Help dial in voltage please on my 2600x
help dial in voltage please im tring to set 1.4volts on the vcore for my amd 2600x at 4.075 - 4.1ghz
my core gear is
cpu - 2600x oc to 4.075ghz
mobo - gigabyte AORUS B450M
ram - 2 x Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16
with these volt settings
Dynamic Vcore(DVID) +0.234**
Dynamic VCORE SOC(DVID) +0.030
DRAM Voltage (CH A/B) 1.330V
an i cant tell if im getting it right
i have tried both global c states both enabled an disabled an auto
it seems more stable with c stats disabled but at the boot bios screen
it reads a peak of 1.380 volts but at main screen it looks like im getting 1.46
under the gnome extension vitals iv cant tell how to read which volt
reading refers to the vcore volts reading help me with this please
What LLC settings are you using?
PBO on or off?
also - are you trying to set 1.4v all the time? thats a heck of a lot…
the aorus b450m doesnt have LLC settings an i dont know what
PBO on or off is
an like i said i cant tell what the vcore is at at load to even know if i hit 1.4
vitals doesn’t label the volts so im either way under or way over the mark
thers two steady 1.35volt reads an one 1.44 - 1.46 volt read
one i assume is the ram read but the other two is a toss up on which is which this is what i
need help determining which is the vcore read
