So, I have 4 670's selected. I will be gaming at 1920x1080. I would like to get the highest fps possible on high settings. Unless it is a 670, please do not recommend any alternative cards to me, I just want to know which of the 4 cards will preform the best for me. Here are the cards:
So, as you can see, there are 2 EVGA cards, and 2 Asus cards. Which of these cards will preform the best? Will I need 4GB for one screen at 1920x1080? Asus or Evga? Let me know which is the best choice for me. If you have any questions let me know. Thanks.
You do not need 4 gigs for 1920x1080, but out of the 4 you have linked there I would say go for the 2nd (http://www.newegg.com/Product/Product.aspx?Item=14-130-785) just because it is factory overclocked. But, if you want to OC yourself, go with the 2GB ASUS card (http://www.newegg.com/Product/Product.aspx?Item=N82E16814121637).
I would also recommend MSI, they make some very good Graphics cards, especially those with the Twin Frozr coolers.
Apparently the 670 reference board is pretty cramped and poorely designed so i would go for the 2GB Asus especially if oc but the EVGA should be very reliable.
I think I'm leaning towards the second link. As it's more likely for me to add a second monitor than to overclock, so it'd be nice to have that 4GB. The fourth link is a bit too expensive for me. What do you guys think? Good choice? Bad choice? Let me know.
EDIT: I was told that 4GB for one screen is overkill by a few people, so I think the first link will be the one I go with.
Is there a specific reason that you are leaving the EVGA FTW version out? And there's no need to waste money on a 4gb card at that resolution. Also, no matter which you pick it's an amazing card, is the asus really worth a 30 dollar premium over the stock EVGA?
Yeah, I'm going with the 2GB evga version, I think. And I have to agree, 2 monitors doesn't really look good when you're playing a game. I'd probroally only use one of them for a game if I had two.
I didn't realise that there was a ftw version of the 670. I thought that was only for the 680... derp. And yeah, I realised that. I'll be going with a 2GB card. As for the ASUS vs EVGA thing, I dunno. That's why I posted this thread. lol
