Help in solving issues with passthrough in PopOS 20.04
Hi, I’ve been all day trying to get this working, but every tutorial I use didn’t help. Sorry, if I’m repetitive here, I’ve seen similar issues in other threads but it didn’t help me in my case.
The first issue I got is with the notorious black screen, I boot my VM but it doesn’t show anything. I already installed Windows 10 using the provided virtual display like advised in this tutorial
The second issue is passing a group USB group to the vm, I tried to bind 03:00.0 to the guest, while keep 24:00.3 to the host. Doing that I get error 127 while trying to start the VM.
My computer spec:
Processor: Ryzen 1800x
Motherboard: Asrock x370 Taichi
Ram: 32GB
Host VGA: Radeon Rx570
Guest VGA: Nvidia GTX 1070
Dedicated SATA SSD for Guest
here is my lspci -nnv
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex [1022:1450]
	Subsystem: ASRock Incorporation Family 17h (Models 00h-0fh) Root Complex [1849:1450]
	Flags: fast devsel
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit [1022:1451]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit [1022:1451]
	Flags: fast devsel, IRQ 25
	Capabilities: [40] Secure device <?>
	Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
	Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: f7c00000-f7cfffff [size=1M]
	Prefetchable memory behind bridge: [disabled]
	Capabilities: [50] Power Management version 3
	Capabilities: [58] Express Root Port (Slot+), MSI 00
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
	Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
	Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150] Advanced Error Reporting
	Capabilities: [270] Secondary PCI Express
	Capabilities: [2a0] Access Control Services
	Capabilities: [370] L1 PM Substates
	Capabilities: [3c4] Designated Vendor-Specific <?>
	Kernel driver in use: pcieport
00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27
	Bus: primary=00, secondary=03, subordinate=21, sec-latency=0
	I/O behind bridge: 0000c000-0000dfff [size=8K]
	Memory behind bridge: f7200000-f76fffff [size=5M]
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28
	Bus: primary=00, secondary=22, subordinate=22, sec-latency=0
	I/O behind bridge: 0000f000-0000ffff [size=4K]
	Memory behind bridge: f7b00000-f7bfffff [size=1M]
	Prefetchable memory behind bridge: 00000000e0000000-00000000f01fffff [size=258M]
00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29
	Bus: primary=00, secondary=23, subordinate=23, sec-latency=0
	I/O behind bridge: 0000e000-0000efff [size=4K]
	Memory behind bridge: f6000000-f70fffff [size=17M]
	Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 30
	Bus: primary=00, secondary=24, subordinate=24, sec-latency=0
	Memory behind bridge: f7700000-f79fffff [size=3M]
	Capabilities: [58] Express Root Port (Slot-), MSI 00
	Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	Flags: fast devsel
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 32
	Bus: primary=00, secondary=25, subordinate=25, sec-latency=0
	Memory behind bridge: f7a00000-f7afffff [size=1M]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
	Subsystem: ASRock Incorporation FCH SMBus Controller [1849:790b]
	Flags: 66MHz, medium devsel
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
	Subsystem: ASRock Incorporation FCH LPC Bridge [1849:790e]
	Flags: bus master, 66MHz, medium devsel, latency 0
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
	Flags: fast devsel
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
	Flags: fast devsel
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
	Flags: fast devsel
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
	Flags: fast devsel
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
	Flags: fast devsel
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
	Flags: fast devsel
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
	Flags: fast devsel
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
	Flags: fast devsel
01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a804] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 48, NUMA node 0
	Memory at f7c00000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [158] Power Budgeting <?>
	Capabilities: [168] Secondary PCI Express
	Capabilities: [188] Latency Tolerance Reporting
	Capabilities: [190] L1 PM Substates
	Kernel driver in use: nvme
	Kernel modules: nvme
03:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset USB 3.1 xHCI Controller [1022:43b9] (rev 02) (prog-if 30 [XHCI])
	Subsystem: ASRock Incorporation Fatal1ty X370 Professional Gaming [1849:43d0]
	Flags: bus master, fast devsel, latency 0, IRQ 43
	Memory at f76a0000 (64-bit, non-prefetchable) [size=32K]
	Capabilities: [50] MSI: Enable+ Count=1/8 Maskable- 64bit+
	Capabilities: [78] Power Management version 3
	Capabilities: [80] Express Legacy Endpoint, MSI 00
	Capabilities: [200] Secondary PCI Express
	Capabilities: [300] Latency Tolerance Reporting
	Capabilities: [400] L1 PM Substates
	Kernel driver in use: xhci_hcd
03:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset SATA Controller [1022:43b5] (rev 02) (prog-if 01 [AHCI 1.0])
	Subsystem: ASRock Incorporation Fatal1ty X370 Professional Gaming [1849:43c8]
	Flags: bus master, fast devsel, latency 0, IRQ 47
	Memory at f7680000 (32-bit, non-prefetchable) [size=128K]
	Expansion ROM at f7600000 [disabled] [size=512K]
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Kernel driver in use: ahci
	Kernel modules: ahci
03:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset PCIe Upstream Port [1022:43b0] (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 33
	Bus: primary=03, secondary=16, subordinate=21, sec-latency=0
	Memory behind bridge: f7200000-f75fffff [size=4M]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [80] Express Upstream Port, MSI 00
	Capabilities: [c0] Subsystem: ASRock Incorporation Fatal1ty X370 Professional Gaming [1849:43c6]
16:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 34
	Bus: primary=16, secondary=17, subordinate=17, sec-latency=0
	Memory behind bridge: [disabled]
	Capabilities: [80] Express Downstream Port (Slot+), MSI 00
	Capabilities: [c0] Subsystem: ASRock Incorporation 300 Series Chipset PCIe Port [1849:43c7]
16:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 35
	Bus: primary=16, secondary=19, subordinate=19, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff [size=4K]
	Memory behind bridge: f7500000-f75fffff [size=1M]
16:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 37
	Bus: primary=16, secondary=1a, subordinate=20, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff [size=4K]
	Memory behind bridge: f7200000-f73fffff [size=2M]
16:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 38
	Bus: primary=16, secondary=21, subordinate=21, sec-latency=0
	Memory behind bridge: f7400000-f74fffff [size=1M]
19:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02) (prog-if 01 [AHCI 1.0])
	Subsystem: ASRock Incorporation Motherboard [1849:0612]
	Flags: bus master, fast devsel, latency 0, IRQ 51
	I/O ports at d050 [size=8]
	I/O ports at d040 [size=4]
	I/O ports at d030 [size=8]
	I/O ports at d020 [size=4]
	I/O ports at d000 [size=32]
	Memory at f7500000 (32-bit, non-prefetchable) [size=512]
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [100] Virtual Channel
1a:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1184e PCIe Switch Port [1b21:1184] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 36
	Bus: primary=1a, secondary=1b, subordinate=20, sec-latency=0
	Capabilities: [c0] Subsystem: ASRock Incorporation ASM1184e PCIe Switch [1849:1184]
	Capabilities: [200] Advanced Error Reporting
	Capabilities: [300] Vendor Specific Information: ID=0000 Rev=0 Len=c00 <?>
1b:01.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1184e PCIe Switch Port [1b21:1184] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 39
	Bus: primary=1b, secondary=1c, subordinate=1c, sec-latency=0
	Memory behind bridge: f7300000-f73fffff [size=1M]
1b:03.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1184e PCIe Switch Port [1b21:1184] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 40
	Bus: primary=1b, secondary=1d, subordinate=1d, sec-latency=0
1b:05.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1184e PCIe Switch Port [1b21:1184] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 41
	Bus: primary=1b, secondary=1e, subordinate=1e, sec-latency=0
	Memory behind bridge: f7200000-f72fffff [size=1M]
1b:07.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1184e PCIe Switch Port [1b21:1184] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 42
	Bus: primary=1b, secondary=20, subordinate=20, sec-latency=0
1c:00.0 Network controller [0280]: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] [8086:24fb] (rev 10)
	Subsystem: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] [8086:2110]
	Flags: bus master, fast devsel, latency 0, IRQ 86
	Memory at f7300000 (64-bit, non-prefetchable) [size=8K]
	Capabilities: [c8] Power Management version 3
	Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [40] Express Endpoint, MSI 00
	Capabilities: [140] Device Serial Number b0-35-9f-ff-ff-07-d3-3e
	Capabilities: [14c] Latency Tolerance Reporting
	Capabilities: [154] L1 PM Substates
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
1e:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
	Subsystem: ASRock Incorporation I211 Gigabit Network Connection [1849:1539]
	Flags: bus master, fast devsel, latency 0, IRQ 31
	Memory at f7200000 (32-bit, non-prefetchable) [size=128K]
	I/O ports at c000 [size=32]
	Memory at f7220000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
	Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
	Capabilities: [a0] Express Endpoint, MSI 00
	Capabilities: [140] Device Serial Number 70-85-c2-ff-ff-42-f8-22
	Capabilities: [1a0] Transaction Processing Hints
	Kernel driver in use: igb
	Kernel modules: igb
21:00.0 Non-Volatile memory controller [0108]: Micron/Crucial Technology P1 NVMe PCIe SSD [c0a9:2263] (rev 03) (prog-if 02 [NVM Express])
	Subsystem: Micron/Crucial Technology P1 NVMe PCIe SSD [c0a9:2263]
	Flags: bus master, fast devsel, latency 0, IRQ 31, NUMA node 0
	Memory at f7400000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
	Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
	Capabilities: [158] Secondary PCI Express
	Capabilities: [178] Latency Tolerance Reporting
	Capabilities: [180] L1 PM Substates
22:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev ef) (prog-if 00 [VGA controller])
	Subsystem: Sapphire Technology Limited Radeon RX 570 Pulse 4GB [1da2:e353]
	Flags: bus master, fast devsel, latency 0, IRQ 82
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Memory at f0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at f000 [size=256]
	Memory at f7b00000 (32-bit, non-prefetchable) [size=256K]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [58] Express Legacy Endpoint, MSI 00
	Capabilities: [200] Resizable BAR <?>
	Capabilities: [2b0] Address Translation Service (ATS)
	Capabilities: [2c0] Page Request Interface (PRI)
	Capabilities: [2d0] Process Address Space ID (PASID)
	Capabilities: [320] Latency Tolerance Reporting
	Capabilities: [328] Alternative Routing-ID Interpretation (ARI)
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
22:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
	Subsystem: Sapphire Technology Limited Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1da2:aaf0]
	Flags: bus master, fast devsel, latency 0, IRQ 88
	Memory at f7b60000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
23:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1070] [10de:1b81] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation GP104 [GeForce GTX 1070] [10de:119d]
	Flags: fast devsel, IRQ 5
	Memory at f6000000 (32-bit, non-prefetchable) [disabled] [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [disabled] [size=256M]
	Memory at d0000000 (64-bit, prefetchable) [disabled] [size=32M]
	I/O ports at e000 [disabled] [size=128]
	Expansion ROM at f7000000 [disabled] [size=512K]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Legacy Endpoint, MSI 00
	Capabilities: [250] Latency Tolerance Reporting
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [420] Advanced Error Reporting
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900] Secondary PCI Express
	Kernel driver in use: vfio-pci
	Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
23:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
	Subsystem: NVIDIA Corporation GP104 High Definition Audio Controller [10de:119d]
	Flags: fast devsel, IRQ 4
	Memory at f7080000 (32-bit, non-prefetchable) [disabled] [size=16K]
	Capabilities: [78] Express Endpoint, MSI 00
24:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
	Flags: fast devsel
	Capabilities: [64] Express Endpoint, MSI 00
24:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
	Flags: bus master, fast devsel, latency 0, IRQ 83
	Memory at f7800000 (32-bit, non-prefetchable) [size=1M]
	Memory at f7900000 (32-bit, non-prefetchable) [size=8K]
	Capabilities: [a0] MSI: Enable- Count=1/2 Maskable- 64bit+
	Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
	Kernel driver in use: ccp
	Kernel modules: ccp
24:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller [1022:145c] (prog-if 30 [XHCI])
	Subsystem: ASRock Incorporation Family 17h (Models 00h-0fh) USB 3.0 Host Controller [1849:7914]
	Flags: bus master, fast devsel, latency 0, IRQ 45
	Memory at f7700000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [a0] MSI: Enable+ Count=1/8 Maskable- 64bit+
25:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
	Flags: fast devsel
25:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51) (prog-if 01 [AHCI 1.0])
	Subsystem: ASRock Incorporation FCH SATA Controller [AHCI mode] [1849:7901]
	Flags: bus master, fast devsel, latency 0, IRQ 53
	Memory at f7a08000 (32-bit, non-prefetchable) [size=4K]
	Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
	Capabilities: [d0] SATA HBA v1.0
25:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
	Subsystem: ASRock Incorporation Family 17h (Models 00h-0fh) HD Audio Controller [1849:1220]
	Flags: bus master, fast devsel, latency 0, IRQ 90
	Memory at f7a00000 (32-bit, non-prefetchable) [size=32K]
update-initramfs -u information:
update-initramfs: Generating /boot/initrd.img-5.7.8
cryptsetup: WARNING: Resume target cryptswap uses a key file
W: Possible missing firmware /lib/firmware/amdgpu/navi12_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_asd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_asd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi14_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/arcturus_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_dmcu.bin for module amdgpu
kernelstub.Config    : INFO     Looking for configuration...
kernelstub           : INFO     System information:
    OS:..................Pop!_OS 20.04
    Root partition:....../dev/sda3
    Root FS UUID:........bdc1b267-cb19-1d92-f235-83208516e464
    ESP Path:............/boot/efi
    ESP Partition:......./dev/sda2
    ESP Partition #:.....2
    NVRAM entry #:.......-1
    Boot Variable #:.....0000
    Kernel Boot Options:.quiet loglevel=0 systemd.show_status=false splash amd_iommu=on vfio-pci.ids=10de:1b81,10de:10f0 pcie_acs_override=downstream intel_iommu=on
    Kernel Image Path:.../boot/vmlinuz-5.7.8-050708-generic
    Initrd Image Path:.../boot/initrd.img-5.7.8-050708-generic
    Force-overwrite:.....False
kernelstub.Installer : INFO     Copying Kernel into ESP
kernelstub.Installer : INFO     Copying initrd.img into ESP
kernelstub.Installer : INFO     Setting up loader.conf configuration
kernelstub.Installer : INFO     Making entry file for Pop!_OS
kernelstub.Installer : INFO     Backing up old kernel
VM config:
<domain type='kvm'>
  <name>win10</name>
  <uuid>8991918e-d6d5-44b9-8b0a-9738cd7819a9</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit='KiB'>12582912</memory>
  <currentMemory unit='KiB'>12582912</currentMemory>
  <memoryBacking>
    <hugepages/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <os>
    <type arch='x86_64' machine='pc-q35-4.2'>hvm</type>
    <loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.ms.fd</loader>
    <nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
    <boot dev='cdrom'/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
      <spinlocks state='on' retries='8191'/>
      <vendor_id state='on' value='kvm hyperv'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <vmport state='off'/>
    <ioapic driver='kvm'/>
  </features>
  <cpu mode='host-model' check='partial'/>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
    <timer name='hypervclock' present='yes'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type='block' device='disk'>
      <driver name='qemu' type='raw' cache='none' io='native'/>
      <source dev='/dev/disk/by-id/ata-LITEON_LCH-256V2S-11_2.5_7mm_256GB_BR0H3T4N1CB0075JB06D'/>
      <target dev='sda' bus='sata'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    <controller type='sata' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
       <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0x9'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='10' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <interface type='network'>
      <mac address='52:54:00:af:78:c7'/>
      <source network='default'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
      <target type='isa-serial' port='0'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
      <target type='serial' port='0'/>
    </console>
    <channel type='spicevmc'>
      <target type='virtio' name='com.redhat.spice.0'/>
      <address type='virtio-serial' controller='0' bus='0' port='1'/>
    </channel>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <source>
        <address domain='0x0000' bus='0x23' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x0a' slot='0x01' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x23' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x0a' slot='0x02' function='0x0'/>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='yes'>
      <source>
        <vendor id='0x046d'/>
        <product id='0xc06b'/>
      </source>
      <address type='usb' bus='0' port='1'/>
    </hostdev>
    <redirdev bus='usb' type='spicevmc'>
      <address type='usb' bus='0' port='2'/>
    </redirdev>
      <address type='usb' bus='0' port='3'/>
    </redirdev>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </memballoon>
  </devices>
</domain>
Thanks for anyone who can help me with this issue.
Win10 QEMU log:
2020-07-10 18:11:12.280+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin \
HOME=/var/lib/libvirt/qemu/domain-1-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-win10/.config \
QEMU_AUDIO_DRV=spice \
/usr/bin/qemu-system-x86_64 \
-name guest=win10,debug-threads=on \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-win10/master-key.aes \
-machine pc-q35-4.2,accel=kvm,usb=off,vmport=off,dump-guest-core=off \
-cpu EPYC-IBPB,x2apic=on,tsc-deadline=on,hypervisor=on,tsc-adjust=on,arch-capabilities=on,xsaves=on,cmp-legacy=on,perfctr-core=on,clzero=on,virt-ssbd=on,rdctl-no=on,skip-l1dfl-vmentry=on,mds-no=on,monitor=off,hv-time,hv-relaxed,hv-vapic,hv-spinlocks=0x1fff \
-m 8192 \
-overcommit mem-lock=off \
-smp 4,sockets=4,cores=1,threads=1 \
-uuid 7aae63ec-db6a-4767-b671-dce40cabc5fe \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=31,server,nowait \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-reboot \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot strict=on \
-device pcie-root-port,port=0x10,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x2 \
-device pcie-root-port,port=0x11,chassis=2,id=pci.2,bus=pcie.0,addr=0x2.0x1 \
-device pcie-root-port,port=0x12,chassis=3,id=pci.3,bus=pcie.0,addr=0x2.0x2 \
-device pcie-root-port,port=0x13,chassis=4,id=pci.4,bus=pcie.0,addr=0x2.0x3 \
-device pcie-root-port,port=0x14,chassis=5,id=pci.5,bus=pcie.0,addr=0x2.0x4 \
-device qemu-xhci,p2=15,p3=15,id=usb,bus=pci.2,addr=0x0 \
-device virtio-serial-pci,id=virtio-serial0,bus=pci.3,addr=0x0 \
-blockdev '{"driver":"file","filename":"/media/gustavo/APPS/Win10_2004_English_x64.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":true,"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-cd,bus=ide.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1 \
-netdev tap,fd=33,id=hostnet0 \
-device e1000e,netdev=hostnet0,id=net0,mac=52:54:00:33:8e:70,bus=pci.1,addr=0x0 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-chardev spicevmc,id=charchannel0,name=vdagent \
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \
-device usb-tablet,id=input0,bus=usb.0,port=1 \
-spice port=5900,addr=127.0.0.1,disable-ticketing,image-compression=off,seamless-migration=on \
-device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,bus=pcie.0,addr=0x1 \
-device ich9-intel-hda,id=sound0,bus=pcie.0,addr=0x1b \
-device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0 \
-chardev spicevmc,id=charredir0,name=usbredir \
-device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 \
-chardev spicevmc,id=charredir1,name=usbredir \
-device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 \
-device virtio-balloon-pci,id=balloon0,bus=pci.4,addr=0x0 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/3 (label charserial0)
2020-07-10T18:11:12.406055Z qemu-system-x86_64: -blockdev {"driver":"file","filename":"/media/gustavo/APPS/Win10_2004_English_x64.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}: Could not open '/media/gustavo/APPS/Win10_2004_English_x64.iso': Permission denied
2020-07-10 18:11:12.509+0000: shutting down, reason=failed
2020-07-10 18:17:49.579+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-2-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-win10/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-2-win10/master-key.aes \
-m 8192 \
-uuid 8cc1e4b2-7ed5-476b-9425-1d591b717746 \
-no-user-config \
-nodefaults \
-no-hpet \
-no-reboot \
-boot strict=on \
-blockdev '{"driver":"file","filename":"/home/gustavo/Downloads/Win10_2004_English_x64.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-device e1000e,netdev=hostnet0,id=net0,mac=52:54:00:a9:c2:f3,bus=pci.1,addr=0x0 \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2020-07-10T18:18:36.463219Z qemu-system-x86_64: terminating on signal 15 from pid 1776 (/usr/sbin/libvirtd)
2020-07-10 18:18:36.663+0000: shutting down, reason=destroyed
2020-07-10 18:37:02.586+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-3-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-3-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-3-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-3-win10/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-3-win10/master-key.aes \
-m 8192 \
-smp 6,sockets=6,cores=1,threads=1 \
-uuid 0829d39a-1427-4441-8b82-8b7c3243e615 \
-no-user-config \
-nodefaults \
-no-hpet \
-no-reboot \
-boot strict=on \
-device e1000e,netdev=hostnet0,id=net0,mac=52:54:00:52:97:a4,bus=pci.1,addr=0x0 \
-msg timestamp=on
2020-07-10T18:37:20.847340Z qemu-system-x86_64: terminating on signal 15 from pid 1776 (/usr/sbin/libvirtd)
2020-07-10 18:37:21.248+0000: shutting down, reason=destroyed
2020-07-10 18:41:42.562+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-4-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-4-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-4-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-4-win10/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-4-win10/master-key.aes \
-blockdev '{"driver":"file","filename":"/usr/share/OVMF/OVMF_CODE.ms.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/win10_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-q35-4.2,accel=kvm,usb=off,vmport=off,smm=on,dump-guest-core=off,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-m 8192 \
-uuid 8991918e-d6d5-44b9-8b0a-9738cd7819a9 \
-no-user-config \
-nodefaults \
-no-hpet \
-no-reboot \
-boot strict=on \
-blockdev '{"driver":"file","filename":"/home/gustavo/Downloads/Win10_2004_English_x64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \
-device ide-cd,bus=ide.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=1 \
-blockdev '{"driver":"file","filename":"/home/gustavo/ata-LITEON_LCH-256V2S-11_2.5_7mm_256GB_BR0H3T4N1CB0075JB06D","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"driver":"qcow2","file":"libvirt-1-storage","backing":null}' \
-device ide-hd,bus=ide.1,drive=libvirt-1-format,id=sata0-0-1,bootindex=2 \
-device e1000e,netdev=hostnet0,id=net0,mac=52:54:00:af:78:c7,bus=pci.1,addr=0x0 \
-msg timestamp=on
2020-07-10T18:44:00.925293Z qemu-system-x86_64: terminating on signal 15 from pid 1776 (/usr/sbin/libvirtd)
2020-07-10 18:44:01.125+0000: shutting down, reason=destroyed
2020-07-10 18:53:51.295+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-5-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-5-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-5-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-5-win10/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-5-win10/master-key.aes \
-machine pc-q35-4.2,accel=kvm,usb=off,vmport=off,dump-guest-core=off,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-m 8192 \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-blockdev '{"driver":"host_device","filename":"/dev/disk/by-id/ata-LITEON_LCH-256V2S-11_2.5_7mm_256GB_BR0H3T4N1CB0075JB06D","aio":"native","node-name":"libvirt-2-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-2-storage"}' \
-device ide-hd,bus=ide.0,drive=libvirt-2-format,id=sata0-0-0,write-cache=on \
-device ide-cd,bus=ide.1,drive=libvirt-1-format,id=sata0-0-1,bootindex=1 \
-msg timestamp=on
2020-07-10T18:59:29.513082Z qemu-system-x86_64: terminating on signal 15 from pid 1776 (/usr/sbin/libvirtd)
2020-07-10 18:59:29.913+0000: shutting down, reason=destroyed
2020-07-10 18:59:47.470+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-6-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-6-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-6-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-6-win10/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-6-win10/master-key.aes \
-m 8192 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=32,server,nowait \
-no-hpet \
-no-shutdown \
-boot strict=on \
-blockdev '{"driver":"host_device","filename":"/dev/disk/by-id/ata-LITEON_LCH-256V2S-11_2.5_7mm_256GB_BR0H3T4N1CB0075JB06D","aio":"native","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-hd,bus=ide.0,drive=libvirt-1-format,id=sata0-0-0,write-cache=on \
-netdev tap,fd=34,id=hostnet0 \
-msg timestamp=on
2020-07-10T19:24:38.441658Z qemu-system-x86_64: terminating on signal 15 from pid 1776 (/usr/sbin/libvirtd)
2020-07-10 19:24:38.752+0000: shutting down, reason=shutdown
2020-07-10 19:44:10.448+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
QEMU_AUDIO_DRV=none \
-S \
-m 12288 \
-mem-prealloc \
-mem-path /dev/hugepages/libvirt/qemu/1-win10 \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device pcie-root-port,port=0x8,chassis=6,id=pci.6,bus=pcie.0,addr=0x1 \
-device vfio-pci,host=0000:23:00.0,id=hostdev0,bus=pci.5,addr=0x0 \
-device vfio-pci,host=0000:23:00.1,id=hostdev1,bus=pci.6,addr=0x0 \
-msg timestamp=on
2020-07-10T19:44:13.105890Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T19:44:13.121878Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T19:44:14.896077Z qemu-system-x86_64: vfio-pci: Cannot read device rom at 0000:23:00.0
Device option ROM contents are probably invalid (check dmesg).
Skip option ROM probe with rombar=0, or load from file with romfile=
2020-07-10T19:51:03.048622Z qemu-system-x86_64: terminating on signal 15 from pid 1734 (/usr/sbin/libvirtd)
2020-07-10 19:51:04.652+0000: shutting down, reason=destroyed
2020-07-10 20:01:01.272+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-msg timestamp=on
char device redirected to /dev/pts/2 (label charserial0)
2020-07-10T20:01:03.899673Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T20:01:03.915672Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T20:01:05.695902Z qemu-system-x86_64: vfio-pci: Cannot read device rom at 0000:23:00.0
2020-07-10T20:24:39.305707Z qemu-system-x86_64: terminating on signal 15 from pid 1731 (/usr/sbin/libvirtd)
2020-07-10 20:24:40.909+0000: shutting down, reason=destroyed
2020-07-10 21:00:23.476+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device pcie-root-port,port=0x8,chassis=6,id=pci.6,bus=pcie.0,multifunction=on,addr=0x1 \
-device pcie-root-port,port=0x9,chassis=7,id=pci.7,bus=pcie.0,addr=0x1.0x1 \
-device vfio-pci,host=0000:03:00.0,id=hostdev2,bus=pci.7,addr=0x0 \
-msg timestamp=on
2020-07-10T21:00:24.900388Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.0,id=hostdev2,bus=pci.7,addr=0x0: vfio 0000:03:00.0: group 15 is not viable
Please ensure all devices within the iommu_group are bound to their vfio bus driver.
2020-07-10 21:00:26.326+0000: shutting down, reason=failed
2020-07-10 21:00:26.998+0000: shutting down, reason=failed
2020-07-10 21:03:22.500+0000: shutting down, reason=failed
2020-07-10 21:06:53.365+0000: shutting down, reason=failed
2020-07-10 21:08:44.700+0000: shutting down, reason=failed
2020-07-10 21:09:51.610+0000: shutting down, reason=failed
2020-07-10 21:15:27.135+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device pcie-root-port,port=0xa,chassis=8,id=pci.8,bus=pcie.0,addr=0x1.0x2 \
-device pcie-root-port,port=0xb,chassis=9,id=pci.9,bus=pcie.0,addr=0x1.0x3 \
-device pcie-pci-bridge,id=pci.10,bus=pci.5,addr=0x0 \
-device vfio-pci,host=0000:03:00.0,id=hostdev0,bus=pci.7,addr=0x0 \
-device vfio-pci,host=0000:23:00.0,id=hostdev1,bus=pci.10,addr=0x1 \
-device vfio-pci,host=0000:23:00.1,id=hostdev2,bus=pci.10,addr=0x2 \
-msg timestamp=on
2020-07-10T21:15:28.096419Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.0,id=hostdev0,bus=pci.7,addr=0x0: vfio 0000:03:00.0: group 15 is not viable
2020-07-10 21:15:28.284+0000: shutting down, reason=failed
2020-07-10 21:15:30.549+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-mem-path /dev/hugepages/libvirt/qemu/2-win10 \
-display none \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=30,server,nowait \
-no-hpet \
-no-shutdown \
-boot strict=on \
-msg timestamp=on
2020-07-10 21:15:30.809+0000: shutting down, reason=failed
2020-07-10 21:17:16.666+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-mem-path /dev/hugepages/libvirt/qemu/3-win10 \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device vfio-pci,host=0000:23:00.0,id=hostdev0,bus=pci.10,addr=0x1 \
-device vfio-pci,host=0000:23:00.1,id=hostdev1,bus=pci.10,addr=0x2 \
-device usb-host,hostbus=1,hostaddr=2,id=hostdev2,bus=usb.0,port=1 \
-msg timestamp=on
2020-07-10T21:17:19.442372Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T21:17:19.478361Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T21:17:21.267141Z qemu-system-x86_64: vfio-pci: Cannot read device rom at 0000:23:00.0
2020-07-10 22:33:42.031+0000: shutting down, reason=failed
2020-07-10 22:42:23.697+0000: shutting down, reason=failed
2020-07-10 22:43:49.695+0000: shutting down, reason=failed
2020-07-10 22:44:36.815+0000: shutting down, reason=failed
2020-07-10 22:45:22.574+0000: shutting down, reason=failed
2020-07-10 22:45:36.926+0000: shutting down, reason=failed
2020-07-10 22:48:29.176+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-acso, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-machine pc-q35-4.2,accel=kvm,usb=off,vmport=off,dump-guest-core=off,kernel_irqchip=on,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-cpu 'EPYC-IBPB,x2apic=on,tsc-deadline=on,hypervisor=on,tsc-adjust=on,arch-capabilities=on,xsaves=on,cmp-legacy=on,perfctr-core=on,clzero=on,virt-ssbd=on,rdctl-no=on,skip-l1dfl-vmentry=on,mds-no=on,monitor=off,hv-time,hv-relaxed,hv-vapic,hv-spinlocks=0x1fff,hv-vendor-id=kvm hyperv,kvm=off' \
-m 12288 \
-mem-prealloc \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-netdev tap,fd=33,id=hostnet0,vhost=on,vhostfd=34 \
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:af:78:c7,bus=pci.1,addr=0x0 \
-msg timestamp=on
2020-07-10T22:48:32.122523Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T22:48:32.138513Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T22:48:33.940110Z qemu-system-x86_64: vfio-pci: Cannot read device rom at 0000:23:00.0
2020-07-10T22:52:19.567349Z qemu-system-x86_64: terminating on signal 15 from pid 1779 (/usr/sbin/libvirtd)
libusb: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusb: error [do_close] A cancellation hasn't even been scheduled on the transfer for which the device is closing
2020-07-10 22:52:21.572+0000: shutting down, reason=destroyed
2020-07-10 23:16:28.887+0000: starting up libvirt version: 6.0.0, package: 0ubuntu8.1 (Christian Ehrhardt <[email protected]> Wed, 20 May 2020 06:59:57 +0200), qemu version: 4.2.0Debian 1:4.2-3ubuntu6.3, kernel: 5.7.8-050708-generic, hostname: linux-workstation.localdomain
LC_ALL=C \
-S \
-m 12288 \
-mem-prealloc \
-display none \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-msg timestamp=on
2020-07-10T23:16:31.711316Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T23:16:31.727347Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3
2020-07-10T23:16:33.548514Z qemu-system-x86_64: vfio-pci: Cannot read device rom at 0000:23:00.0
This looks like it is your problem. Thank you for providing logs and config, and even formatting them, it is so nice to not have to ask.
The first thing to get the 1070’s vBIOS. You might be able to get it from the card itself, or possibly download it from techpowerup, although if you download it, make sure it is from the exact same card model.
https://www.techpowerup.com/vgabios/
Then pass the vBIOS as in your vm config.
<hostdev>
     <rom file='/path/to/your/gpu/bios.bin'/>
   </hostdev>
source
The other possibility is that it is caused by a bug in your motherboard’s UEFI. You may be able to fix it by upgrading or downgrading your motherboar’s UEFI. The keyword search is vfio stuck in D3
Thanks for the response.
I tried both possible solutions but it didn’t help me. The first one, no matter where I put the rom file and permissions, it gives me error while trying to read the file, says it can’t find it. I already verified if is a valid rom and it is.
The second option I tried upgrading but didn’t help, downgrading isn’t an option because the bios block.
I’m really out of ideas on this one :weary:
