HELP OC MY aorus b450m with a 2600x at 4.10ghz
Im currently running my Aorus b450m with a 2600x an have recently OC’ED from 3.8 to 4.10ghz with a dynamic vcore offset at +.245 an dynamic soc at auto is that too much or too little ?
an wither or not it is on my linux pc what the best cpu benchmark test to run to check stability my current one i use is s-tui an is ther a way to set the stress options to get best result ?
.245 can be pretty high. I would check and see what the highest reported voltage is with whatever software you are using to monitor it.
On Linux I would check out y-cruncher & Geekbench.
how do i get an install y-cruncher
http://numberworld.org/y-cruncher/
thanks
You’re welcome!
