HELP install qmk firmware/configure tool boxs for linux (pop os)
does anyone know what the correct sudo command lines are to
install qmk firmware/configure tool boxs for linux (pop os) are iv got the
drop shift barebones keyboard an need to add the
qmk software to load the custom rgb an key config can from drop
can someone help
iv got the via program loaded an my custom key map an rgb profile .bin file from drops configure page
but how to load it to the connected keyboard i dont know
By the looks of it you need to do it through pip3.
So
sudo apt install -y git python3-pip
python3 -m pip install --user qmk
Then to run the set up
qmk setup
thanks
