Hi everyone!
I have LG Gram 15Z980-G.AA55P 0.1 (2018) running Fedora 32 Gnome
fpaste output
=== fpaste 0.4.0.1 System Information (fpaste --sysinfo) ===
* OS Release (lsb_release -ds):
"Fedora release 32 (Thirty Two)"
* Kernel (uname -r ; cat /proc/cmdline):
5.7.11-200.fc32.x86_64
BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.7.11-200.fc32.x86_64 root=/dev/mapper/fedora_localhost--live-root ro resume=/dev/mapper/fedora_localhost--live-swap rd.lvm.lv=fedora_localhost-live/root rd.luks.uuid=luks-06138e00-fe38-4d62-9a63-c6328617ae9d rd.lvm.lv=fedora_localhost-live/swap rhgb quiet
* Desktop(s) Running (ps -eo comm= | grep -E '(gnome-session|startkde|startactive|xfce.?-session|fluxbox|blackbox|hackedbox|ratpoison|enlightenment|icewm-session|od-session|wmaker|wmx|openbox-lxde|openbox-gnome-session|openbox-kde-session|mwm|e16|fvwm|xmonad|sugar-session|mate-session|lxqt-session|cinnamon)' ):
gnome-session-b
gnome-session-c
gnome-session-b
* Desktop(s) Installed (ls -m /usr/share/xsessions/ | sed 's/\.desktop//g' ):
gnome-classic, gnome, gnome-xorg
* SELinux Status (sestatus):
SELinux status: enabled
SELinuxfs mount: /sys/fs/selinux
SELinux root directory: /etc/selinux
Loaded policy name: targeted
Current mode: enforcing
Mode from config file: enforcing
Policy MLS status: enabled
Policy deny_unknown status: allowed
Memory protection checking: actual (secure)
Max kernel policy version: 32
* SELinux Errors (selinuxenabled && journalctl --since yesterday |grep avc: | grep -Eo comm="[^ ]+" | sort |uniq -c |sort -rn):
18 comm="brprintconflsr2"
4 comm="systemd"
2 comm="rawtobr2"
* CPU Model (grep 'model name' /proc/cpuinfo | awk -F: '{print $2}' | uniq -c |
sed -re 's/^ +//' ):
8 Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
* 64-bit Support (grep -q ' lm ' /proc/cpuinfo && echo Yes || echo No):
Yes
* Hardware Virtualization Support (grep -Eq '(vmx|svm)' /proc/cpuinfo && echo Yes || echo No):
Yes
* Load average (uptime):
20:09:57 up 1:26, 1 user, load average: 1,72, 1,41, 1,10
* Memory usage (free -m):
total used free shared buff/cache available
Mem: 7695 3531 371 1083 3792 2780
Swap: 7823 23 7800
* Top 5 CPU hogs (ps axuScnh | awk '$2!=71985' | sort -rnk3 | head -5):
1000 71345 76.1 3.3 9284168 262528 ? Sl 20:04 3:54 chrome
1000 63426 27.6 2.2 897424 176720 ? Sl 19:19 13:51 steam
1000 71704 11.2 2.1 4914288 167868 ? Sl 20:07 0:15 chrome
1000 33351 10.8 3.0 5136840 243900 ? Ssl 18:44 9:17 gnome-shell
1000 59515 9.2 3.9 1372936 312804 ? SLl 18:59 6:30 chrome
* Top 5 Memory hogs (ps axuScnh | sort -rnk4 | head -5):
1000 60653 5.5 4.3 5121872 342640 ? Sl 19:03 3:38 chrome
0 18408 0.6 4.3 892184 340492 ? Ssl 18:44 0:31 packagekitd
1000 34970 0.3 3.9 1342920 310936 ? Sl 18:44 0:17 gnome-software
* Disk space usage (df -hT):
Filesystem Type Size Used Avail Use% Mounted on
devtmpfs devtmpfs 3,8G 0 3,8G 0% /dev
tmpfs tmpfs 3,8G 513M 3,3G 14% /dev/shm
tmpfs tmpfs 3,8G 1,9M 3,8G 1% /run
/dev/mapper/fedora_localhost--live-root ext4 69G 14G 52G 21% /
tmpfs tmpfs 3,8G 124K 3,8G 1% /tmp
/dev/sda2 ext4 976M 248M 661M 28% /boot
/dev/mapper/fedora_localhost--live-home ext4 391G 28G 343G 8% /home
/dev/sda1 vfat 599M 21M 579M 4% /boot/efi
tmpfs tmpfs 770M 212K 770M 1% /run/user/1000
* Block devices (without results: "blkid" AND "/sbin/blkid"):
N/A
* PCI devices (lspci):
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.3 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #3 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #11 (rev f1)
00:1d.3 PCI bridge: Intel Corporation Device 9d1b (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
02:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
* USB devices (lsusb):
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 10a5:0007 FPC FPC Sensor Controller
Bus 001 Device 003: ID 0bda:562e Realtek Semiconductor Corp. LG Camera
Bus 001 Device 002: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
* DRM Information (journalctl -k -b | grep -o 'kernel:.*drm.*$' | cut -d ' ' -f 2- ):
fb0: switching to inteldrmfb from EFI VGA
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[drm] Initialized i915 1.6.0 20200313 for 0000:00:02.0 on minor 0
fbcon: i915drmfb (fb0) is primary device
i915 0000:00:02.0: fb0: i915drmfb frame buffer device
i915 0000:00:02.0: [drm] *ERROR* CPU pipe A FIFO underrun
* Xorg modules (grep LoadModule /var/log/Xorg.0.log ~/.local/share/xorg/Xorg.0.log | cut -d \" -f 2 | xargs):
* GL Support (glxinfo | grep -E "OpenGL version|OpenGL renderer"):
OpenGL renderer string: Mesa Intel(R) UHD Graphics 620 (KBL GT2)
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.1.4
* Xorg errors (without results: "grep '^\[.*(EE)' /var/log/Xorg.0.log ~/.local/share/xorg/Xorg.0.log | cut -d ':' -f 2- "):
N/A
* Kernel buffer tail (dmesg | tail):
[ 2480.532115] logitech-hidpp-device 0005:046D:B01E.0004: HID++ 4.5 device connected.
[ 2481.196000] input: Logitech Wireless Mouse MX Master as /devices/virtual/misc/uhid/0005:046D:B01E.0004/input/input24
[ 2481.196782] logitech-hidpp-device 0005:046D:B01E.0004: input,hidraw1: BLUETOOTH HID v0.05 Keyboard [Logitech Wireless Mouse MX Master] on c0:b6:f9:8b:f7:a3
[ 2512.010107] logitech-hidpp-device 0005:046D:B01E.0005: HID++ 4.5 device connected.
[ 2512.516259] input: Logitech Wireless Mouse MX Master as /devices/virtual/misc/uhid/0005:046D:B01E.0005/input/input25
[ 2512.516491] logitech-hidpp-device 0005:046D:B01E.0005: input,hidraw1: BLUETOOTH HID v0.05 Keyboard [Logitech Wireless Mouse MX Master] on c0:b6:f9:8b:f7:a3
[ 3898.166537] logitech-hidpp-device 0005:046D:B01E.0006: HID++ 4.5 device connected.
[ 3898.717502] input: Logitech Wireless Mouse MX Master as /devices/virtual/misc/uhid/0005:046D:B01E.0006/input/input26
[ 3898.718462] logitech-hidpp-device 0005:046D:B01E.0006: input,hidraw1: BLUETOOTH HID v0.05 Keyboard [Logitech Wireless Mouse MX Master] on c0:b6:f9:8b:f7:a3
[ 4419.969996] i915 0000:00:02.0: [drm] *ERROR* CPU pipe A FIFO underrun
* Last few reboots (last -x -n10 reboot runlevel):
runlevel (to lvl 5) 5.7.11-200.fc32. Mon Aug 3 18:44 still running
reboot system boot 5.7.11-200.fc32. Mon Aug 3 18:44 still running
reboot system boot 5.7.6-201.fc32.x Mon Aug 3 18:40 - 18:43 (00:03)
runlevel (to lvl 5) 5.7.6-201.fc32.x Mon Aug 3 16:55 - 18:39 (01:43)
reboot system boot 5.7.6-201.fc32.x Mon Aug 3 16:55 - 18:39 (01:43)
runlevel (to lvl 5) 5.7.6-201.fc32.x Fri Jul 31 12:11 - 12:12 (00:01)
reboot system boot 5.7.6-201.fc32.x Fri Jul 31 12:10 - 12:12 (00:02)
runlevel (to lvl 5) 5.7.6-201.fc32.x Sat Jul 25 16:35 - 16:39 (00:04)
reboot system boot 5.7.6-201.fc32.x Sat Jul 25 16:34 - 16:39 (00:04)
runlevel (to lvl 5) 5.7.6-201.fc32.x Sat Jul 25 16:33 - 16:35 (00:01)
wtmp begins Mon Apr 20 09:03:04 2020
* DNF Repositories (dnf repolist):
repo id repo name
copr:copr.fedorainfracloud.org:elxreno:libinput-gestures Copr repo for libinput-gestures owned by elxreno
fedora Fedora 32 - x86_64
fedora-cisco-openh264 Fedora 32 openh264 (From Cisco) - x86_64
fedora-modular Fedora Modular 32 - x86_64
google-chrome google-chrome
rpmfusion-free RPM Fusion for Fedora 32 - Free
rpmfusion-free-updates RPM Fusion for Fedora 32 - Free - Updates
rpmfusion-nonfree RPM Fusion for Fedora 32 - Nonfree
rpmfusion-nonfree-updates RPM Fusion for Fedora 32 - Nonfree - Updates
updates Fedora 32 - x86_64 - Updates
updates-modular Fedora Modular 32 - x86_64 - Updates
* DNF Extras (dnf -C list extras):
Last metadata expiration check: 3:02:43 ago on seg 03 ago 2020 17:07:17.
Extra Packages
cupswrapperHL5350DN.i386 2.0.4-1 @@commandline
hl5350dnlpr.i386 2.0.3-1 @@commandline
zoom.x86_64 3.5.385850.0413-1 @@commandline
* Last 20 packages installed (rpm -qa --nodigest --nosignature --last | head -20):
tlp-rdw-1.3.1-1.fc32.noarch seg 03 ago 2020 19:53:09
util-linux-user-2.35.2-1.fc32.x86_64 seg 03 ago 2020 19:53:08
tlp-1.3.1-1.fc32.noarch seg 03 ago 2020 19:53:08
redhat-lsb-core-4.1-49.fc32.x86_64 seg 03 ago 2020 19:53:08
make-4.2.1-16.fc32.x86_64 seg 03 ago 2020 19:53:08
kernel-tools-libs-5.7.11-200.fc32.x86_64 seg 03 ago 2020 19:53:08
kernel-tools-5.7.11-200.fc32.x86_64 seg 03 ago 2020 19:53:08
guile22-2.2.6-4.fc32.x86_64 seg 03 ago 2020 19:53:08
ed-1.14.2-8.fc32.x86_64 seg 03 ago 2020 19:53:08
redhat-lsb-submod-security-4.1-49.fc32.x86_64 seg 03 ago 2020 19:53:07
patch-2.7.6-12.fc32.x86_64 seg 03 ago 2020 19:53:07
ncurses-compat-libs-6.1-15.20191109.fc32.x86_64 seg 03 ago 2020 19:53:07
mailx-12.5-33.fc32.x86_64 seg 03 ago 2020 19:53:07
m4-1.4.18-12.fc32.x86_64 seg 03 ago 2020 19:53:07
liblockfile-1.14-5.fc32.x86_64 seg 03 ago 2020 19:53:07
libesmtp-1.0.6-19.fc32.x86_64 seg 03 ago 2020 19:53:07
hdparm-9.58-3.fc32.x86_64 seg 03 ago 2020 19:53:07
esmtp-1.2-15.fc32.x86_64 seg 03 ago 2020 19:53:07
spax-1.6-2.fc32.x86_64 seg 03 ago 2020 19:53:06
lshw-B.02.19.2-2.fc32.x86_64 seg 03 ago 2020 19:44:27
* EFI boot manager output (efibootmgr -v):
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 0002,001A,0000,0001,0015,0016,0017,0018,0019,001B,001C
Boot0000* Pop!_OS 19.10 HD(1,GPT,5e63c498-acc0-468a-aa76-ecce4ce2e267,0x1000,0xf8fff)/File(\EFI\SYSTEMD\SYSTEMD-BOOTX64.EFI)
Boot0001* ubuntu HD(1,GPT,898b83cb-2313-4cdb-8841-41e3274d0ee1,0x1000,0x96000)/File(\EFI\ubuntu\shimx64.efi)
Boot0002* Fedora HD(1,GPT,699d67bf-2906-45ec-b5b1-2748f1cbc5c0,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0010 Setup FvFile(4213591d-ceef-425f-915b-ae4559680f62)
Boot0011 HiddenMenuSetup FvFile(04689584-799d-4a9d-ffff-ffffb91a2d5b)
Boot0012 SecureSetup FvFile(a8f1e579-0d86-4c93-ffff-ffff76875225)
Boot0013 Boot Menu FvFile(86488440-41bb-42c7-93ac-450fbf7766bf)
Boot0014 F11 Recovery FvFile(c8714e83-895e-4192-ffff-ffff293630b3)
Boot0015* USB CD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot0016* ATA HDD2: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f602)
Boot0017* ATA HDD1: HFS512G39TNF-N3A0A PciRoot(0x0)/Pci(0x17,0x0)/Sata(1,0,0)..bYVD.A...O.*..
Boot0018* NVMe0: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a406)
Boot0019* NVMe1: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a407)
Boot001A* USB HDD: Generic- SD/MMC PciRoot(0x0)/Pci(0x14,0x0)/USB(14,0)3.!..3.G..A.....
Boot001B* USB FDD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot001C* USB LAN: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,e854bca4cae7704ca322b00da0376322)
I read this article on phoronix about better linux drivers for the laptop:
(I don’t know why, but I can’t post links)
From what I understood, I would need to recompile the kernel with the LG_LAPTOP Kconfig switch actived. I’ve been using Linux for the past 3 years but never built the kernel myself.
Is there a way to build the kernel based on the default Fedora, but with that flag activated? If so, could anyone please point me in the right direction?
Thank you
