there is a python script u can use talked about here so just a general tool… i’d deff ask in the popchat unless someone else can suggest here for u…
Though if you just want a quick way to (not for login but authentication) not have to deal with a password every time (especially if you have mint lol) then this might be a easier option:
these are just suggestions, others will offer better ones and always check thoroughly before doing anything i suggest because i am very much a newbie still!
Not sure what model the reader is in the Flex 5 but I know the one in the Ideapad line doesn’t have kernel support, only some of the Thinkpad/Carbon are supported.
