Hi good peeps. A long shot but maybe someone can help.
I've been having an issue with "disc 0 has been surprised removed" for almost 2 months now. I've tried to the hilt to resolve this issue but to no avail. Mostly its recurring almost to the second on the hour every time. I've tried looking into tasks ect... and everything else within my knowledge but to no avail. Driving me nuts pretty much now.
High end skylake build, OS Windows 10 1511. Was apparent before the 1511 update also.
I have a screen shot of the event viewer but not clear how to post that here.
This is rather curious, also could you change the name of this thread to something like "[HELP] Disk Error" just so other people know whats this is about I would get http://crystalmark.info/software/CrystalDiskInfo/index-e.html to see some more information because all I get from this is that your disk is being disconnected while in use
Have crystal here mate. Ill give that a go. The disk just keeps popping in and out every hour on the hour never happens when im using it. It is indeed curious.
if you go to services, and look for "Windows Driver Foundation - User-mode Driver Framework".... Does the status stay running and what is the startup type? If the Status is not running, set the startup type to automatic and reboot.
Curious i have 2 drives connected to the Asmedia controllers on this board (there are only 2). That's disc 0 & disc 1 only with disc 0 do i have this issue.
If the issue was a slight connection problem then the removal issue would be very random and disruptive. There has to be something in windows triggering that controller on a regular basis. Really biting the cookie here.
Possibly a format is in order. If not then mobo return. But a faulty sata controller wouldn't give a regular on the hour disconnect.
