I would look and see if theres ram somewhere else that would work as well as if you can get an older SSD. I my rig I have a mix of some Samsung ram that was in another machine (4GB that you can buy for like 10 bucks) and some G.Skill ram that I wouldn't have been able to get otherwise (normal looking dimms but overclockable).
For an OS drive I have a samsun P800 64GB SSD. 30 GB for windows, 26 GB for linux, and the rest of the space is linux swap space. The SSD is purely to boot from and to store updates. Each side only uses 8 GB with windows 10 on one side and Linux on the other. You might find it helpful to do it that way especially if you have High RPM HDD's. Most of the HDD's in my system I already had, I only bought one. You could probably find a 64 GB SSD for 25-40 (based on USD) or at least not for very much. At the same time to find a 750 GB drive and use a laptop hard drive you might have lying around would work just fine. Theres a lot of cash you can save :P
