Help needed-info & advice on filament & nozzles an accessories
help needed-info & advice on filament & nozzles an accessories
i recently bought a Longer LK5 Pro 3 3D Printer but yet to get any filament & nozzles,etc
an need advice on want extras to get
i want to get some alt nozzle options from the lk5’s default .4mm like .6mm, .8mm & .25mm
for fine detail an design printing , are ther such alt brand options the are compatible with the lk5 & what are they if i can can someone give me a rec from amazon?
also whats the best cheapest petg , i wanted to start with ELEGOO PETG Filament ?
2 questions about petg & pla
1 does either type print to a smooth finish & can it be sanded ?
2 is ther a diff in using petg vs pla with diff nozzle sizes an or curtain prints
( as in which is better for larger solid prints vs smaller thinner pc mods such as fan & radiator mods ? )
are the any other brand optional printer sheets like this PEI Powder-Coated Platform that i can or should use with the lk5
an is the a alt brand vented printer enclosure that i can or should use with my lk5 or is its
default adequate
