Hi guys. I have a NAS with samba share enabled. Now i want to use the NAS so that i don’t have to mount it every time i boot. The NAS is running ZFS with 4 Datasets. Where in windows i have those datasets maped like i have 4 HUGE disks. Well now i want to replicate that in fedora.
Because all of the tutorials mentioned editing fstab and are for ubuntu i ask you guys to help me cuz i don’t wanna mess up fedora now where i have it set up the way i like it.
Okay, so your credentials file has username=username and password=password with each on their own line?
There’s a comma before credentials that you should get rid of (from when you got rid of the defaults option).
Try it without the gid option, or try your username for uid and your user’s group name for gid (this is your local user that will be accessing the shares) or you could try without those options but it may cause it to be mounted as root.
Something is wrong i tride a normal mount and the same error occurs which is unlogical if my Windows, phone and nautilus fm can all access this NAS. sudo mount -t cifs -o user=alphazero1990 //192.168.1.2 /home/alphazero1990/Data_share/
With just //192.168.1.2 i get the error 22. But when i try a Dataset like 192.168.1.2/Data/Music i get error 6 no such device.
But are they the share names in samba? Can you do a network discovery in the file browser or something and see what the names are? I don’t think it works with just the server i think it needs to be server/share. Try 192.168.1.2/data or 192.168.1.2/music, it won’t be server/something/somethingelse
THANK you SO much. The actual name of the shares are Data_Music, Data_Games. I won’t forget this lession :D. Now the perma mount should work 100%. Thx again for sticking around and helping a noob.
