Help Reviewing Script for Suspicious Code
Hello all, Im not versed AT ALLLL in coding and scripting. I’m trying to learn by writing a post processing script for my DVR recordings because they are HUGE files so I hoped to slim them down after recording. Instead of using the CPU to process the recording, I have a NVIDIA gpu so the hope is to utilize this card more to process the video file to a H.264 or H.265 HVEC.
I have a GTX 1650 Super in the machine that should be able to handle this easily. I know the GPU is set up correctly and recognized by plex (I have plex running in a Debian 11 LXC, on a proxmox system with the GPU passed through to it).
I hope to set up a location on my machine (IE a second drive or a SSD temp drive) to do the transcoding on.
Im hoping someone can review this code for possibly anything malicious… I looked it over and is seems straight forward. I just want to double check or see if anyone has experiance with this type of thing.
Thanks in advance…there is no pressure on this at all. The source can be seen HERE on github.
Here is the code-
Code
#!/bin/bash
# set -x
# transcode_internal.sh
#       Author: cedarrapidsboy
#     Contribs: nebhead (https://github.com/nebhead/PlexPostProc)
#      License: MIT License (https://spdx.org/licenses/MIT.html
#      Purpose: For use as a Plex DVR Postprocessing script. Converts captured
#               ATSC MPEG2/TS files into H264/MP4 or H264/MKV at lower
#               bitrates. Removes source file upon successful conversion.
# Requirements: Plex Server (1.19.3.2764 tested), Linux, Bash
#        Usage: transcode_internal.sh <file> (see README.md)
# CONSTANTS
# A standard location for the codecs (PMS docker image)
CONST_CODECS_01="/config/Library/Application Support/Plex Media Server/Codecs/"
# A standard location for the codecs (PMS linux package?)
CONST_CODECS_02="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/"
: "${TRANSCODE:="true"}"	# Perform transcode step, otherwise just copy
: "${COPYAUDIO:="false"}"	# Simply copy audio track, otherwise transcode
							#    audio to AAC
: "${COMCHAP:="false"}"		# Create chapter marks for commercials (leaves the
							#    commercials in -- non-destructive)
: "${AACRATE:="192"}"		# Kb/s for AAC audio (stereo DPLII downmix)
: "${PPSRATE:="0.000072"}" 	# WARNING: DO NOT CHANGE - USE VBRMULT INSTEAD
: "${VBRMULT:="1.0"}"      	# Adjusts average video bitrate ("2.0" == 2X)
: "${TMPFOLDER:="/tmp"}"	# In-process transcoded file
: "${PPFORMAT:="mp4"}"		# Output format <mkv|mp4> (source file will be
							#    remuxed to this format if any operations are
							#    performed)
: "${ONLYMPEG2:="false"}"	# Only transcode mpeg2video sources
: "${FFMPEGLIBS:=""}"	    # User-defined ffmpeg libs (codecs) folder
                            #    Contains (at any depth) libmpeg2video_decoder.so
                            #    I.e., /<...>/Plex Media Server/Codecs/
: "${LOGLEVEL:="1"}"        # Logging verbosity
                            #    (0=none, *1=STDOUT msgs, 2=STDOUT+STDERR)
# INITIALIZATION
ulimit -c 0					# Disable core dumps
FILENAME="${1}"				# %FILE% - Filename of original file
WORKINGFILE="$(mktemp ${TMPFOLDER}/working.XXXXXXXX.mkv)"
COMSKIP_CHAPTERS=""
UNIQUESTRING=$(head /dev/urandom | tr -dc A-Za-z0-9 | head -c 8)
LOGFILE="/dev/null"
ERRFILE="/dev/null"
if [ "${LOGLEVEL}" -gt "0" ]; then
	LOGFILE="/tmp/transcode.$(date +"%Y%m%d").log" # Create a daily log file.
fi
if [ "${LOGLEVEL}" -gt "1" ]; then
	ERRFILE="/tmp/transcode.$(date +"%Y%m%d").err" # Create a daily log file.
fi
touch "${LOGFILE}"			# Create the log file
touch "${ERRFILE}"			# Create the log file
AUDIOPARMS="-c:a aac -ac 2 -b:a ${AACRATE}k -filter:a aresample=matrix_encoding=dplii"
if [ "${COPYAUDIO}" == "true" ]; then
	AUDIOPARMS="-c:a copy"
fi
# FUNCTION check_errs
# Examine non-zero argument $1 and log the error $2. Remove temp file.
# Kills the script on non-zero $1. Otherwise GNDN.
check_errs()
   if [ "${1}" -ne "0" ]; then
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] ERROR: ${1} : ${2}" \
		   | tee -a "${LOGFILE}"
		rm -f "${WORKINGFILE}"
		exit ${1}
   fi
# SCRIPT START
echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Starting postprocessing for $FILENAME." \
		 | tee -a "${LOGFILE}" "${ERRFILE}"
# ".../Plex <executables>" require some custom FFMPEG libraries
# Exact path may change wrt release -- discover it
CODECs=""
if [ -n "$FFMPEGLIBS" ]; then
	CODECS="$(find "$FFMPEGLIBS" -name "libmpeg2video_decoder.so" -printf "%h\n")"
	check_errs $? "Failed to locate user-defined plex encoder libraries. libmpeg2video_decoder.so not found." \
		> >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
else
	CODECS="$(find "$CONST_CODECS_01" -name "libmpeg2video_decoder.so" -printf "%h\n")"
	if [ "$?" -ne "0" ]; then
		CODECS="$(find "$CONST_CODECS_02" -name "libmpeg2video_decoder.so" -printf "%h\n")"
		check_errs $? "Failed to locate plex encoder libraries. libmpeg2video_decoder.so not found." \
	fi
fi
export FFMPEG_EXTERNAL_LIBS="$CODECS/"
echo "INFO - FFMPEG_EXTERNAL_LIBS: $FFMPEG_EXTERNAL_LIBS" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
# Remux the source file into our working format
/usr/lib/plexmediaserver/Plex\ Transcoder -y -hide_banner -i "${FILENAME}" \
	-c:v copy -c:a copy -c:s copy -c:d copy -c:t copy "${WORKINGFILE}" \
check_errs $? "Failed to remux ${FILENAME}."
WORKSIZE=$(stat -c%s "${WORKINGFILE}")
if [[ "${TRANSCODE}" == "true" ]]; then
   # Grab some dimension and framerate info so we can set bitrates
   # Runtime: <1s
   DIM="$(/usr/lib/plexmediaserver/Plex\ Transcoder -i "${WORKINGFILE}" 2>&1 \
		| grep "Stream #0:0" \
		| perl -lane 'print "$1 $2 $3" if /Video: (\w+).*, (\d{3,})x(\d{3,})/' \
		 > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2))"
   ISMPEG2=$(echo ${DIM} | perl -lane 'print $F[0] if $F[0] eq "mpeg2video"')
   HEIGHT=$(echo ${DIM} | perl -lane 'print $F[2]')
   WIDTH=$(echo ${DIM} | perl -lane 'print $F[1]')
   FPS="$(/usr/lib/plexmediaserver/Plex\ Transcoder -i "${WORKINGFILE}" 2>&1 \
		| perl -lane 'print $1 if /, (\d+(.\d+)*) fps/' \
   ALLOK="true"
   if [[ -z $ISMPEG2 && "${ONLYMPEG2}" == "true" ]]; then
		# Input video is not MPEG2 and the env variable is set to only encode MPEG2
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Transcode skipped. Source video codec is not MPEG2 and ONLYMPEG2 is defined." \
		ALLOK="false"
   fi
   if [[ -z $WIDTH || -z $HEIGHT || -z $FPS ]]; then
	 echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] ERROR: transcode_internal.sh : Transcode canceled. Unable to determine input video dimensions." \
		ALLOK="false"
   fi
   if [[ "${ALLOK}" == "true" ]]; then
		# Analyze input video and grab the FFMPEG deinterlace string (or "")
		# Runtime: Just a few seconds (1000 frames analyzed)
		# DEINT      = "" (progressive) or "-vf yadif=0:0:0" or "-vf yadif=0:1:0"
		# DEINT_CUDA = <same as DEINT with string substitution to use yadif_cuda>
		DEINT="$(/usr/lib/plexmediaserver/Plex\ Transcoder -i "${WORKINGFILE}" \
		-filter:v idet -frames:v 1000 -an -f h264 -y /dev/null 2>&1 \
		| grep "Multi frame detection:" \
		| perl -lane 'if (/TFF:\s+(\d+)\s+BFF:\s+(\d+)\s+Progressive:\s+(\d+)/){print "-vf yadif=0:0:0" if ($1>$2 && $1>$3);print "-vf yadif=0:1:0" if ($2>$1 && $2>$3);print "" if ($3>$1 && $3>$2);}' \
		HWYADIF="hwupload_cuda,yadif_cuda"
		DEINT_CUDA="${DEINT/yadif/$HWYADIF}"
		# Calculate average bitrate based on frame size and frame rate
		BITRATE="$( echo ${WIDTH} ${HEIGHT} ${FPS} ${PPSRATE} ${VBRMULT} \
		| perl -lane 'print int($F[0]*$F[1]*$F[2]*$F[3]*$F[4]+0.5);')"
		BITMAX="$(echo ${BITRATE} | perl -lane 'print ($F[0]*2)')"
		BUFFER="$(echo ${BITRATE} | perl -lane 'print ($F[0]*3)')"
		echo "INFO -           Dimensions: ${WIDTH} x ${HEIGHT}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		echo "INFO -            Framerate: ${FPS}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		echo "INFO -  De-interlace filter: \"${DEINT}\"" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		echo "INFO -   Calculated bitrate: ${BITRATE}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		echo "INFO -     Max bitrate (2x): ${BITMAX}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		echo "INFO - Encoding buffer (3x): ${BUFFER}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		# Transcode input video into a more efficient format
		# Video Codec: H264_NVEC (preferred) or H264
		# Audio Codec: AAC (stereo DPLII downmix)
		# File Format: MKV
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Video and audio transcoding starting." \
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] DEBUG: transcode_internal.sh : $FILENAME;$ISMPEG2;$WIDTH;$HEIGHT;$FPS;$DEINT;$BITRATE;$BITMAX;$BUFFER." \
		TEMPFILENAME="$(mktemp ${TMPFOLDER}/transcode.XXXXXXXX.mkv)"  # Temporary File Name for transcoding
		/usr/lib/plexmediaserver/Plex\ Transcoder -y -hide_banner \
		-hwaccel nvdec -i "${WORKINGFILE}" \
		-c:v h264_nvenc -b:v ${BITRATE}k -maxrate:v ${BITMAX}k -profile:v high \
		-bf:v 3 -bufsize:v ${BUFFER}k -preset:v hq -forced-idr:v 1 ${DEINT_CUDA} \
		${AUDIOPARMS} \
		"${TEMPFILENAME}" > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
		ERRCODE=$?
		if [[ "${ERRCODE}" -ne "0" ]]; then
		# For numerous reasons, NVDEC/NVENC may fail. Try pure SW encoding.
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] WARNING: ${ERRCODE} : transcode_internal.sh : Fail-over to libx264." \
		 -c:v libx264 -b:v ${BITRATE}k -maxrate:v ${BITMAX}k -profile:v high \
		 -bf:v 3 -bufsize:v ${BUFFER}k -preset:v veryfast -forced-idr:v 1 ${DEINT} \
		 ${AUDIOPARMS} \
		ERRCODE=$?
			echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] ERROR: ${ERRCODE} : transcode_internal.sh : Transcode failed." \
			rm -f "${TEMPFILENAME}"
		else
			echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Transcoding complete. ${TEMPFILENAME} created." \
		fi
		else
		fi
		# Rename temporary MKV file
		# Remove original file
		if [[ -f "${TEMPFILENAME}" ]]; then
		mv -f "${TEMPFILENAME}" "${WORKINGFILE}"
		fi
   fi
fi
# Find commercials and generate chapter marks.
# Does not transcode but will remux TS source files into MKV.
# Deletes original file.
# INPUT: an MKV file
# OUTPUT: a chapter file
if [[ "${COMCHAP}" == "true" ]]; then
   # COMSKIP STUFF HERE
	echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Commercial detection and chapter insertion starting." \
		| tee -a "${LOGFILE}"
   COMSKIP_ORG="$(find /usr/lib/plexmediaserver/ -name "comskip.ini")"
   COMSKIP_PRE="$(head /dev/urandom | tr -dc A-Za-z0-9 | head -c 13)"
   COMSKIP_TMP="${TMPFOLDER}/${COMSKIP_PRE}.comskip.ini"
   COMSKIP_OUT="${TMPFOLDER}/${COMSKIP_PRE}.commerge.mkv"
   cp "${COMSKIP_ORG}" "${COMSKIP_TMP}"
   echo output_ffmeta=1 >> "${COMSKIP_TMP}"
   /usr/lib/plexmediaserver/Plex\ Commercial\ Skipper --ini "${COMSKIP_TMP}" --output="${TMPFOLDER}" \
		--output-filename="${COMSKIP_PRE}.comskip" -q "${WORKINGFILE}" "${TMPFOLDER}" \
   COMSKIP_ERR=$?
   if [[ "${COMSKIP_ERR}" -ne "0" ]]; then
		# For numerous reasons, comskip may fail.
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] WARN: ${COMSKIP_ERR} : transcode_internal.sh : Comskip failed to generate chapters." \
   elif [[ -f "${TMPFOLDER}/${COMSKIP_PRE}.comskip.ffmeta" ]]; then
	 COMSKIP_CHAPTERS="${TMPFOLDER}/${COMSKIP_PRE}.comskip.ffmeta"
   else
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] WARN: ${COMSKIP_ERR} : transcode_internal.sh : Comskip output was empty." \
   fi
fi
# REMUX the working file into the desired format
if [[ "${COMSKIP_CHAPTERS}" != "" || "$(stat -c%s "${WORKINGFILE}")" -ne "${WORKSIZE}" ]]; then
   TEMPFILENAME="$(mktemp ${TMPFOLDER}/transcode.XXXXXXXX.${PPFORMAT})"  # Temporary File Name for transcoding
   echo TEMPFILENAME=$TEMPFILENAME
   echo WORKINGFILE=$WORKINGFILE
   if [[ "${COMSKIP_CHAPTERS}" != "" ]]; then
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Muxing $WORKINGFILE and $COMSKIP_CHAPTERS into $TEMPFILENAME." \
		 | tee -a "${LOGFILE}"
		echo COMSKIP_CHAPTERS=$COMSKIP_CHAPTERS
		# remux the working file into the desired container -- chance to fail w/ mp4
		#    due to limitations of the container
		   -i "$WORKINGFILE" -i "$COMSKIP_CHAPTERS" \
		 -c:v copy -c:a copy -c:s copy -c:d copy -c:t copy \
		   "$TEMPFILENAME"  > >(tee -a "${LOGFILE}") 2> >(tee -a "${ERRFILE}" >&2)
   else
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Remuxing $WORKINGFILE into $TEMPFILENAME." \
		 | tee -a "${LOGFILE}"
		   -i "$WORKINGFILE" \
   fi
   ERRCODE=$?
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] ERROR: ${ERRCODE} : transcode_internal.sh : Unable to remux working file." \
		| tee -a "${LOGFILE}"
   else
		NEWFILENAME="${FILENAME%.*}.${PPFORMAT}"
		mv -f "${TEMPFILENAME}" "${NEWFILENAME}"
		echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Moved $TEMPFILENAME to $NEWFILENAME." \
		 | tee -a "${LOGFILE}"
		if [[ "${FILENAME}" != "${NEWFILENAME}" ]]; then
		   rm -f "${FILENAME}"
		 echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Original file format not wanted. Removed ${FILENAME}." \
			| tee -a "${LOGFILE}"
		fi
   fi
   echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Postprocessing completed. Removed ${TEMPFILENAME}." \
		| tee -a "${LOGFILE}"
else
   echo "$(date +"%Y%m%d-%H%M%S") [${UNIQUESTRING}] INFO: transcode_internal.sh : Postprocessing completed. No work done. Removed ${WORKINGFILE}." \
		| tee -a "${LOGFILE}"
fi
rm -f "${TMPFOLDER}/${COMSKIP_PRE}.comskip"*
exit 0
# SCRIPT DONE.
This is a very old script. I’m not sure I need comskip.ini because I think it is a part of Plex now… Im not too sure or if Ill need to rely on comskip because I’m running a script vs letting Plex handle it.
Looks fine to me. It’s mostly a bunch of what look like ffmpeg commands using perl, grep, tee and a few other things to filter and prepare the output.
And yeah there’s that bit about comskip also. IIRC, the tricky part about comskip was tuning all its parameters so that it would correctly find the commercial breaks, but maybe Plex has done that already, or like you say they’ve got something else entirely. It was a number of years ago that I last messed with it.
Thanks so much.
Yeah I looked to see what’s going on more recently… but the most recent was close to 4 years ago when DVR was still beta.
Plex has options for commercial detection and removal built in now that does fairly well in my opinion, I havent missed a secion of a show ever, and may get one commercial per recording… Maybe one… So I’m happy with that. My goal is to just shrink the file. I may have to add a few things like pearl etc to the LXC then to make it work.
I may spin up a VM or LXC to test this to see if it works on the same machine. I should be able to clone the LXC without issue for testing.
Again thanks for the time to review it for me just to be safe :slight_smile:
Yeah I dunno if perl is a dependency of Plex or not. You could just do a perl --version from the shell to see if it’s installed, and then grab it from your package repo if not.
I think @Argone has done similar things with transcoding to shrink file sizes also.
My setup is a little less automated I have my devices labeled as 1transcode and 2transcode and so forth and Completed Transcode Folders. I manually move the files to the transcode folder to be transcoded and then run ./handbrake.sh. Outputs the transcoded file to completed and then i delete the original file.
I use handbrakecli which utilizes ffmpeg. I do cpu encodes as they result in smaller files while retaining better quality than nvenc encodes. Nvenc is faster and results in larger files for the same quality output.
#!/bin/bash
cd "/home/argone/mnt/plexmedia/work 1/1Transcode"
for name in *.mkv;
do HandBrakeCLI -i "$name" -o "/home/argone/mnt/plexmedia/work 1/1Completed/${name%.*}.mkv" --crop="0:0:0:0" --non-anamorphic -e x265 --encoder-preset medium --cfr -q 18 --audio-lang-list eng --all-audio -E copy -s 1 --srt-default --ssa-default
done
Here are command line parameters and documentation for handbrakecli.
Depending on what is being transcoded I have multiple files i can run. i.e. animated stuff is set to animation preset and 10bit output.
Yeah I was hoping to automate it.
I found a few scripts that utilize handbrake, I may look into them. I belive they are newer and dont utilize their own comskip, just process the file and delete the old version and send it on its way to the hdd location.
Appreciate the feed back I may try that for a number of shows I have in my library already to shrink them down. I guess I was hoping newer HVEC might get me smaller files that are as good.
FYI, if you use a 10bit panel and notice banding with transcodes, You can transcode to 10bit which usually takes care of the banding. Atleast for animation content.
Awesome !!!, Hi,
Since you’re new, install pre-commit. And add things like shellcheck to your .pre-commit-config.yaml, and add reuse there as well.
This will prevent you from checking in broken shell scripts or questionably licenses files.
There’s probably a shell formatter somewhere, that’ll reformat your she’ll code to keep it consistent.
I like my shell scripts like my code, to fail fully and quit on first error.
I’m also not a bash expert nor enthusiast, but I stick to bash since that’s the one I know best, use set -eu ; set -o pipefail… and consider splitting some of that stuff into functions.
