Headphone jack on my minisforum is not detected
I have a Minisforum MS-S1 Max (one of the strix halo units). I was using a USB speaker until now. This week I resurrected my old Sennheiser headphones with new pads & cord, but when I plug it in the headphone jack on the front, it’s not detected anywhere. Audio continues to play through the USB speaker (or through my monitor via HDMI). So obviously I tried with something else to check if the resurrection failed. Same issue with my regular earphones. I then tried using the Sennheiser with my laptop and phone, both worked really well!
Searching around, I couldn’t figure out how to debug this. So I used an LLM, but I don’t quiet understand those results either (except that this might be a driver issue).
My audio devices:
$ pactl list cards | grep -iE 'Name:|headphone|available|Active Profile'
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
	Active Profile: output:hdmi-stereo
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
		hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
	Active Profile: input:analog-stereo
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 3, not available)
				port.type = "headphones"
				device.icon_name = "audio-headphones"
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
		pro-audio: Pro Audio (sinks: 1, sources: 0, priority: 1, available: yes)
	Active Profile: output:analog-stereo
    onboard audio chip, able to play over HDMI
When I plugin my headphone, it’s not detected:
$ sudo evtest
[sudo] password for user:
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:	Power Button
/dev/input/event1:	AT Raw Set 2 keyboard
/dev/input/event10:	NuPhy Air75 V3 Mouse
/dev/input/event11:	NuPhy Air75 V3 System Control
/dev/input/event12:	NuPhy Air75 V3 Consumer Control
/dev/input/event13:	NuPhy Air75 V3
/dev/input/event14:	HID 413d:2107
/dev/input/event15:	HID 413d:2107 Consumer Control
/dev/input/event16:	HID 413d:2107 System Control
/dev/input/event17:	PC Speaker
/dev/input/event18:	HD-Audio Generic HDMI/DP,pcm=3
/dev/input/event19:	HD-Audio Generic HDMI/DP,pcm=7
/dev/input/event2:	Logitech M720 Triathlon
/dev/input/event20:	HD-Audio Generic HDMI/DP,pcm=8
/dev/input/event21:	HD-Audio Generic HDMI/DP,pcm=9
/dev/input/event22:	HD-Audio Generic Mic
/dev/input/event23:	HD-Audio Generic Headphone
/dev/input/event3:	Video Bus
/dev/input/event4:	HID 413d:2107
/dev/input/event5:	Logitech Wireless Mouse
/dev/input/event6:	Logitech K230
/dev/input/event7:	Harman JBL Flip 7
/dev/input/event8:	NuPhy Air75 V3
/dev/input/event9:	NuPhy Air75 V3
Select the device event number [0-23]: 23
Input driver version is 1.0.1
Input device ID: bus 0x0 vendor 0x0 product 0x0 version 0x0
Input device name: "HD-Audio Generic Headphone"
Supported events:
  Event type 0 (EV_SYN)
  Event type 5 (EV_SW)
    Event code 2 (SW_HEADPHONE_INSERT) state 0
Properties:
Testing ... (interrupt to exit)
^C
This stays like that, and I have to cancel it.
The LLM pointed me to this issue: GitHub - puffo/minisforum-audio-fix · GitHub , with this explanation:
[the issue] reports the same symptom: node 0x21 jack sense always reads “unplugged”, and node 0x17 has working jack sense but isn’t wired to the output. Its fix is a firmware patch plus auto-mute disabling. Caveat: it targets subsystem 1f4c:b020 (AI 9 HX 370), and your board is 1f4c:b026 (MS-S1 MAX, Strix Halo). Treat it as a starting point, not a drop-in fix.
Anyone has any bright ideas I could try?
Since I use Fedora, initially I asked this question on Fedora’s discussion board, but haven’t received any response. Then I figured maybe this is more of a hardware enthusiasts question, so here I am :stuck_out_tongue:
