8320 and 8350 are essentially the same, the 8350s are a better bin and are clocked higher at stock. You can overclock a 8320 (assuming you don't get a dud) to the equivalent or better than the 8350 at stock speed.
The 8320 is practically a down clocked 8350 so you could overclock the 8320 on it to get it to perform the same as an 8350 for less. I believe the 990fx Pro has a better powerphase over the Evo so it would handle overclocks much better.
The performance difference shouldn't be much of a difference. It will vary from game to game as some games prefer Amd and some prefer Intel. The noctua cooler should keep it cool enough.
An intel CPU will obviously overclock well also, however it's very very hard to pass up the 8320 at this price to performance ratio given the allocated budget.
1) About the GPU: i read stuff about Club3D cards not being reliable. When it comes to GPU, should i chose reputable brands instead like Asus, Saphire XFX etc...?
2) About the PSU: is 650 enough considering the fans, GPU and the potential overclocking?
3) About the RAM: would it be better to spread the 8GB across 4*2 GB or 2*4GB?
Get this one then: http://www.ldlc.com/fiche/PB00158919.html
The MSI cooler is good and you will get Battlefield 4 as well by the looks of it.
You need to go to the manufacturers website and look up the specifications to check what channel of memory it has but it is very rare for a motherboard at the moment to be anything but dual channel. (Also tri/quad channel are not significant improvements at the moment until they work more on the technology.
All PCs are up-gradable. You may need to update the motherboard to upgrade the CPU in 5 years or so but that's not a problem.
If you want to replace the graphics card later that's very easy to do. If you want to run two cards in xfire or SLI then you might want to invest in a larger PSU (add maybe 200-400 watts depending on the card) but I wouldn't bother with a dual card system. By the time you want to upgrade you may as well sell your 'old' card and buy a new better one with the money you have saved + what you can get back for your old card.
