I'm trying hard to bring the cost under the 1000€ belt but i don't have the knowledge to pick the right parts which would still allow me to do some heavy gaming.
http://fr.pcpartpicker.com/p/2MoIa
Could you please help me out? Where do you think i could make a compromise? GPU maybe?
GTX 670 is like a nerfed GTX 680. The EVGA FTW variant has the same power design and PCB as the 680, so you should have the same level of overclocking capability and very similar performance.
I left the expensive chassis in the parts list because that is subjective, and you may not want to change it, but you could save a lot of money by purchasing a cheaper chassis.
I gave you a PSU that I would be comfortable using. I don't know anything about BeQuiet units.
Jesus christ that was some fast answering. Thanks for the awesome feedback guys. I like the AMD build.
Berserker, there is no CPU cooler in your builds, is it normal?
Appart from being cheaper what difference is there between the AMD 8 core and the i5 which can be overclocked (also the reason why i chose a liquid cooler for the CPU)?
The 8320 is an unlocked part and can be overclocked, it's cheaper and has very good performance. If you had a bigger budget I would go for the 4770k over the 8320.
About the Chassis, i like the minimalistic and efficient design of the R4, which is the main reason why i chose it. Until now, i have yet to find another (cheaper) one which is as simple and as sleak as this one.
Yes, you can use the stock cooler that comes with the CPU. However, you will need to add an aftermarket heatsink if you wish to overclock the CPU.
Also, I would take a decent quality Noctua air cooler over a cheap liquid cooler.
You will not see much of a tangible performance difference between the two CPUs in most games. This is because most of the work is done by the GPU, therefore, the GTX 770 build would perform a little faster.
The AMD octa-core will be better for things like streaming, but some games do prefer Intel's stronger per-core performance. So it depends what you want to achieve? I would break it down like this: maximum performance in all games = Intel. Streaming and multitasking of any kind, maybe video editing = AMD.
some indie games (but trine 2 for instance eats its fair share of GPU)
I would love to play on max settings since i mostly played on low or medium settings for the last ten years and i'm tired of being frustrated or having low fps for some games.
The AMD should be able to handle all of those. Only one of those I haven't played on my 8320 is Bioshock Infinite. The original will be handled easily if that's what you meant.
You can play any of those games on max settings with either build. I would actually advocate grabbing a high-end AMD GPU, if you can afford one. Something like the 280x, particularly if you want to mod Skyrim.
That appears to be a really great price for the 280x. Arguably a better card than both the 670 and 770. It performs similarly, but it has a great deal more capability, and you will certainly secure the use of Mantle - which Nvidia might fail to adopt.
Its only 9 over budget but it would be worth it. The r9 280x would be on par with the 770 but the r9 280x has 3gb of vram(Trust me 2gb is not enough for skyrim modded.) The motherboard would be fine for a high overclock on the 8320 so it could match the 8350's performance.
So if i understood you correctly, the motherboard you selected is better for overclocking the 8320, allowing to reach similar performances to the 8350. How so?
Edit: And in this AMD build, the CPU performances with the M5A99FX when overclocking are better than the i5 overclocked? And the Noctua CPU cooler is enough to cool it down?
8320 and 8350 are essentially the same, the 8350s are a better bin and are clocked higher at stock. You can overclock a 8320 (assuming you don't get a dud) to the equivalent or better than the 8350 at stock speed.
The Noctua should be fine for a moderate overclock, for an extreme overclock go the U12S or U14S, both which will fit in that case.
I would stick with an SSD bigger than 120 GB so you can have a number of large games on it as well as your OS. Skyrim on SSD is amazing with load times.
