KVM Model:
PAAG-E3122B
5-gigabit
Problem:
I am not getting any video signal nor mouse/keyboard input. The only indication of ‘life’ on the KVM are the LEDs showing green when I got the USB connected.
One of my questions is about the USB protocol listed in the documentation. The literature that comes with the KVM indicates to connect to the USB 3.2 Gen 1 port of my PC. I only have USB 3.1 Gen 2 ports, but from what I have been reading these are synonymous with one another and was just a marketing name change. Am I correct in that?
Also, the USB cable should work if it is a 3.0 B version correct?
I’ve been reading a number of posts from everyone and it seems cable length is a major item. My display port cables are the typical 6’ length. They all work without using the KVM. I’ve tested with just one monitor on all ports of the KVM with no change. I’ve held the button on the KVM for a good ten count with nothing happening and just clicking the button doesn’t change the LEDs to red.
Other Notes:
I did wonder if the power adapter was no good, but with my volt meter I did have just under 12 volts coming out of the line.
Thank you in advance for any help you may be able to offer.
