Help Finding a 2u server case for a NAS
Hey hope y’all are doing fine. I been on the quest on trying to find a case for my new NAS server. I’m having trouble finding a case for the server something in the low end of price. I really like the Silverstone RM21-308 2U but its out of my price range. The case its the perfect size for my rack. If you have any recommendation please share them with me. Thank you in advance.
If silverstone is too pricey, then chinese case off eBay is your solution
plinkusa
Have ordered from them before, quality is good for the price
Only thing that’d make me reticent from ordering from them is the lack of https.
Beyond that aliexpress or alibaba have some cheap ones. But you will be rolling the dice with them.
If you want something quality (and made in USA), but don’t want Silverstone to build another golden toilet with your money, see if this Sliger doesn’t work for you? CX2137b | Sliger
They sell on eBay too I think that’s where I got their stuff before
Have sliger case too deff nice can’t remember them having anything 2u but never was really in the market for anything under 3u
[Hey! Hope you’re doing well too. Finding the right NAS server case on a budget can definitely be a bit of a challenge. Since you’re looking for something in the lower price range, and the Silverstone RM21-308 is out of reach, there are a few budget-friendly alternatives that might work for you.
You could look into the Rosewill RSV-L4500 or the iStarUSA D-214-MATX. They’re both rackmountable, relatively affordable, and offer decent space for drives. Another option might be checking for used or refurbished rackmount cases on eBay or other marketplaces—sometimes you can score a deal.
Hope that helps, and good luck with your NAS build! Let me know how it goes or if you find something that works.]
This topic was automatically closed after 273 days. New replies are no longer allowed.
