Help Diagnosing H11SSL-i Mobo with AMD EPYC 7551P [Solved...Kinda]
I have a EPYC 7551P AMD CPU 32 Cores + Supermicro H11SSL-i Motherboard, I got it used a couple of months back, because it took me awhile to have the budget for the rest of the parts (HDD, power supply, etc)
When I give it power BMC LED is solid then just blinks (not rapidly though) no other lights come on and it does not boot/post.
The board has IPMI and I tried to use that for diagnosis however it never showed up on my network, when I plug it in despite the lights on the RJ45 port blinking and lighting up.
I’ve tried reseating the CPU and RAM, still same issue.
Any thoughts on diagnosing what might be the issue here?
I happen to have a pair of that exact config :wink: Things to heck:
  1. make sure the CPU isn’t locked. Cheap EPYC CPU’s are generally locked to a specific board and/or vendor, they refuse to boot in anything else :face_with_symbols_over_mouth:
  2. make sure you use the correct RAM, EPYC expects ECC RAM. Yeah, I made that mistake :stuck_out_tongue: I use Samsung LRDIMMs, but I suspect those are unobtainium ATM :money_with_wings:
  3. do a full BMC reset (not required if you can log in, I couldn’t make out from your post whether you can) using the SuperMicro reset tool (there’s several threads I posted in finding that) as it’s likely the IPMI/BMC has an unknown static IP address
  4. are all power connectors supplied with power from the PSU?
HTH!
  1. How would I check if the cpu is locked?
  2. The ram should be ECC its 4 sticks of this: (https://www.memory4less.com/Samsung-32GB-DDR4-PC17000-M386A4G40DM0)
  3. TBD
  4. all power connectors are connected except that 12V 4-pin Auxilliary Power Connector (JPW1) in the top left because my PSU didn’t come with a plug for that. (but that seemed optional?)
Your RAM is about the same as mine, so that shouldn’t be an issue. Locked CPU’s are generally very cheap so you may think you’re getting a fantastic deal but in actual fact you’re getting screwed as many vendors do not mention the reason for their cheap CPU’s :roll_eyes:
As for power: the board has 2 very similarly named connectors. One is indeed optional, the other isn’t. Guess which one you didn’t connect :wink: You can get Molex to CPU power (ESP) adapters for those.
So it powered up!
I think something is up with the jumper pins and that was a red herring as well.
After a bit of googling, I saw you could use wire shark to listen to its arp call, and figure out what static ip the IPMI thinks it should be. Sure enough I spotted it, claiming to be 1.1.21.118 (which is interesting), so I plugged its either net cable, into my laptop, and fudged my the nic to be on the same subnet, and got to the login screen, however it was not using default creds so I couldn’t log in.
So even though it didn’t work two days ago when it was the first thing I did, I decided to try resetting the CMOS see if it reset that password too. Suddenly right after I gave it power it spun up and posted and tried to boot from one of the old HDDs I stuck in there.
I then gave it a proper shut down and tried to boot it again with the power button…nothing, touched the power pins with a screw driver…nothing. I had to do the CMOS reset again to get it to boot, this time though I changed the bios so that if it looses power it automatically boots up and that’s how I’ve been getting the machine to start and post.
Weirdly though, when I was in grub it did respond to the physical power buttons/pins and rebooted the machine when the button pressed.
So this mobo is a little haunted, I guess this is the price I pay for used hardware???
Next, step though is to got get that utility for IPMI to reset its password cause that’s still what ever was left on there, but its good to be back in “work arounds” and “Solvable problems” territory.
Thanks for the help you inspired me to keep trying.
Nice to know you made progress. I’ll be battling IPMI issues as well, a 3151-based SoC EPYC system doesn’t allow me to log in anymore. I have the tools to fix it, but it’s a matter of how much time and energy I want to spend on it ATM. And that’s not a lot, frankly :face_with_diagonal_mouth:
