HELP: is my PSU still good?
hi guys!
I'm planning to build a rig this coming December and I need to know if my 5yrs old PSU fsp epsilon600w is still good for the job?
im planning to have an
cpu: fx8350 slight oc "if can be" i will use cooler master v8 for cooling..
board: asrock 990fx faital1ty pro
ram: 16g dual ram
vga: palit jetstream gtx 760 2gb  "of course overclock it!:)"
and an 128ssd, some hdd and high rpm fans..
your answers will be so much appreciated thanks! :)
Yes it will still do nicely with a good margin. Just take the opportunity to blow out any dust from inside it while you build. :) Compressed air in a can is good. (short bursts)
thank you so much!
one more thing!
just incase i have a good budget
can i run a single r9 280x or 7970 on it?
the r9 280x requires at least 700watts psu while the 7970 requires 600watts..
and so i heard the r9 280x is a 7970 with some additional features...
im confused..
sorry man! i only have few knowledge with regards to psu..
5 years is a long time i'd recommend you get a new psu, failing that, you can get a 20 dollar power supply tester to make sure the voltages are correct, or you can use a simple multimeter. if you need info about testing your power supply i suggest you search about it on google.com
Does your old PSU have all the connectors your new build is gonna need?
Drop 8 gigs from the ram and invest in a new PSU (some 500W and 80+ Bronze certified (alot of options))
Yes! It has a 6pin and 8pin just enough for 760
Sorry I'm a bit late to reply but your Epsilon 600 can handle those graphics cards just fine. It's a quality part and the official recommendations that are written on thge graphics card packages have a lot of margin. They're essentially on a levels that counts in power supplies that do not deliver their rated wattage, but the Epsilon 600 does. While less common in recent years there are still some "noname" brands out there that add a fake 100-200W onto the box of the unit.
I have an early edition of the Epsilon 600 which efficiency curve over the range of watts is not flat enough to pass 80PLUS certification like the newer ones, but at levels where your system would be loaded even this old one would be quite efficient with a peak at about 85% around mid load. Your system with a 280X graphics card shouldn't draw more than 400-450W when playing games, unless you overclock a lot. On the other hand going to a 280X fron your current 760 might not be an upgrade big enough to warrant the cost. I'd save up for a bigger future upgrade.
It's more than enough for you.
They don't. Never look at those PSU requirements, google actual benchmarks instead (and remember that most benchmarks show total system power).
is 600w more than enough to power your build? Yes.
Would I use a power supply that old in a build? No.
As time goes on, power supplies become more inefficient, and can supply dirty power to your system.
The parts wear down, the capacitors lose their quality, and dirty power can damage parts, and cause coil whine.
Thank you so much guys! so i guess i have to save a budget for a new psu. For the meanwhile i think i will stick to my epsilon600 for few months until i have the budget.
