Hello, first time poster.
Today I think my gpu has died while I was playing CSGO for linux. It suddenly displayed artifacts on screen and then froze inmediately after. After pressing the reset button, I noticed that the BIOS had glitches as well.
This definitely elevated the worry-meter to max. I've had freezing in the past, but I attributed it to a bad seating of the gpu on the pcie slot because after a reinsertion it worked fine. I also tried reinsertion but the current issue is dire, specially after seeing the NVRM errors.
To give a bit of a back story, the same day it happened I was trying to get gpu passthrough working. I had uninstalled the proprietary drivers. Tried to run csgo but that didnt work on nouveau drivers. After doing that I was invited by some friends to play, so I did a quick reinstall and ran the game. I was warming up on a DM server, but after 5 mins of playing, it froze as stated before.
I am attaching dmesg and xorg logs that might become handy for diagnostics.
Luckly I had installed ssh server the same day in anticipation of finding myself with a videoless boot. The original driver I had installed was the 375, then I tried out the one available on the ppa, 378, to no avail.
Can anyone help? I am going to install windows on a spare hdd and try it. I think this whole thing came about because of a clash of drivers and left the card in some funky state, though the persistance of the issue after resets/shutdowns has me believing it may be permanent damage.
dmesg
[ 0.000000] microcode: microcode updated early to revision 0x1e, date = 2015-08-13
[ 0.000000] Linux version 4.8.0-51-generic (buildd@lcy01-09) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #54~16.04.1-Ubuntu SMP Wed Apr 26 16:00:28 UTC 2017 (Ubuntu 4.8.0-51.54~16.04.1-generic 4.8.17)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-51-generic root=UUID=a454cb17-35a4-4d67-9588-162c5c5da7ba ro nomodeset
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000c78bafff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c78bb000-0x00000000c78c1fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000c78c2000-0x00000000c7d1bfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c7d1c000-0x00000000c817ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c8180000-0x00000000dd63afff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dd63b000-0x00000000dd843fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dd844000-0x00000000dd85cfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000dd85d000-0x00000000ddd9bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ddd9c000-0x00000000deffefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000defff000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: ASUS All Series/MAXIMUS VI IMPACT, BIOS 1603 08/15/2014
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7C00000000 write-back
[ 0.000000] 1 base 0400000000 mask 7FF0000000 write-back
[ 0.000000] 2 base 0410000000 mask 7FF8000000 write-back
[ 0.000000] 3 base 0418000000 mask 7FFC000000 write-back
[ 0.000000] 4 base 041C000000 mask 7FFE000000 write-back
[ 0.000000] 5 base 041E000000 mask 7FFF000000 write-back
[ 0.000000] 6 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] total RAM covered: 16368M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 32M num_reg: 7 lose cover RAM: 0G
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd750-0x000fd75f] mapped at [ffff8d8e000fd750]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff8d8e00097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x31923b000, 0x31923bfff] PGTABLE
[ 0.000000] BRK [0x31923c000, 0x31923cfff] PGTABLE
[ 0.000000] BRK [0x31923d000, 0x31923dfff] PGTABLE
[ 0.000000] BRK [0x31923e000, 0x31923efff] PGTABLE
[ 0.000000] BRK [0x31923f000, 0x31923ffff] PGTABLE
[ 0.000000] BRK [0x319240000, 0x319240fff] PGTABLE
[ 0.000000] BRK [0x319241000, 0x319241fff] PGTABLE
[ 0.000000] BRK [0x319242000, 0x319242fff] PGTABLE
[ 0.000000] BRK [0x319243000, 0x319243fff] PGTABLE
[ 0.000000] BRK [0x319244000, 0x319244fff] PGTABLE
[ 0.000000] BRK [0x319245000, 0x319245fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x33256000-0x35922fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DD849088 000084 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DD857528 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000DD8491A0 00E383 (v02 ALASKA A M I 00000031 INTL 20091112)
[ 0.000000] ACPI: FACS 0x00000000DDD9A080 000040
[ 0.000000] ACPI: APIC 0x00000000DD857638 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DD8576D0 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: LPIT 0x00000000DD857718 00005C (v01 ALASKA A M I 00000000 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DD857778 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20091112)
[ 0.000000] ACPI: SSDT 0x00000000DD857CB8 000AD8 (v01 PmRef CpuPm 00003000 INTL 20091112)
[ 0.000000] ACPI: SSDT 0x00000000DD858790 0001C7 (v01 PmRef LakeTiny 00003000 INTL 20091112)
[ 0.000000] ACPI: MCFG 0x00000000DD858958 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000DD858998 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DD8589D0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT 0x00000000DD858D40 0034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: DMAR 0x00000000DD85C280 000080 (v01 INTEL HSW 00000001 INTL 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x41effb000-0x41effffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000c78bafff]
[ 0.000000] node 0: [mem 0x00000000c78c2000-0x00000000c7d1bfff]
[ 0.000000] node 0: [mem 0x00000000c8180000-0x00000000dd63afff]
[ 0.000000] node 0: [mem 0x00000000defff000-0x00000000deffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[ 0.000000] On node 0 totalpages: 4178285
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14088 pages used for memmap
[ 0.000000] DMA32 zone: 901585 pages, LIFO batch:31
[ 0.000000] Normal zone: 51136 pages used for memmap
[ 0.000000] Normal zone: 3272704 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc78bb000-0xc78c1fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc7d1c000-0xc817ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdd63b000-0xdd843fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdd844000-0xdd85cfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdd85d000-0xddd9bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xddd9c000-0xdeffefff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdf000000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xdf000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] percpu: Embedded 36 pages/cpu @ffff8d921ec00000 s107864 r8192 d31400 u262144
[ 0.000000] pcpu-alloc: s107864 r8192 d31400 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 4112976
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-51-generic root=UUID=a454cb17-35a4-4d67-9588-162c5c5da7ba ro nomodeset
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 16324988K/16713140K available (8829K kernel code, 1441K rwdata, 3836K rodata, 1548K init, 1296K bss, 388152K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:33024 nr_irqs:488 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3991.050 MHz processor
[ 0.000015] Calibrating delay loop (skipped), value calculated using timer frequency.. 7982.10 BogoMIPS (lpj=15964200)
[ 0.000019] pid_max: default: 32768 minimum: 301
[ 0.000026] ACPI: Core revision 20160422
[ 0.006942] ACPI: 6 ACPI AML tables successfully acquired and loaded
[ 0.006969] Security Framework initialized
[ 0.006971] Yama: becoming mindful.
[ 0.006982] AppArmor: AppArmor initialized
[ 0.007423] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.009400] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.010301] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.010311] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.010514] CPU: Physical Processor ID: 0
[ 0.010516] CPU: Processor Core ID: 0
[ 0.010520] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.010522] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.010526] mce: CPU supports 9 MCE banks
[ 0.010533] CPU0: Thermal monitoring enabled (TM1)
[ 0.010544] process: using mwait in idle threads
[ 0.010548] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.010549] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.010974] Freeing SMP alternatives memory: 32K (ffffffff8daed000 - ffffffff8daf5000)
[ 0.016399] ftrace: allocating 33453 entries in 131 pages
[ 0.025470] smpboot: APIC(0) Converting physical 0 to logical package 0
[ 0.025472] smpboot: Max logical packages: 2
[ 0.025476] DMAR: Host address width 39
[ 0.025478] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.025484] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
[ 0.025487] DMAR: RMRR base: 0x000000dd7cb000 end: 0x000000dd7d7fff
[ 0.025490] DMAR-IR: IOAPIC id 8 under DRHD base 0xfed90000 IOMMU 0
[ 0.025492] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.025493] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.025627] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.025629] x2apic enabled
[ 0.025634] Switched APIC routing to cluster x2apic.
[ 0.026009] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.065695] TSC deadline timer enabled
[ 0.065696] smpboot: CPU0: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[ 0.065701] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.065727] ... version: 3
[ 0.065728] ... bit width: 48
[ 0.065730] ... generic registers: 4
[ 0.065731] ... value mask: 0000ffffffffffff
[ 0.065733] ... max period: 00007fffffffffff
[ 0.065734] ... fixed-purpose events: 3
[ 0.065736] ... event mask: 000000070000000f
[ 0.066258] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.066303] x86: Booting SMP configuration:
[ 0.066305] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.085002] x86: Booted up 1 node, 8 CPUs
[ 0.085008] smpboot: Total of 8 processors activated (63856.80 BogoMIPS)
[ 0.091239] devtmpfs: initialized
[ 0.091276] x86/mm: Memory block size: 128MB
[ 0.092884] evm: security.selinux
[ 0.092885] evm: security.SMACK64
[ 0.092887] evm: security.SMACK64EXEC
[ 0.092888] evm: security.SMACK64TRANSMUTE
[ 0.092890] evm: security.SMACK64MMAP
[ 0.092891] evm: security.ima
[ 0.092893] evm: security.capability
[ 0.092922] PM: Registering ACPI NVS region [mem 0xc78bb000-0xc78c1fff] (28672 bytes)
[ 0.092926] PM: Registering ACPI NVS region [mem 0xdd85d000-0xddd9bfff] (5500928 bytes)
[ 0.093005] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.093034] pinctrl core: initialized pinctrl subsystem
[ 0.093101] RTC time: 2:15:26, date: 05/07/17
[ 0.093154] NET: Registered protocol family 16
[ 0.106896] cpuidle: using governor ladder
[ 0.122900] cpuidle: using governor menu
[ 0.122902] PCCT header not found.
[ 0.122918] ACPI: bus type PCI registered
[ 0.122920] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.122953] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.122956] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.122963] PCI: Using configuration type 1 for base access
[ 0.122998] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.138956] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.138959] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.139080] ACPI: Added _OSI(Module Device)
[ 0.139082] ACPI: Added _OSI(Processor Device)
[ 0.139083] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.139085] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.139203] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.141602] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.142076] ACPI: Dynamic OEM Table Load:
[ 0.142081] ACPI: SSDT 0xFFFF8D920BD67800 0005AA (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.143161] ACPI : EC: EC started
[ 0.143177] ACPI: Interpreter enabled
[ 0.143195] ACPI: (supports S0 S3 S4 S5)
[ 0.143197] ACPI: Using IOAPIC for interrupt routing
[ 0.143212] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.147678] ACPI: Power Resource [FN00] (off)
[ 0.147722] ACPI: Power Resource [FN01] (off)
[ 0.147763] ACPI: Power Resource [FN02] (off)
[ 0.147803] ACPI: Power Resource [FN03] (off)
[ 0.147845] ACPI: Power Resource [FN04] (off)
[ 0.148300] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.148305] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.148433] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[ 0.148504] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.148704] PCI host bridge to bus 0000:00
[ 0.148707] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.148709] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.148711] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.148714] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.148716] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.148719] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.148722] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.148724] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.148727] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.148730] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[ 0.148733] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.148738] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.148787] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[ 0.148808] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.148852] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.148890] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.148903] pci 0000:00:14.0: reg 0x10: [mem 0xf7120000-0xf712ffff 64bit]
[ 0.148949] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.148970] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.148993] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.149006] pci 0000:00:16.0: reg 0x10: [mem 0xf713b000-0xf713b00f 64bit]
[ 0.149055] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.149098] pci 0000:00:19.0: [8086:153b] type 00 class 0x020000
[ 0.149109] pci 0000:00:19.0: reg 0x10: [mem 0xf7100000-0xf711ffff]
[ 0.149114] pci 0000:00:19.0: reg 0x14: [mem 0xf7139000-0xf7139fff]
[ 0.149120] pci 0000:00:19.0: reg 0x18: [io 0xf040-0xf05f]
[ 0.149164] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.149186] pci 0000:00:19.0: System wakeup disabled by ACPI
[ 0.149208] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.149221] pci 0000:00:1a.0: reg 0x10: [mem 0xf7138000-0xf71383ff]
[ 0.149288] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.149317] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.149340] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.149352] pci 0000:00:1b.0: reg 0x10: [mem 0xf7130000-0xf7133fff 64bit]
[ 0.149405] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.149428] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.149448] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.149497] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.149536] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.149559] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[ 0.149607] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.149646] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.149671] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.149684] pci 0000:00:1d.0: reg 0x10: [mem 0xf7137000-0xf71373ff]
[ 0.149752] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.149782] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.149805] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100
[ 0.149924] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.149934] pci 0000:00:1f.2: reg 0x10: [io 0xf090-0xf097]
[ 0.149939] pci 0000:00:1f.2: reg 0x14: [io 0xf080-0xf083]
[ 0.149943] pci 0000:00:1f.2: reg 0x18: [io 0xf070-0xf077]
[ 0.149948] pci 0000:00:1f.2: reg 0x1c: [io 0xf060-0xf063]
[ 0.149953] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.149958] pci 0000:00:1f.2: reg 0x24: [mem 0xf7136000-0xf71367ff]
[ 0.149984] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.150019] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.150030] pci 0000:00:1f.3: reg 0x10: [mem 0xf7135000-0xf71350ff 64bit]
[ 0.150045] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.150116] pci 0000:01:00.0: [10de:1004] type 00 class 0x030000
[ 0.150124] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.150132] pci 0000:01:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
[ 0.150140] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.150145] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.150150] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.150198] pci 0000:01:00.0: System wakeup disabled by ACPI
[ 0.150221] pci 0000:01:00.1: [10de:0e1a] type 00 class 0x040300
[ 0.150229] pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.158919] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.158922] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.158923] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.158925] pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.158966] acpiphp: Slot [1] registered
[ 0.158970] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.159066] pci 0000:03:00.0: [14e4:43b1] type 00 class 0x028000
[ 0.159102] pci 0000:03:00.0: reg 0x10: [mem 0xf7400000-0xf7407fff 64bit]
[ 0.159126] pci 0000:03:00.0: reg 0x18: [mem 0xf7200000-0xf73fffff 64bit]
[ 0.159310] pci 0000:03:00.0: supports D1 D2
[ 0.159310] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.159371] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.170959] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.170964] pci 0000:00:1c.3: bridge window [mem 0xf7200000-0xf74fffff]
[ 0.171351] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.171381] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.171408] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 *6 7 10 11 12 14 15)
[ 0.171434] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.171460] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.171487] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.171513] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.171539] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.171714] ACPI: Enabled 5 GPEs in block 00 to 3F
[ 0.171730] ACPI : EC: EC stopped
[ 0.171741] ACPI : EC: GPE = 0x1e, I/O: command/status = 0x66, data = 0x62
[ 0.171742] ACPI : EC: EC started
[ 0.171856] SCSI subsystem initialized
[ 0.171875] libata version 3.00 loaded.
[ 0.171893] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.171895] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.171897] vgaarb: loaded
[ 0.171899] vgaarb: bridge control possible 0000:01:00.0
[ 0.171910] ACPI: bus type USB registered
[ 0.171919] usbcore: registered new interface driver usbfs
[ 0.171924] usbcore: registered new interface driver hub
[ 0.171935] usbcore: registered new device driver usb
[ 0.171985] PCI: Using ACPI for IRQ routing
[ 0.173264] PCI: pci_cache_line_size set to 64 bytes
[ 0.173325] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.173326] e820: reserve RAM buffer [mem 0xc78bb000-0xc7ffffff]
[ 0.173326] e820: reserve RAM buffer [mem 0xc7d1c000-0xc7ffffff]
[ 0.173327] e820: reserve RAM buffer [mem 0xdd63b000-0xdfffffff]
[ 0.173327] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.173328] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[ 0.173377] NetLabel: Initializing
[ 0.173379] NetLabel: domain hash size = 128
[ 0.173380] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.173389] NetLabel: unlabeled traffic allowed by default
[ 0.173434] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.173438] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.177856] clocksource: Switched to clocksource hpet
[ 0.182108] VFS: Disk quotas dquot_6.6.0
[ 0.182123] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.182179] AppArmor: AppArmor Filesystem Enabled
[ 0.182209] pnp: PnP ACPI init
[ 0.182264] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.182268] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.182419] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.182421] system 00:01: [io 0xffff] has been reserved
[ 0.182423] system 00:01: [io 0xffff] has been reserved
[ 0.182425] system 00:01: [io 0xffff] has been reserved
[ 0.182427] system 00:01: [io 0x1c00-0x1cfe] has been reserved
[ 0.182429] system 00:01: [io 0x1d00-0x1dfe] has been reserved
[ 0.182431] system 00:01: [io 0x1e00-0x1efe] has been reserved
[ 0.182433] system 00:01: [io 0x1f00-0x1ffe] has been reserved
[ 0.182435] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.182437] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.182439] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.182454] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.182479] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.182482] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.182529] system 00:04: [io 0x0290-0x029f] has been reserved
[ 0.182532] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.182558] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.182561] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.182737] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.182740] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.182742] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.182744] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.182746] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.182748] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.182750] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.182752] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.182754] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.182756] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.182758] system 00:06: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.182760] system 00:06: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.182762] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.182880] pnp: PnP ACPI: found 7 devices
[ 0.188235] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.188254] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.188257] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.188260] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.188262] pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.188267] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.188275] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.188279] pci 0000:00:1c.3: bridge window [mem 0xf7200000-0xf74fffff]
[ 0.188285] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.188286] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.188287] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.188287] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.188288] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.188288] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.188289] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.188290] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.188290] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[ 0.188291] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xfeafffff window]
[ 0.188291] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.188292] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.188292] pci_bus 0000:01: resource 2 [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.188293] pci_bus 0000:03: resource 1 [mem 0xf7200000-0xf74fffff]
[ 0.188309] NET: Registered protocol family 2
[ 0.188410] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.188532] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.188637] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.188653] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.188687] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.188737] NET: Registered protocol family 1
[ 0.237907] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.237950] PCI: CLS 64 bytes, default 64
[ 0.237973] Unpacking initramfs...
[ 0.580410] Freeing initrd memory: 39732K (ffff8d8e33256000 - ffff8d8e35923000)
[ 0.580436] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.580439] software IO TLB [mem 0xd963b000-0xdd63b000] (64MB) mapped at [ffff8d8ed963b000-ffff8d8edd63afff]
[ 0.580624] Scanning for low memory corruption every 60 seconds
[ 0.580811] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.580835] audit: initializing netlink subsys (disabled)
[ 0.580845] audit: type=2000 audit(1494123325.572:1): initialized
[ 0.581068] Initialise system trusted keyrings
[ 0.581119] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[ 0.581911] zbud: loaded
[ 0.582129] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.582228] fuse init (API version 7.25)
[ 0.582298] Allocating IMA blacklist keyring.
[ 0.582848] Key type asymmetric registered
[ 0.582850] Asymmetric key parser 'x509' registered
[ 0.582868] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.582887] io scheduler noop registered
[ 0.582888] io scheduler deadline registered (default)
[ 0.582894] io scheduler cfq registered
[ 0.583163] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.583168] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.583183] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 0.583185] vesafb: scrolling: redraw
[ 0.583187] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.583193] vesafb: framebuffer at 0xf1000000, mapped to 0xffffa83bc1c00000, using 1216k, total 1216k
[ 0.597666] Console: switching to colour frame buffer device 80x30
[ 0.612520] fb0: VESA VGA frame buffer device
[ 0.612829] intel_idle: MWAIT substates: 0x42120
[ 0.612829] intel_idle: v0.4.1 model 0x3C
[ 0.612974] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.613023] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.613602] ACPI: Power Button [PWRB]
[ 0.613878] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.632841] ACPI: Power Button [PWRF]
[ 0.642679] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.652270] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.661855] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.671377] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.680779] GHES: HEST is not enabled!
[ 0.690059] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.700304] Linux agpgart interface v0.103
[ 0.710849] loop: module loaded
[ 0.720284] libphy: Fixed MDIO Bus: probed
[ 0.729655] tun: Universal TUN/TAP device driver, 1.6
[ 0.738997] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 0.748348] PPP generic driver version 2.4.2
[ 0.757684] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.767346] ehci-pci: EHCI PCI platform driver
[ 0.777062] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.786730] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.805759] ehci-pci 0000:00:1a.0: debug port 2
[ 0.819251] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.819262] ehci-pci 0000:00:1a.0: irq 20, io mem 0xf7138000
[ 0.841816] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.851278] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.860732] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.879037] usb usb1: Product: EHCI Host Controller
[ 0.888172] usb usb1: Manufacturer: Linux 4.8.0-51-generic ehci_hcd
[ 0.897240] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.906310] hub 1-0:1.0: USB hub found
[ 0.915085] hub 1-0:1.0: 2 ports detected
[ 0.923668] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.932299] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.949361] ehci-pci 0000:00:1d.0: debug port 2
[ 0.961849] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.961857] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7137000
[ 0.985806] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.994316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.994317] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994317] usb usb2: Product: EHCI Host Controller
[ 0.994317] usb usb2: Manufacturer: Linux 4.8.0-51-generic ehci_hcd
[ 0.994318] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.994369] hub 2-0:1.0: USB hub found
[ 0.994371] hub 2-0:1.0: 2 ports detected
[ 0.994429] ehci-platform: EHCI generic platform driver
[ 0.994433] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.994435] ohci-pci: OHCI PCI platform driver
[ 0.994439] ohci-platform: OHCI generic platform driver
[ 0.994442] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.994497] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.994499] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.995558] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[ 0.995561] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.995610] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.995610] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.995611] usb usb3: Product: xHCI Host Controller
[ 0.995611] usb usb3: Manufacturer: Linux 4.8.0-51-generic xhci-hcd
[ 0.995612] usb usb3: SerialNumber: 0000:00:14.0
[ 0.995661] hub 3-0:1.0: USB hub found
[ 0.995673] hub 3-0:1.0: 14 ports detected
[ 0.997644] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.997646] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.997667] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.997667] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.997667] usb usb4: Product: xHCI Host Controller
[ 0.997668] usb usb4: Manufacturer: Linux 4.8.0-51-generic xhci-hcd
[ 0.997668] usb usb4: SerialNumber: 0000:00:14.0
[ 0.997718] hub 4-0:1.0: USB hub found
[ 0.997726] hub 4-0:1.0: 6 ports detected
[ 0.998357] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.000610] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.000612] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.000677] mousedev: PS/2 mouse device common for all mice
[ 1.000752] rtc_cmos 00:02: RTC can wake from S4
[ 1.000845] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.000867] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.000869] i2c /dev entries driver
[ 1.000891] device-mapper: uevent: version 1.0.3
[ 1.000939] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 1.000942] intel_pstate: Intel P-state driver initializing
[ 1.249797] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.325800] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.325805] usb 3-3: new full-speed USB device number 2 using xhci_hcd
[ 1.398137] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.398137] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.398275] hub 1-1:1.0: USB hub found
[ 1.398384] hub 1-1:1.0: 6 ports detected
[ 1.467462] usb 3-3: New USB device found, idVendor=1532, idProduct=0024
[ 1.467463] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.467463] usb 3-3: Product: Razer Mamba
[ 1.467463] usb 3-3: Manufacturer: Razer
[ 1.486131] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.486132] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.486269] hub 2-1:1.0: USB hub found
[ 1.486380] hub 2-1:1.0: 8 ports detected
[ 1.539508] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.547906] NET: Registered protocol family 10
[ 1.555997] NET: Registered protocol family 17
[ 1.563630] Key type dns_resolver registered
[ 1.571590] microcode: sig=0x306c3, pf=0x2, revision=0x1e
[ 1.579628] microcode: Microcode Update Driver: v2.01 <[email protected]>, Peter Oruba
[ 1.595789] usb 4-5: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.604185] tsc: Refined TSC clocksource calibration: 3990.758 MHz
[ 1.604269] registered taskstats version 1
[ 1.604271] Loading compiled-in X.509 certificates
[ 1.606066] Loaded X.509 cert 'Build time autogenerated kernel key: 9fb919bd9c101904a8e869e34acf515f11932921'
[ 1.606080] zswap: loaded using pool lzo/zbud
[ 1.654305] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x730c85718cb, max_idle_ns: 881591244843 ns
[ 1.679078] Key type big_key registered
[ 1.689068] Key type trusted registered
[ 1.698872] Key type encrypted registered
[ 1.707468] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.716070] ima: No TPM chip found, activating TPM-bypass!
[ 1.724859] evm: HMAC attrs: 0x1
[ 1.733693] Magic number: 1:447:257
[ 1.742213] usb usb3-port13: hash matches
[ 1.750725] rtc_cmos 00:02: setting system clock to 2017-05-07 02:15:27 UTC (1494123327)
[ 1.768236] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.777243] EDD information not available.
[ 1.786130] PM: Hibernation image not present or could not be loaded.
[ 1.786716] Freeing unused kernel memory: 1548K (ffffffff8d96a000 - ffffffff8daed000)
[ 1.805100] Write protecting the kernel read-only data: 14336k
[ 1.814718] Freeing unused kernel memory: 1396K (ffff8d91188a3000 - ffff8d9118a00000)
[ 1.834447] Freeing unused kernel memory: 260K (ffff8d9118dbf000 - ffff8d9118e00000)
[ 1.858103] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.894379] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.894566] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.894579] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895078] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895100] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895297] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895319] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895339] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895359] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.895379] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.903663] usb 4-5: New USB device found, idVendor=2109, idProduct=0812
[ 1.903663] usb 4-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.903664] usb 4-5: Product: USB3.0 Hub
[ 1.903665] usb 4-5: Manufacturer: VIA Labs, Inc.
[ 1.904833] hub 4-5:1.0: USB hub found
[ 1.905485] hub 4-5:1.0: 4 ports detected
[ 2.021742] usb 3-7: new full-speed USB device number 3 using xhci_hcd
[ 2.040893] FUJITSU Extended Socket Network Device Driver - version 1.1 - Copyright (c) 2015 FUJITSU LIMITED
[ 2.056488] pps_core: LinuxPPS API ver. 1 registered
[ 2.064045] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 2.079511] PTP clock support registered
[ 2.086816] ahci 0000:00:1f.2: version 3.0
[ 2.086963] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 2.094470] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 2.094538] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.094539] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.123049] ahci 0000:00:1f.2: flags: 64bit ncq stag led clo pio slum part ems sxs apst
[ 2.163786] usb 3-7: New USB device found, idVendor=0b05, idProduct=17cf
[ 2.171268] usb 3-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.179010] usb 3-7: Product: BCM20702A0
[ 2.186865] usb 3-7: Manufacturer: Broadcom Corp
[ 2.194938] usb 3-7: SerialNumber: 54271E6AEC6B
[ 2.206170] scsi host0: ahci
[ 2.214638] scsi host1: ahci
[ 2.223088] scsi host2: ahci
[ 2.231536] scsi host3: ahci
[ 2.240007] scsi host4: ahci
[ 2.248113] scsi host5: ahci
[ 2.255965] ata1: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136100 irq 27
[ 2.272129] ata2: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136180 irq 27
[ 2.289245] ata3: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136200 irq 27
[ 2.306872] ata4: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136280 irq 27
[ 2.321709] usb 3-9: new high-speed USB device number 4 using xhci_hcd
[ 2.333730] ata5: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136300 irq 27
[ 2.351755] ata6: SATA max UDMA/133 abar m2048@0xf7136000 port 0xf7136380 irq 27
[ 2.370317] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.463218] usb 3-9: New USB device found, idVendor=2109, idProduct=2812
[ 2.464467] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[ 2.492129] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.501986] usb 3-9: Product: USB2.0 Hub
[ 2.511761] usb 3-9: Manufacturer: VIA Labs, Inc.
[ 2.521852] hub 3-9:1.0: USB hub found
[ 2.531545] hub 3-9:1.0: 4 ports detected
[ 2.532860] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 40:16:7e:79:4d:b6
[ 2.532861] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 2.532899] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[ 2.561110] e1000e 0000:00:19.0 eno1: renamed from eth0
[ 2.688686] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.699872] clocksource: Switched to clocksource tsc
[ 2.700523] ata1.00: ATA-9: ST1000DM003-1CH162, CC47, max UDMA/133
[ 2.700524] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.701386] ata1.00: configured for UDMA/133
[ 2.701513] scsi 0:0:0:0: Direct-Access ATA ST1000DM003-1CH1 CC47 PQ: 0 ANSI: 5
[ 2.717689] usb 3-11: new full-speed USB device number 5 using xhci_hcd
[ 2.817775] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.839042] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.839064] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.860078] sd 0:0:0:0: [sda] Write Protect is off
[ 2.870236] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.870264] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.890750] usb 3-11: New USB device found, idVendor=1b1c, idProduct=0c04
[ 2.900877] usb 3-11: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.920385] usb 3-11: Product: Integrated USB Bridge
[ 2.930059] usb 3-11: Manufacturer: Corsair Memory, Inc.
[ 2.942266] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.954356] usbcore: registered new interface driver usbhid
[ 2.964189] usbhid: USB HID core driver
[ 2.974963] input: Razer Razer Mamba as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:1532:0024.0001/input/input5
[ 2.994495] usb 3-9.3: new full-speed USB device number 6 using xhci_hcd
[ 2.999257] sda: sda1
[ 2.999351] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.004487] hid-generic 0003:1532:0024.0001: input,hidraw0: USB HID v1.11 Mouse [Razer Razer Mamba] on usb-0000:00:14.0-3/input0
[ 3.004588] input: Razer Razer Mamba as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:1532:0024.0002/input/input6
[ 3.061754] hid-generic 0003:1532:0024.0002: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer Mamba] on usb-0000:00:14.0-3/input1
[ 3.061940] hid-generic 0003:1B1C:0C04.0003: hiddev0,hidraw2: USB HID v1.11 Device [Corsair Memory, Inc. Integrated USB Bridge] on usb-0000:00:14.0-11/input0
[ 3.186407] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.197566] ata2.00: ATAPI: ATAPI iHAS324 A, BL1A, max UDMA/100
[ 3.209152] ata2.00: configured for UDMA/100
[ 3.220902] usb 3-9.3: New USB device found, idVendor=0e6a, idProduct=030c
[ 3.221372] scsi 1:0:0:0: CD-ROM ATAPI iHAS324 A BL1A PQ: 0 ANSI: 5
[ 3.253221] usb 3-9.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.275124] usb 3-9.3: Product: Truly Ergonomic Computer Keyboard
[ 3.277480] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.277480] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.277560] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.277613] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.330719] usb 3-9.3: Manufacturer: TrulyErgonomic.com
[ 3.343748] input: TrulyErgonomic.com Truly Ergonomic Computer Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.3/3-9.3:1.0/0003:0E6A:030C.0004/input/input7
[ 3.437733] hid-generic 0003:0E6A:030C.0004: input,hidraw3: USB HID v1.11 Keyboard [TrulyErgonomic.com Truly Ergonomic Computer Keyboard] on usb-0000:00:14.0-9.3/input0
[ 3.474206] input: TrulyErgonomic.com Truly Ergonomic Computer Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.3/3-9.3:1.1/0003:0E6A:030C.0005/input/input8
[ 3.569723] hid-generic 0003:0E6A:030C.0005: input,hidraw4: USB HID v1.11 Device [TrulyErgonomic.com Truly Ergonomic Computer Keyboard] on usb-0000:00:14.0-9.3/input1
[ 3.592029] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 3.592522] ata3.00: ATA-9: SAMSUNG SSD 830 Series, CXM03B1Q, max UDMA/133
[ 3.592523] ata3.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 3.592778] ata3.00: configured for UDMA/133
[ 3.592894] scsi 2:0:0:0: Direct-Access ATA SAMSUNG SSD 830 3B1Q PQ: 0 ANSI: 5
[ 3.705681] sd 2:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 3.705710] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 3.741290] sd 2:0:0:0: [sdb] Write Protect is off
[ 3.753011] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3.753017] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.776681] sdb: sdb1
[ 3.788003] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 3.809610] usb 3-9.4: new low-speed USB device number 7 using xhci_hcd
[ 4.000535] usb 3-9.4: New USB device found, idVendor=04d9, idProduct=a02a
[ 4.011752] usb 3-9.4: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 4.021903] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.022362] ata4.00: ATA-9: WDC WD20EZRZ-00Z5HB0, 80.00A80, max UDMA/133
[ 4.022363] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 4.022849] ata4.00: configured for UDMA/133
[ 4.022967] scsi 3:0:0:0: Direct-Access ATA WDC WD20EZRZ-00Z 0A80 PQ: 0 ANSI: 5
[ 4.132165] input: HID 04d9:a02a as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.4/3-9.4:1.0/0003:04D9:A02A.0006/input/input9
[ 4.152695] sd 3:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 4.152698] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 4.183563] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[ 4.193772] sd 3:0:0:0: [sdc] Write Protect is off
[ 4.203764] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 4.203768] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.209676] hid-generic 0003:04D9:A02A.0006: input,hidraw5: USB HID v1.10 Keyboard [HID 04d9:a02a] on usb-0000:00:14.0-9.4/input0
[ 4.467969] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.487096] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20160422/psargs-359)
[ 4.507719] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT4._GTF] (Node ffff8d920e0e7000), AE_NOT_FOUND (20160422/psparse-542)
[ 4.529324] ata5.00: ATA-9: BP5, SAFM12.2, max UDMA/133
[ 4.540262] ata5.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 4.551529] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20160422/psargs-359)
[ 4.573715] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT4._GTF] (Node ffff8d920e0e7000), AE_NOT_FOUND (20160422/psparse-542)
[ 4.596756] ata5.00: configured for UDMA/133
[ 4.608260] scsi 4:0:0:0: Direct-Access ATA BP5 12.2 PQ: 0 ANSI: 5
[ 4.661633] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 4.661637] sd 4:0:0:0: [sdd] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 4.661751] sd 4:0:0:0: [sdd] Write Protect is off
[ 4.661753] sd 4:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 4.661782] sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.662173] sdd: sdd1 sdd2 < sdd5 >
[ 4.662307] sd 4:0:0:0: [sdd] Attached SCSI disk
[ 4.891962] sdc: sdc1
[ 4.902442] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 5.059930] ata6: SATA link down (SStatus 0 SControl 300)
[ 5.085201] random: fast init done
[ 6.436691] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.614079] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.641631] systemd[1]: Detected architecture x86-64.
[ 6.678826] systemd[1]: Set hostname to <stefano-desktop>.
[ 6.758097] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[ 6.777017] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.806500] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.826954] systemd[1]: Created slice System Slice.
[ 6.847528] systemd[1]: Reached target Encrypted Volumes.
[ 6.868023] systemd[1]: Listening on Journal Socket.
[ 6.901434] systemd[1]: Starting Load Kernel Modules...
[ 6.919246] lp: driver loaded but no devices found
[ 6.920689] ppdev: user-space parallel port driver
[ 6.948675] nct6775: Enabling hardware monitor logical device mappings.
[ 6.948683] nct6775: Found NCT6791D or compatible chip at 0x2e:0x290
[ 7.459524] EXT4-fs (sdd1): re-mounted. Opts: errors=remount-ro
[ 7.518832] systemd-journald[384]: Received request to flush runtime journal from PID 1
[ 7.531242] wmi: Mapper loaded
[ 7.537953] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 7.556504] bcma: bus0: Found chip with id 0x4352, rev 0x03 and package 0x00
[ 7.556545] bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
[ 7.556567] bcma: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
[ 7.556610] bcma: bus0: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
[ 7.556656] bcma: bus0: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
[ 7.556678] bcma: bus0: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
[ 7.577940] random: crng init done
[ 7.598137] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 7.598138] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 7.598139] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 7.598139] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 7.598140] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 7.601500] [drm] Initialized drm 1.1.0 20060810
[ 7.605651] Bluetooth: Core ver 2.21
[ 7.605659] NET: Registered protocol family 31
[ 7.605659] Bluetooth: HCI device and connection manager initialized
[ 7.605661] Bluetooth: HCI socket layer initialized
[ 7.605662] Bluetooth: L2CAP socket layer initialized
[ 7.605666] Bluetooth: SCO socket layer initialized
[ 7.605778] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 7.605786] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 7.614183] usbcore: registered new interface driver btusb
[ 7.620323] bcma: Unsupported SPROM revision: 11
[ 7.627384] bcma: bus0: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
[ 7.627385] bcma: bus0: Using fallback SPROM failed (err -2)
[ 7.627385] bcma: bus0: No SPROM available
[ 7.636720] snd_hda_codec_realtek hdaudioC0D0: ALC1150: SKU not ready 0x00000000
[ 7.636845] bcma: bus0: Bus registered
[ 7.637101] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1150: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 7.637102] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.637103] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 7.637103] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 7.637104] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 7.637104] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 7.637105] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 7.637106] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 7.637106] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 7.643431] Adding 9764860k swap on /dev/sdd5. Priority:-1 extents:1 across:9764860k SSFS
[ 7.648305] AVX2 version of gcm_enc/dec engaged.
[ 7.648305] AES CTR mode by8 optimization enabled
[ 7.650497] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 7.650531] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 7.650561] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 7.650598] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 7.650686] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 7.661080] intel_rapl: Found RAPL domain package
[ 7.661081] intel_rapl: Found RAPL domain core
[ 7.661083] intel_rapl: Found RAPL domain dram
[ 7.668010] nvidia: loading out-of-tree module taints kernel.
[ 7.668014] nvidia: module license 'NVIDIA' taints kernel.
[ 7.668014] Disabling lock debugging due to kernel taint
[ 7.671310] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 7.674818] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 7.674887] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[ 7.674911] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 378.13 Tue Feb 7 20:10:06 PST 2017 (using threaded interrupts)
[ 7.680079] asus_wmi: ASUS WMI generic driver loaded
[ 7.680356] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 378.13 Tue Feb 7 18:30:08 PST 2017
[ 7.680965] asus_wmi: Initialization: 0x0
[ 7.680979] asus_wmi: BIOS WMI version: 0.9
[ 7.680995] asus_wmi: SFUN value: 0x0
[ 7.681184] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input15
[ 7.681243] asus_wmi: Number of fans: 1
[ 7.681550] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 7.717351] b43-phy0: Broadcom 4352 WLAN found (core revision 42)
[ 7.717762] b43-phy0 ERROR: FOUND UNSUPPORTED PHY (Analog 12, Type 11 (AC), Revision 1)
[ 7.717766] b43: probe of bcma0:1 failed with error -95
[ 7.717776] Broadcom 43xx driver loaded [ Features: PNL ]
[ 7.726938] Bluetooth: hci0: BCM: chip id 63
[ 7.742936] Bluetooth: hci0: stefano-desktop
[ 7.743947] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 7.744659] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0b05-17cf.hcd failed with error -2
[ 7.744660] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0b05-17cf.hcd not found
[ 7.791760] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 241
[ 8.081444] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.413708] NVRM: GPU at PCI:0000:01:00: GPU-56c13f19-a730-b309-7e5a-a2e5acfdba22
[ 8.413709] NVRM: Xid (PCI:0000:01:00): 61, 1899(15dc) 00000000 00000000
[ 8.415144] NVRM: Xid (PCI:0000:01:00): 61, 1899(15dc) 00000000 00000000
[ 8.416650] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 8.416790] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 8.416855] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 8.416901] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[ 8.546147] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
[ 8.686724] audit: type=1400 audit(1494123334.433:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=855 comm="apparmor_parser"
[ 8.687061] audit: type=1400 audit(1494123334.433:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=852 comm="apparmor_parser"
[ 8.687065] audit: type=1400 audit(1494123334.433:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=852 comm="apparmor_parser"
[ 8.687112] audit: type=1400 audit(1494123334.433:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/libvirt/virt-aa-helper" pid=851 comm="apparmor_parser"
[ 8.687284] audit: type=1400 audit(1494123334.433:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/libvirtd" pid=856 comm="apparmor_parser"
[ 8.688293] audit: type=1400 audit(1494123334.433:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=853 comm="apparmor_parser"
[ 8.688319] audit: type=1400 audit(1494123334.433:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=848 comm="apparmor_parser"
[ 8.688321] audit: type=1400 audit(1494123334.433:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=848 comm="apparmor_parser"
[ 8.688323] audit: type=1400 audit(1494123334.433:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=848 comm="apparmor_parser"
[ 8.688325] audit: type=1400 audit(1494123334.433:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=848 comm="apparmor_parser"
[ 12.799489] cgroup: new mount options do not match the existing superblock, will be ignored
[ 12.862279] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.862279] Bluetooth: BNEP filters: protocol multicast
[ 12.862281] Bluetooth: BNEP socket layer initialized
[ 13.020008] NVRM: Xid (PCI:0000:01:00): 44, Ch 00000000, engmask 00000101, intr 10000000
[ 13.021056] NVRM: Xid (PCI:0000:01:00): 62, 1899(15dc) 00000000 00000000
[ 15.065173] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 15.256840] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 19.023277] e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 19.023304] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[ 21.021327] NVRM: Xid (PCI:0000:01:00): 32, Channel ID 00000000 intr 80044000
[ 21.021567] NVRM: Xid (PCI:0000:01:00): 32, Channel ID 00000000 intr 80004000
[ 33.023045] NVRM: Your system is not currently configured to drive a VGA console
[ 33.023046] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 33.023047] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 33.023047] NVRM: drivers including, but not limited to, vesafb, may result in
[ 33.023047] NVRM: corruption and stability problems, and is not supported.
[ 44.983324] nvidia-modeset: Allocated GPU:0 (GPU-56c13f19-a730-b309-7e5a-a2e5acfdba22) @ PCI:0000:01:00.0
[ 48.957367] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000088 00010009 00000007 00000000
[ 48.957377] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 0000008c 00000000 00000005 0000102b
[ 49.072493] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 49.080641] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 49.088822] Ebtables v2.0 registered
[ 49.266928] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 49.329520] virbr0: port 1(virbr0-nic) entered blocking state
[ 49.329521] virbr0: port 1(virbr0-nic) entered disabled state
[ 49.329568] device virbr0-nic entered promiscuous mode
[ 49.444607] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 49.483128] virbr0: port 1(virbr0-nic) entered blocking state
[ 49.483130] virbr0: port 1(virbr0-nic) entered listening state
[ 49.536565] virbr0: port 1(virbr0-nic) entered disabled state
[ 49.538271] device virbr0-nic left promiscuous mode
[ 49.538280] virbr0: port 1(virbr0-nic) entered disabled state
[ 51.919716] nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing.
[ 69.132673] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000474 0001005f 00000007 00000000
[ 69.132837] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 0000045c 00010047 00000007 00000000
[ 69.133102] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000006 00000005 00001005
[ 71.933524] NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
[ 72.130327] nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing.
[ 79.933325] nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000917e:0:0
[ 81.933751] nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000927c:0:0
[ 89.950834] nvidia-modeset: Freed GPU:0 (GPU-56c13f19-a730-b309-7e5a-a2e5acfdba22) @ PCI:0000:01:00.0
Xorg.log
[ 13.230] (--) Log file renamed from "/var/log/Xorg.pid-1108.log" to "/var/log/Xorg.0.log"
[ 13.230]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 13.230] X Protocol Version 11, Revision 0
[ 13.230] Build Operating System: Linux 4.4.0-59-generic x86_64 Ubuntu
[ 13.230] Current Operating System: Linux stefano-desktop 4.8.0-51-generic #54~16.04.1-Ubuntu SMP Wed Apr 26 16:00:28 UTC 2017 x86_64
[ 13.230] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-51-generic root=UUID=a454cb17-35a4-4d67-9588-162c5c5da7ba ro nomodeset
[ 13.230] Build Date: 26 January 2017 12:26:18AM
[ 13.230] xorg-server 2:1.18.4-1ubuntu6.1~16.04.1 (For technical support please see http://www.ubuntu.com/support)
[ 13.230] Current version of pixman: 0.33.6
[ 13.230] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 13.230] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 13.230] (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 6 22:15:38 2017
[ 13.231] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 13.232] (==) No Layout section. Using the first Screen section.
[ 13.232] (==) No screen section available. Using defaults.
[ 13.232] (**) |-->Screen "Default Screen Section" (0)
[ 13.232] (**) | |-->Monitor "<default monitor>"
[ 13.232] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 13.232] (==) Automatically adding devices
[ 13.232] (==) Automatically enabling devices
[ 13.232] (==) Automatically adding GPU devices
[ 13.232] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 13.232] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 13.232] Entry deleted from font path.
[ 13.232] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 13.232] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 13.232] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 13.232] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 13.232] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 13.232] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 13.232] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 13.233] (II) Loader magic: 0x55c20ee34dc0
[ 13.233] (II) Module ABI versions:
[ 13.233] X.Org ANSI C Emulation: 0.4
[ 13.233] X.Org Video Driver: 20.0
[ 13.233] X.Org XInput driver : 22.1
[ 13.233] X.Org Server Extension : 9.0
[ 13.233] (++) using VT number 7
[ 13.233] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 13.233] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 13.234] (--) PCI:*(0:1:0:0) 10de:1004:3842:2782 rev 161, Mem @ 0xf6000000/16777216, 0xe8000000/134217728, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 13.234] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 13.234] (II) "glx" will be loaded by default.
[ 13.234] (II) LoadModule: "glx"
[ 13.234] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 13.280] (II) Module glx: vendor="NVIDIA Corporation"
[ 13.280] compiled for 4.0.2, module version = 1.0.0
[ 13.280] Module class: X.Org Server Extension
[ 13.280] (II) NVIDIA GLX Module 378.13 Tue Feb 7 18:25:34 PST 2017
[ 13.280] (==) Matched nvidia as autoconfigured driver 0
[ 13.280] (==) Matched nouveau as autoconfigured driver 1
[ 13.280] (==) Matched nvidia as autoconfigured driver 2
[ 13.280] (==) Matched nouveau as autoconfigured driver 3
[ 13.280] (==) Matched modesetting as autoconfigured driver 4
[ 13.280] (==) Matched fbdev as autoconfigured driver 5
[ 13.280] (==) Matched vesa as autoconfigured driver 6
[ 13.280] (==) Assigned the driver to the xf86ConfigLayout
[ 13.280] (II) LoadModule: "nvidia"
[ 13.280] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 13.283] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 13.283] compiled for 4.0.2, module version = 1.0.0
[ 13.283] Module class: X.Org Video Driver
[ 13.283] (II) LoadModule: "nouveau"
[ 13.283] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 13.284] (II) Module nouveau: vendor="X.Org Foundation"
[ 13.284] compiled for 1.18.4, module version = 1.0.12
[ 13.284] Module class: X.Org Video Driver
[ 13.284] ABI class: X.Org Video Driver, version 20.0
[ 13.284] (II) LoadModule: "modesetting"
[ 13.284] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 13.284] (II) Module modesetting: vendor="X.Org Foundation"
[ 13.284] compiled for 1.18.4, module version = 1.18.4
[ 13.284] (II) LoadModule: "fbdev"
[ 13.284] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 13.284] (II) Module fbdev: vendor="X.Org Foundation"
[ 13.284] compiled for 1.18.4, module version = 0.4.4
[ 13.284] (II) LoadModule: "vesa"
[ 13.284] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 13.284] (II) Module vesa: vendor="X.Org Foundation"
[ 13.284] compiled for 1.18.4, module version = 2.3.4
[ 13.284] (II) NVIDIA dlloader X Driver 378.13 Tue Feb 7 18:01:51 PST 2017
[ 13.284] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 13.285] (II) NOUVEAU driver Date: Tue Dec 8 15:52:25 2015 +1000
[ 13.285] (II) NOUVEAU driver for NVIDIA chipset families :
[ 13.285] RIVA TNT (NV04)
[ 13.285] RIVA TNT2 (NV05)
[ 13.285] GeForce 256 (NV10)
[ 13.285] GeForce 2 (NV11, NV15)
[ 13.285] GeForce 4MX (NV17, NV18)
[ 13.285] GeForce 3 (NV20)
[ 13.285] GeForce 4Ti (NV25, NV28)
[ 13.285] GeForce FX (NV3x)
[ 13.285] GeForce 6 (NV4x)
[ 13.285] GeForce 7 (G7x)
[ 13.285] GeForce 8 (G8x)
[ 13.285] GeForce GTX 200 (NVA0)
[ 13.285] GeForce GTX 400 (NVC0)
[ 13.285] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 13.285] (II) FBDEV: driver for framebuffer: fbdev
[ 13.285] (II) VESA: driver for VESA chipsets: vesa
[ 13.304] (II) Loading sub module "fb"
[ 13.304] (II) LoadModule: "fb"
[ 13.304] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 13.304] (II) Module fb: vendor="X.Org Foundation"
[ 13.304] compiled for 1.18.4, module version = 1.0.0
[ 13.304] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.304] (II) Loading sub module "wfb"
[ 13.304] (II) LoadModule: "wfb"
[ 13.304] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 13.305] (II) Module wfb: vendor="X.Org Foundation"
[ 13.305] compiled for 1.18.4, module version = 1.0.0
[ 13.305] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.305] (II) Loading sub module "ramdac"
[ 13.305] (II) LoadModule: "ramdac"
[ 13.305] (II) Module "ramdac" already built-in
[ 33.019] (WW) Falling back to old probe method for modesetting
[ 33.019] (WW) Falling back to old probe method for fbdev
[ 33.019] (II) Loading sub module "fbdevhw"
[ 33.019] (II) LoadModule: "fbdevhw"
[ 33.019] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 33.019] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 33.019] compiled for 1.18.4, module version = 0.0.2
[ 33.019] ABI class: X.Org Video Driver, version 20.0
[ 33.019] (WW) Falling back to old probe method for vesa
[ 33.019] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 33.019] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 33.019] (==) NVIDIA(0): RGB weight 888
[ 33.019] (==) NVIDIA(0): Default visual is TrueColor
[ 33.019] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 33.029] (**) NVIDIA(0): Enabling 2D acceleration
[ 52.154] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 52.154] (--) NVIDIA(0): CRT-0
[ 52.154] (--) NVIDIA(0): DFP-0
[ 52.154] (--) NVIDIA(0): DFP-1
[ 52.154] (--) NVIDIA(0): DFP-2 (boot)
[ 52.154] (--) NVIDIA(0): DFP-3
[ 52.154] (--) NVIDIA(0): DFP-4
[ 56.155] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 780 (GK110) at PCI:1:0:0 (GPU-0)
[ 56.155] (--) NVIDIA(0): Memory: 3145728 kBytes
[ 56.155] (--) NVIDIA(0): VideoBIOS: 80.10.3a.00.80
[ 56.155] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 56.157] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 56.157] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 56.160] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 56.160] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 56.160] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 56.160] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 56.160] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 56.160] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 56.256] (--) NVIDIA(GPU-0): Acer V243H (DFP-2): connected
[ 56.256] (--) NVIDIA(GPU-0): Acer V243H (DFP-2): Internal TMDS
[ 56.256] (--) NVIDIA(GPU-0): Acer V243H (DFP-2): 165.0 MHz maximum pixel clock
[ 56.256] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 56.256] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 56.256] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 56.256] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 56.256] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 56.256] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 56.257] (==) NVIDIA(0):
[ 56.257] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 56.257] (==) NVIDIA(0): will be used as the requested mode.
[ 56.258] (II) NVIDIA(0): Validated MetaModes:
[ 56.258] (II) NVIDIA(0): "DFP-2:nvidia-auto-select"
[ 56.258] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 56.261] (--) NVIDIA(0): DPI set to (92, 94); computed from "UseEdidDpi" X config
[ 56.261] (--) NVIDIA(0): option
[ 56.261] (II) UnloadModule: "nouveau"
[ 56.261] (II) Unloading nouveau
[ 56.261] (II) UnloadModule: "modesetting"
[ 56.261] (II) Unloading modesetting
[ 56.261] (II) UnloadModule: "fbdev"
[ 56.261] (II) Unloading fbdev
[ 56.261] (II) UnloadSubModule: "fbdevhw"
[ 56.261] (II) Unloading fbdevhw
[ 56.261] (II) UnloadModule: "vesa"
[ 56.261] (II) Unloading vesa
[ 56.261] (--) Depth 24 pixmap format is 32 bpp
[ 60.261] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[ 60.261] (II) NVIDIA: access.
[ 63.263] (EE) NVIDIA(GPU-0): Failed to initialize DMA.
[ 63.263] (EE) *** Aborting ***
[ 69.266] (EE) NVIDIA(0): Failed to allocate push buffer
