q-32GRR
Samsung 850 Evo 250GB SSD
HGST 2TB Internal Hard Drive
1TB External Drive
Gigabyte GeForce 980ti 6GB GDDR5
EVGA 750w Power Supply
Rosewill RISE case
And I'm having some serious issues I can't seem to figure out.
Lets start:
This is the second 980ti I'm trying. I can't get anything out of the POST, nothing appears on-screen. The mobo has no iGPU so I can't verify there, but when I remove RAM, I get the 'missing RAM' beep code. So I'm guessing it isn't that, but I have no way to verify without an additional DDR4 mobo. This is also the second set of RAM I'm trying.
Basically, I've checked:
All connectors
Proper seating of CPU, GPU, and RAM
A low end GPU (still nothing)
Cmos Reset
cmos clear
Additionally, both 980ti's didn't work in separate machines (an older amd 6core and i5) either, and won't even POST. I'm at a loss because I don't know what else to do, or what I could be missing.
This brand new 980ti I got today didn't work in the build, so I tried a different machine, which won't even power on. (FYI, this machine works fine otherwise, and currently houses a GTX Titan with no issues).
This is the third time receiving revised items from newegg, I want to add. First box was so water logged, I opened the 980ti box to find visible moisture on the inside. So I RMAed and got another set, that didn't work for either machine. Now, I'm on yet another set that seems to be having a similiar issue.
Any ideas? Any input would be appreciated, I would really like to figure out what's going on.
