HD 7970 FX 8350 but low fps (BF4) [Solved]
Just try uninstalling msi afterburner (that was the culprit on my pc, couldnt remember the name) and re-installing 13.9, when I did that things went back to being awesome :D
  • update your bios to latest version never harms..
  • disable cool n quiet, i guess it shouldn´t be an issue if its enabled, but i have it disabled on my mobo.
  • set the cpu core voltage from offset, to manual mode, leave everything on auto.
But the Asrock 970 extreme 3 like i said above is not realy a great mobo, im sorry. those 4+1 powerphase and cheap analog vrm´s are not realy designed for powering a power hungry 8 core cpu. i don´t see why people keep on recommending this combo, if you want a highend FX8350 cpu then its better not to cheap out on a mobo, but to buy a decent 990FX chipset board. like the Asus M5A99FX pro R2.0 with 6+2 powerphase and high quality digi vrm´s.
But offcourse this does not mean, your motherboard is the issue.. that its holding back your cpu  i saw your core voltage set a 1.4+ volts on stock.. that seems a bit high to me.. like i said above i dont hope that this is your issue, but it could be..
if you have a friend, where you can  install you gpu in his/her computer and test what kind of  fps you get then, is the best way to see if its an  gpu issue driver issue or mobo/cpu issue.
+1, AsRock didn't certify that mobo for the FX8350. It's a digi-VRM board alright, but only certified up to the FX8300 or FX8150. The FX8350 isn't even supported properly by the mobo's BIOS. It will just never work:
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=970%20Extreme3
@MisteryAngel: Nope, I'm on my one. Non of my friends have a computer case as big as mine, and I almost have problems fitting that big HD 7970 in my case.
@Some Dude: Yeah, already OC'ed my GPU from 925/1325 to 1000/1400. My CPU is a different story, it's already running quite hot when playing BF4, it's because I have the stock cooler. When I did Auto Tune in AMD Catalyst Control Center It got up to 4300MHz and then my computer shut itself down because my CPU was getting to hot, do those extra 200mhz really help me?
@flazza, I already removed MSI Afterburner, but I still have to install 13.9, I don't think it will help me but it's worth a shot.
I also disabled Cool 'n Quite, I got a performance boost out of it, so I want to ask this: My Fps very from 35 to 70 but it is almost all the time at 45 FPS, is this normal on Ultra Preset @1080P?
If yes, then I think Cool 'n Quite did help me.
Yeah I also disabled cool 'n quiet to get a performance boost. The reason it is really noticable in bf4 is because of the extended 8 core support. In its true meaning cool 'n quiet shouldn't get in the way (stressed should mean stressed!), but it does, it just, DOES.
Glad you found it. 45FPS on ultra sounds normal to me. I got an average of 48fps, but on eyefinity, and I have 2 7970s and an OC'ed 8350; It kind of adds up to me.
well i think you have to life with it at the moment.
I still think that your motherboard is struggling with the cpu, thats probably also the reason why your system shutted down, after a little overclock to 4.3 GHZ.
*Dus een keer een nieuw moederbordje kopen, denk ik! lol ☺*
Yeah, I don't really need Ultra. I just tried medium with Ultra textures and it's locked at 60 fps and it (almost) never goes below that, so yeah that's a real performance boost :) I think i'm done with this post as of today. Thank you all for you help!
-Jaron
You might want to try upgrading to win8.1 (if not already) people are saying there should be 10-20 fps to gain
+1, en wel dringend, zoals hoger vermeld is het bord niet goedgekeurd voor de FX8350, het is gewoon een gevaarlijke situatie. Leg je vinger (voorzichtig) maar eens op de VRMs en het NB koellichaam, zal wel gruwelijk heet lopen...
Anyway, I wouldn't overclock it, and keep Cool 'n Quiet on, load line leveling on auto, and at stock speed, just to prevent house fires and stuff, and I'm serious about the house fires.
Sorry to thread jack, but I figure it would be better to ask here then make a pointless new thread for one question.
I just got the same motherboard from a friend for free, the Asrock 970 extreme 3. I was planning on dumping an fx8320 in there. It seems that the boards 4+1 power phase is not a good combo with the fx8350, but would I be safe running an FX8320 in there and not experience any throttling? Since it has a lower clock speed and lower power consumption. No overclock of course, might even look to under volt.
In my case, the last 4+2 phase motherboard i used with a 8350 almost burned out. But that was partially my fault, since i overclocked it. So I guess you really could do that, if you plan not to overclock and all, and sleep bad at night. >:)
I heard some cases where 4 phases would hold out on a 8350 w/o overclocking, but basicly you are on unknown terrain here. Proof of that is that manufacturers like gigabit (like I found out) and Asrock (like Zoltan mentioned) will basicly deny it even supports them FX CPUs.
Well never undervolt a cpu in the first place, cpu´s are very sensetive  for that.
Running a power hungry FX8320/8350 on a 4+1 powerphase and analog vrm board, is not realy something i would personaly recommend.
Looks like I might be selling that board then because the next best CPU that the board will support is a fx6300 and I feel like that would be a waste of money and I'd be better off using the money made from selling the board to get an haswell or ivy bridge set up.
well, I was browsing reddit earlier reading stuff that didn't apply to me at all. but I found this and it seems like it could help you out a bit.
http://np.reddit.com/r/battlefield_4/comments/1puiok/getting_cpu_lag_in_battlefield_4_i_found_a_fix/
I dont really saw parked cores in his CPU chart, but on windows 7, yeah, always worth to do this anyway.
well you can allways try it, i have also disabled core parking from the beginning.
is realy easy to do.
  1. Go to your register: start type "regedit"
  2. Go to Edit then klick on "search"
  3. copy and paste this reg key: " 0cc5b647-c1df-4637-891a-dec35c318583 " offcourse without the "" marks.
  4. then klick on "Value max" and change the value from 64 to 0 (zero)
  5. close the register
  6. Mostley this key exists 2x in the register, so do the steps again. in my case the key exists 2 times, so i had to do it 2 times, but the steps are the same.
grtz Angel ☺
