till recently corectrl worked with my 6700xt an gave fine tuning over
voltage , core clock , memory clock an max power sliders
so i need help fixing corectrl an pp_od_clk_voltage functions
iv tried all 4 of these
sudo kernelstub -a amdgpu.ppfeaturemask=0xffffffff
sudo kernelstub -a amdgpu.ppfeaturemask=0xfffd7fff
sudo kernelstub -a amdgpu.ppfeaturemask=0xfffd3fff
sudo kernelstub -a amdgpu.ppfeaturemask=0xfff7bfff
along with this
sudo update-initramfs -u
sudo grub-mkconfig -o /boot/grub/grub.cfg
this is how both grub files now look an i tried all 4 mask versions an still no re-generation of pp_od_clk_voltage file which it did have before it broke
how do i fix this to gain fine grain control of my 6700xt vi the corectrl app
as of right now the max power slider stops at 185 instead of 215 which it did before running the one with 0xffffffff
after neither of the 4 versions seem to have any effect now an the pp_od_clk_voltage file seem to be missing
it was to start located at /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0
an i did find it after running readlink -f /sys/class/drm/card0/device but after
an update an reboot its gone an wont seem to come back so now what do i do
an now corectrl no longer shows voltage control an the core clock an mem slider
dont do fine tuning they just pop either straight to the top or bottom how can i fix all this
before when it worked right
after update
