Hello Everyone.
I own the following hardware which should fully support ECC:
Motherboard: Asrock Rack B650D4U-2L2TBCM
- System Memory: Supported Type DDR5 288-pin ECC/non-ECC UDIMM
- Memory QVL: DDR5 4800 ECC 32GB Samsung M324R4GA3BB0-CQK0L
Processor: AMD Ryzen 9 PRO 7945
- ECC Support: Yes (Requires mobo support)
RAM: 4x DDR5 4800 ECC 32GB Samsung M324R4GA3BB0-CQK0L
I freshly installed Ubuntu 24.04 and apparently, I have no ECC enabled.
Any help is welcome!
Below are some commands showing the hardware detected.
$ sudo dmidecode -t memory
# dmidecode 3.5
Getting SMBIOS data from sysfs.
SMBIOS 3.5.0 present.
Handle 0x001C, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 128 GB
Error Information Handle: 0x001B
Number Of Devices: 4
Handle 0x001F, DMI type 17, 92 bytes
Memory Device
Array Handle: 0x001C
Error Information Handle: 0x001E
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL A
Type: DDR5
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 4800 MT/s
Manufacturer: Samsung
Serial Number: 0576FB3C
Asset Tag: Not Specified
Part Number: M324R4GA3BB0-CQKOD
Rank: 2
Configured Memory Speed: 3600 MT/s
Minimum Voltage: 1.1 V
Maximum Voltage: 1.1 V
Configured Voltage: 1.1 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Unknown
Module Manufacturer ID: Bank 1, Hex 0xCE
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 32 GB
Cache Size: None
Logical Size: None
Handle 0x0022, DMI type 17, 92 bytes
Memory Device
Error Information Handle: 0x0021
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR5
Speed: 4800 MT/s
Serial Number: 057705B9
Rank: 2
Cache Size: None
Logical Size: None
Handle 0x0025, DMI type 17, 92 bytes
Memory Device
Error Information Handle: 0x0024
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL B
Type: DDR5
Speed: 4800 MT/s
Serial Number: 0576FF4A
Rank: 2
Cache Size: None
Logical Size: None
Handle 0x0028, DMI type 17, 92 bytes
Memory Device
Error Information Handle: 0x0027
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR5
Speed: 4800 MT/s
Serial Number: 0576FB07
Rank: 2
Cache Size: None
Logical Size: None
$ sudo lshw -c memory
*-firmware
description: BIOS
vendor: American Megatrends International, LLC.
physical id: 0
version: 4.09
date: 10/02/2023
capacity: 32MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer int10video acpi usb biosbootspecification uefi
*-cache:0
description: L1 cache
physical id: 17
slot: L1 - Cache
capacity: 768KiB
clock: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 18
slot: L2 - Cache
capacity: 12MiB
clock: 1GHz (1.0ns)
configuration: level=2
*-cache:2
description: L3 cache
physical id: 19
slot: L3 - Cache
capacity: 64MiB
clock: 1GHz (1.0ns)
configuration: level=3
*-memory
description: System Memory
physical id: 1c
slot: System board or motherboard
*-bank:0
description: DIMM Synchronous Unbuffered (Unregistered) 4800 MHz (0.2 ns)
product: M324R4GA3BB0-CQKOD
vendor: Samsung
physical id: 0
serial: 0576FB3C
slot: DIMM 0
width: 64 bits
clock: 505MHz (2.0ns)
*-bank:1
vendor: Samsung
physical id: 1
serial: 057705B9
slot: DIMM 1
width: 64 bits
*-bank:2
vendor: Samsung
physical id: 2
serial: 0576FF4A
slot: DIMM 0
width: 64 bits
*-bank:3
vendor: Samsung
physical id: 3
serial: 0576FB07
slot: DIMM 1
width: 64 bits
lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 24
On-line CPU(s) list: 0-23
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 9 PRO 7945 12-Core Processor
CPU family: 25
Model: 97
Thread(s) per core: 2
Core(s) per socket: 12
Socket(s): 1
Stepping: 2
CPU(s) scaling MHz: 24%
CPU max MHz: 5482.0000
CPU min MHz: 400.0000
BogoMIPS: 7399.33
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht sys
call nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_a
picid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave a
vx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs sk
init wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd m
ba perfmon_v2 ibrs ibpb stibp ibrs_enhanced vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a
avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt x
savec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local user_shstk avx512_bf16 clzero irp
erf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid dec
odeassists pausefilter pfthreshold avic v_vmsave_vmload vgif x2avic v_spec_ctrl vnmi avx512vbmi umip pku
ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid overflow_recov
succor smca fsrm flush_l1d
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 384 KiB (12 instances)
L1i: 384 KiB (12 instances)
L2: 12 MiB (12 instances)
L3: 64 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-23
Vulnerabilities:
Gather data sampling: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Reg file data sampling: Not affected
Retbleed: Not affected
Spec rstack overflow: Vulnerable: Safe RET, no microcode
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS; IBPB conditional; STIBP always-on; RSB filling; PBRSB-eIBRS Not a
ffected; BHI Not affected
Srbds: Not affected
Tsx async abort: Not affected
