Hello everyone,
TL;DR: Custom CPU ratio, FID and DID are gone after updating my BIOS unless I’m messing something and I don’t remember the previous BIOS version.
Long Version:
So I wanted OC my PC further than I had it before because it was a basic manual overclock of 3.7 GHz @ 1.3 volts and it’s been like this for a couple of years and since I have nothing else to do in these trying times i thought it’s the right time to do so but I updated my bios and now I don’t see the more advanced option of (custom CPU ratio with DID and FID options).
SPECS:
MOBO: ASUS x370 Crosshair VI
CPU: Ryzen 1700
GPU: GTX 1080ti ftw3
RAM: G.SKILL TridentZ RGB Series 32GB Model F4-3200C14Q-32GTZR
These Are My Current Settings:
These are the Options available and I tried everything but I can’t unlock the custom CPU ratio with DID and FID options (maybe ASUS is turning this feature to A DLC like every fking major game publisher or Dev : )
I also checked the Pstate option in the advanced category and there is no sign of the Custom CPU ratio options
