If you’re not sure if your computer is on or off, you can go to ismycomputeron.com and it will tell you.
Have you tried turning it on and off again?
I’d rather it not turn on and than randomly turn itself on, like it did last night. I always put my PC in sleep for the night. Last night after about 30mins it just randomly turned itself back on. I looked at it and assumed Windows Update had woke it up, but that’s disabled, I manually update. I have no clue.
