Hello,
So after loosing all my files due hdd failure i decided that i want to buy NAS. I am a bit limited on money so i cant really spend more than 275€ on it. Also i would like it to have at least 2tb storage on it.
Thanks
Hello,
Thanks
You may also want to consider just adding a 2 TB drive to your system and backing up to it. If your system supports raid 1, (or use software raid) you could buy two, 2TB drives and add them to your system.
IMO, 275 Euro won't get you to far on a NAS. You could look into one of these though:
Thecus N2310:
http://www.amazon.com/Thecus-N2310-SUPPORT-WEB-BASED-BUILT-IN/dp/B00GHVB7KS
But keep in mind you will still have to purchase the drives separately.
