http://pcpartpicker.com/p/lTGv
Plz Help
Additional: If anyone has a budget build idea feel free to post it i could use all the info right now.
Plz Help
It may be saying that because the Ram speed is clocked higher than the motherboard supports.
and the ram is pretty low quality, and expensive, 1.65v for ddr3 1600 is horrible, especially at a price of $50 for 8 gigs. look for a set that says 1.5v or less. and at a $500 budget, I would get an amd A10 and no discrete card, thae performance is going to be ALOT better than with a pentium
Commissar you should take a look at the picture I posted in builds about my reservoir/ pump
Thanks
